UART not powering down Zephyr
I am using nRF Connect SDK V2.3.0. How can I power down the UART?
I am using the Interrupt-driven UART API, interrupt driven on RX and polling on TX. I have disabled the console on the dtb and prj.conf. I am using both UARTs in my application to talk to external peripherals (so I do not need logging nor the console on any of the UARTs). My application is a very low power application, micro amps matter here.
When I do not use the UART my power consumption is nice and low. As soon as I use the UART my power consumption jumps by 1.3mA, not good to say the least. I have tried to use the power manager "pm_device_action_run(uart, PM_DEVICE_ACTION_SUSPEND)", but my power consumption does not drop. I know it is the UART and not something else on my board, because as soon I issue the forbidden register writes, the power consumption drops down to micro amps again:
*(volatile uint32_t *)0x40002FFC = 0;   // Power down UARTE0
I did look at the NRFX UARTE drivers also and they are no good, I cannot know the size of the expected packet, nor drop packets due to a timeout.
My question is how can I power down the UART when I am not using it (simular to uninitializing it in the old nRF52 SDK) and then powering it up again when I need it? So technically I want a way to uninitialse the UARTs and re-initialise them again when I need them to save as much power as possible.
Thank you in advance for the assistance. Hope to hear from someone soon.
Kind Regards
Julian
  • Hi Edvin,
    Thank you so much for testing my application. That is excellent news.
    I have a theory of what is going on here. Like mentoined before I have a RS232 converter attached to UART0 that I power up. I think what is happening is because I cannot control when the UART gets initialised the RS232 converter gets powered up after the UART is initialised. This causes a framing error (or other error) on the UART and then the UART does not want to power down. By reading from the UART I suspect in the driver somewhere (in Zephyr) it clears the error flags.
    So my question is how can I clear the error flags directly with Zephyr (without reading or waiting to receive data from the UART)?
    I will test if it works if you can just tell me how to clear the errors. Thanks in advance. I believe we are close to solving this.
    Kind Regards
    Julian
    What does this look like  in your application? Do you see it in the logs or something?
    I see that pm_device_action_run() runs a few checks, and returns an error if it is not able to run properly. Do you see the return value of pmm_device_action_run not being 0? Can you try to step through this function to see how it behaves in your case?
    BR,
    Edvin
