Adding CONFIG_LOG=y causes Flash overflow error
This is my environment
  • IDE: VSC
  • SDK: NCS v2.2.0
  • nRF52-DK
I've got a couple of different sets of firmware for different applications, and I am seeing this issue with all of them.
They all use Bluetooth and have the MCU Boot manager enabled, as I need the OTA Firmware Update functionality.
Setup like that, I can't enable logging.  The moment I do, I get this error:
c:/nordic/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.1.0/../../../../arm-zephyr-eabi/bin/ld.exe: region `FLASH' overflowed by 23716 bytes
I've got no idea why this is occuring and whether its actually something I can get around somehow.
In the past, I've resolved this by simply printing debug statements out using printk(), and having a bunch of #ifdef DEBUG #end statements around the printk() statement so I can enable/disable those as I move through the firmware development.
But it would be good to get the logging working
Does anyone know how I can fix this?
Mike
  • I have.
    So, this is my proj.conf
    And in every single .c file where I may want to use logging, I have this set:
    If I then build my code, this is how much flash I'm consuming (running pretty close to the limit, I know)
    If I then just change my proj.conf to this:
    But leave everything else as is, I get this error:
    So, by my calculations, I am adding 16,760 kB (= 224768 + 5684 - 213692) from somewhere!
  • Huh, that is odd.
    Can you verify from build/zephyr/.config that those configurations are set as expected?
    Can you try the same with some of our samples and see if you get similar results, or if it is only your app?
  • Yeah, its got me baffled!
    OK, this is my proj.conf settings for logging:
    And this is the relevant section of the .config file:
    That won't fit into my available flash space, so bombs out.  This is the full error message:
    I tried with a few samples, and other code I have.  I can definitely see a difference in the total amount of Flash consumed between having CONFIG_LOG_MODE_MINIMAL=y compared to CONFIG_LOG_MODE_MINIMAL=n
    Interestingly, if I set CONFIG_LOG_MODE_MINIMAL=y, I'm over-sized by 2148 bytes, but if I set
    CONFIG_LOG_MODE_MINIMAL=n, I've oversized by 12784 bytes, which is about the 11kB difference I've been seeing.  Just can't work out why I'm going over my Flash limit in the first place.
    Putting CONFIG_LOG=n, means I'm about 16kB less in total Flash than if I set CONFIG_LOG=y and CONFIG_LOG_MINIMAL=y.
    I do have a child image with this application, as I am using MCUBoot for OTA firmware updates, so thought perhaps I had to do the same in the mcuboot.conf file as I do for prog.conf, but any attempts I made to set CONFIG_LOG=n there had no impact on total flash space required once I set things up in my proj.conf.
    I guess that if logging in the mode minimal uses 16kB data, it uses 16kB data. I do not have any tables with numbers for each driver or such, so I can not confirm nor deny exact numbers here.
    I guess the best you can do is to check the same configs for other samples and see if they use the same space.
    You can also make MCUboot smaller. Here are some keywords to search for
    And also see https://github.com/nrfconnect/sdk-mcuboot/blob/main/boot/zephyr/prj_minimal.conf
    And specifically CONFIG_CBPRINTF_NANO=y makes MCUboot ca 10kB smaller I think
  • Hi Sigurd,
    I implemented a bunch of those CONFIG settings, and stumbled across this ticket which gave me a few more to try out.
    I was able to reduce my MCUBoot by about the 10kB you indicated, and also my firmware image by about 4kB.  So, now I can enable logging and still stay within the size limits.
    I did notice this warning pop up when I was building though:
    warning: The choice symbol LOG_MODE_MINIMAL (defined at subsys/logging\Kconfig.mode:28) was selected
    (set =y), but no symbol ended up as the choice selection. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_MODE_MINIMAL and/or look up
    LOG_MODE_MINIMAL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    Seems to be suggesting that even though I'm setting CONFIG_LOG_MODE_MINNAL=y, its not actually being set to that.
    But in my .config under build/zephyr I see this:
    which is suggesting its been set to what I want.
    Testing on a more simple example I have (its basically just a LED blinky for testing new hardware), I'm seeing this:
    CONFIG_LOG=n
    Code size = 20948
    CONFIG_LOG=y
    Code size = 22938
    CONFIG_LOG=y
    Code size = 30972
    So, minimal logging is adding 2kB and full logging is adding 10kB.  Yet in the firmware I am working with at the moment, those figures are:
    CONFIG_LOG=n
    Code size = 206992
    CONFIG_LOG=y
    Code size = 223336
    CONFIG_LOG=y
    Code size = 223336
    So, somehow the minimal logging is not being set and full logging is adding 16kB.
    Mike
