I am building a project with nrf52840dk, on NCS 2.5.2.
I have a board that includes an NXP SC18IS606. This is an ISC to SPI bridge which contains several additional GPIOS (to function as CS lines).
I have taken the NXP SC18IM704 which is a UART to I2C bridge and also includes gpios as an example for how to set this up..
Since this is a bridge and also a gpio the devicetree entry ends up looking like this:
spi_bridge: SC18IS606@28 { compatible = "nxp,sc18is606"; status = "okay"; reset-gpio = <&cone_io_expander 1 GPIO_ACTIVE_LOW>; reg = <0x28>; sc18is606_gpio_port0: sc18is606_gpio { compatible = "nxp,sc18is606-gpio"; #gpio-cells = <2>; ngpios = <8>; status = "okay"; gpio-controller; }; spi_ext: sc18is606_spi { compatible = "nxp,sc18is606-spi"; status = "okay"; //TODO add LED chain here }; };
This is instanced on a i2c0.
For some reason devicetree does not generate the properties for the gpio sub-component. I get errors like this:
zephyr/include/generated/devicetree_generated.h:13224:45: error: 'DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_ngpios' undeclared here (not in a function);
and indeed th edevice tree generated header file only includes properties for compatble and status:
/* Generic property macros: */ #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible {"nxp,sc18is606-gpio"} #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_IDX_0 "nxp,sc18is606-gpio" #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_IDX_0_STRING_UNQUOTED nxp,sc18is606-gpio #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_IDX_0_STRING_TOKEN nxp_sc18is606_gpio #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_IDX_0_STRING_UPPER_TOKEN NXP_SC18IS606_GPIO #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_IDX_0_EXISTS 1 #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_FOREACH_PROP_ELEM(fn) fn(DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio, compatible, 0) #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_FOREACH_PROP_ELEM_SEP(fn, sep) fn(DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio, compatible, 0) #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_FOREACH_PROP_ELEM_VARGS(fn, ...) fn(DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio, compatible, 0, __VA_ARGS__) #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_FOREACH_PROP_ELEM_SEP_VARGS(fn, sep, ...) fn(DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio, compatible, 0, __VA_ARGS__) #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_LEN 1 #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_compatible_EXISTS 1 #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status "okay" #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_STRING_UNQUOTED okay #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_STRING_TOKEN okay #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_STRING_UPPER_TOKEN OKAY #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_IDX_0 "okay" #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_IDX_0_EXISTS 1 #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_ENUM_IDX 1 #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_ENUM_VAL_okay_EXISTS 1 #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_ENUM_TOKEN okay #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_ENUM_UPPER_TOKEN OKAY #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_FOREACH_PROP_ELEM(fn) fn(DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio, status, 0) #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_FOREACH_PROP_ELEM_SEP(fn, sep) fn(DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio, status, 0) #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_FOREACH_PROP_ELEM_VARGS(fn, ...) fn(DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio, status, 0, __VA_ARGS__) #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_FOREACH_PROP_ELEM_SEP_VARGS(fn, sep, ...) fn(DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio, status, 0, __VA_ARGS__) #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_LEN 1 #define DT_N_S_soc_S_i2c_40003000_S_sc18is606_28_S_sc18is606_gpio_P_status_EXISTS 1
I cannot figure out why it generates the ngpios for a ioexpander on the same bus but not for this device.
For reference here is the dts yaml for the gpio sub-component.
description: GPIO controller part for the SC18IS6060 bridge compatible: "nxp,sc18is606-gpio" include: gpio-controller.yaml properties: "#gpio-cells": required: true const: 2 ngpios: required: true const: 8 description: | Number of GPIOs available on port expander. gpio-cells: - pin - flags on-bus: nxp,sc18is606
Is it possible there is a depth limit for device tree properties? Any other ideas on what i'm doing wrong?
