Adding CONFIG_LOG=y causes Flash overflow error
This is my environment
  • IDE: VSC
  • SDK: NCS v2.2.0
  • nRF52-DK
I've got a couple of different sets of firmware for different applications, and I am seeing this issue with all of them.
They all use Bluetooth and have the MCU Boot manager enabled, as I need the OTA Firmware Update functionality.
Setup like that, I can't enable logging.  The moment I do, I get this error:
c:/nordic/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 23716 bytes
I've got no idea why this is occuring and whether its actually something I can get around somehow.
In the past, I've resolved this by simply printing debug statements out using printk(), and having a bunch of #ifdef DEBUG #end statements around the printk() statement so I can enable/disable those as I move through the firmware development.
But it would be good to get the logging working
Does anyone know how I can fix this?
Mike
  • Mike Austin (LPI) said:
    Seems to be suggesting that even though I'm setting CONFIG_LOG_MODE_MINNAL=y, its not actually being set to that.
    Since you verify that this is set for the application, this warning is likely related to a child image.
    That you can verify in, for example, build/mcuboot/zephyr/.config.
    To debug this, I often do
    cd build/mcuboot
    ninja menuconfig
    And then search( / ) for the related configuration, then look at its info ( ? ), to see why it is set as "n", cause this let you view its depenedncies and how they are set.
    So, somehow the minimal logging is not being set and full logging is adding 16kB.
    Hmmm. I dont quite remember now. From previous debugging, did you verify that the 16kB is from the application, or could it be from a child image?
