How to integrate MBEDTLS for nrf9160 and native simulation on sdk 2.6?
Dear Support Team
My goal is to build an application for two targets. The targets are an nrf9160 and a simulation target for running it natively on Linux (currently trying native_sim).
The application makes use of the mbedtls-API. For example the `mbedtls_x509...`, `mbedtls_ecp` etc...
To build it for the nrf9160 it works fine now with the following config:
CONFIG_MBEDTLS_TLS_LIBRARY=y
CONFIG_MBEDTLS_PK_WRITE_C=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_DHM_C=y
CONFIG_MBEDTLS_X509_CREATE_C=y
CONFIG_MBEDTLS_X509_CSR_WRITE_C=y
CONFIG_MBEDTLS_X509_CRT_PARSE_C=y
CONFIG_MBEDTLS_X509_LIBRARY=y
CONFIG_MBEDTLS_X509_USE_C=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=59000
CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y
CONFIG_MBEDTLS_PKCS1_V15=y
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS_CMAC_C=n
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_GCM_C=y
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SHA384_C=n
CONFIG_MBEDTLS_SHA512_C=n
CONFIG_MBEDTLS_CIPHER_MODE_XTS=n
CONFIG_MBEDTLS_CIPHER_MODE_CBC=n
CONFIG_MBEDTLS_CIPHER_MODE_CTR=y
CONFIG_MBEDTLS_CHACHA20_C=n
CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=n
CONFIG_MBEDTLS_SSL_SRV_C=n
CONFIG_MBEDTLS_ECDH_C=n
CONFIG_MBEDTLS_PKCS1_V21=n
CONFIG_MBEDTLS_CCM_C=n
CONFIG_MBEDTLS_POLY1305_C=n
CONFIG_MBEDTLS_HKDF_C=n
Furthermore, we had to modify the `modules/mbedtls/configs/config-tls-generic.h`-file slightly with some hardcoded `defines`.
But I am struggling to build it for native_sim. The problem is, that I can not enable the respective Kconfigs. For example:
warning: MBEDTLS_X509_LIBRARY (defined at /opt/zephyrproject/nrf/modules/trusted-
firmware-m/Kconfig.mbedtls_minimal.defconfig:32,
/opt/zephyrproject/nrf/subsys/nrf_security/Kconfig.tls:7) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: (TFM_PROFILE_TYPE_MINIMAL || NRF_SECURITY) (=n).
Furthermore, I have observed the following:
The library can be included via the `nrf-sdk`-west.yml or via `sdk-zephyr`-west.yml. Both of those will pull in a different state it seems:
Both refer to the mbedtls fork here: https://github.com/nrfconnect/sdk-mbedtls
But then there is also upstream mbedtls, that is pulled in by upstream zephyr, that seems to offer different options then the `sdk-mbedtls`-fork, like `CONFIG_MBEDTLS_BUILTIN`: https://github.com/zephyrproject-rtos/mbedtls
This confuses me a bit. And I can summarize my questions this way:
  • Which mbedtls-version to use with `sdk-2.6` (sdk vs upsteam, revision v3.5.2-ncs1 vs revision 66ed2279d6222056af172c188eaf4dcfed481032) ?
  • Which way do you recommend to configure MBEDTLS to achieve the goal described above? Could we use `CONFIG_MBEDTLS_CFG_FILE` instead?
  • How can we do all this, while ensuring, that hardware-crypto-acceleration is used when building for the nrf9160?
Thanks in advance and let me know, if you need additional information.
  • We have some unit-test in place. They use the native-posix board with `CONFIG_ASAN` and `CONFIG_UBSAN` activated. We run the unit-test directly on the hardware also.
    In addition we would like to do some integration/system-testing with a simulation setup.In the past we have used `qemu`, but it is not possible to activate `CONFIG_ASAN` to my knowledge. We are evaluating `native_sim` (released with zephyr 3.5) to do system-testing in a simulation environment that allows us to use native debugging tools and other tooling like above mentioned address sanitizer.
    Edit: on the hardware we run the unit tests without CONFIG_ASAN and CONFIG_UBSAN, because they are not supported to our knowledge.
  • The status on this ticket is that I have asked our crypto developers if they have any ideas here.
  • Speaking of the Dev, they just answered:
    This is not something we claim to support. The NCS MbedTLS config is coupled with building for our products.
    I have no idea if their use case is feasible, I suspect it would require a lot of config and build system voodoo, but I don't think we can support them on this. You are probably as likely as any of the developers to be able to provide advice here.
    So yea, I can spend some time to try and build a crypto sample for native_sim, but i would not have high hopes. As they say the tight coupling between our SoC and libraries may make this hard.
    One alternative would be to disable crypto for your project, but that might make the whole exercise a bit pointless?
  • Thanks for the quick reply. Disabling and Mocking the crypto-stuff could be an option.
    I was just wondering, if there is a supported way to achieve this, since software implementations for Mbedtls exists.
  • Doing some testing:
    zephyr/samples/drivers/crypto works with native_sim
    zephyr/samples/tfm_integration/tfm_psa_test does not work  with native_sim (even with vanilla zephyr)
    So to sum up parts that might have problems with native_sim:
    • Modem networking
      • Fix: Assuming IP works for native_sim, configure networking to use that instead
    • TF-M
      • I assume you need this?
      • Not sure how or if to fix this for native_sim at the moment.
    • Crypto
      • Which APIs do you currently use in your code?
      • Fix: I have never tried Mbedtls-shim before, but look into using that
    • HW specific components
      • Fix: Simulate
    Do you agree with this summary?
    Am I missing something? Do you disagree with anything?
