How to integrate MBEDTLS for nrf9160 and native simulation on sdk 2.6?
Dear Support Team
My goal is to build an application for two targets. The targets are an nrf9160 and a simulation target for running it natively on Linux (currently trying native_sim).
The application makes use of the mbedtls-API. For example the `mbedtls_x509...`, `mbedtls_ecp` etc...
To build it for the nrf9160 it works fine now with the following config:
CONFIG_MBEDTLS_TLS_LIBRARY=y
CONFIG_MBEDTLS_PK_WRITE_C=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_DHM_C=y
CONFIG_MBEDTLS_X509_CREATE_C=y
CONFIG_MBEDTLS_X509_CSR_WRITE_C=y
CONFIG_MBEDTLS_X509_CRT_PARSE_C=y
CONFIG_MBEDTLS_X509_LIBRARY=y
CONFIG_MBEDTLS_X509_USE_C=y
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_HEAP_SIZE=59000
CONFIG_MBEDTLS_SSL_SERVER_NAME_INDICATION=y
CONFIG_MBEDTLS_PKCS1_V15=y
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS_CMAC_C=n
CONFIG_MBEDTLS_PSA_CRYPTO_C=y
CONFIG_MBEDTLS_GCM_C=y
CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=16384
CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=16384
CONFIG_MBEDTLS_SHA384_C=n
CONFIG_MBEDTLS_SHA512_C=n
CONFIG_MBEDTLS_CIPHER_MODE_XTS=n
CONFIG_MBEDTLS_CIPHER_MODE_CBC=n
CONFIG_MBEDTLS_CIPHER_MODE_CTR=y
CONFIG_MBEDTLS_CHACHA20_C=n
CONFIG_MBEDTLS_ECDSA_DETERMINISTIC=n
CONFIG_MBEDTLS_SSL_SRV_C=n
CONFIG_MBEDTLS_ECDH_C=n
CONFIG_MBEDTLS_PKCS1_V21=n
CONFIG_MBEDTLS_CCM_C=n
CONFIG_MBEDTLS_POLY1305_C=n
CONFIG_MBEDTLS_HKDF_C=n
Furthermore, we had to modify the `modules/mbedtls/configs/config-tls-generic.h`-file slightly with some hardcoded `defines`.
But I am struggling to build it for native_sim. The problem is, that I can not enable the respective Kconfigs. For example:
warning: MBEDTLS_X509_LIBRARY (defined at /opt/zephyrproject/nrf/modules/trusted-
firmware-m/Kconfig.mbedtls_minimal.defconfig:32,
/opt/zephyrproject/nrf/subsys/nrf_security/Kconfig.tls:7) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: (TFM_PROFILE_TYPE_MINIMAL || NRF_SECURITY) (=n).
Furthermore, I have observed the following:
The library can be included via the `nrf-sdk`-west.yml or via `sdk-zephyr`-west.yml. Both of those will pull in a different state it seems:
Both refer to the mbedtls fork here: https://github.com/nrfconnect/sdk-mbedtls
But then there is also upstream mbedtls, that is pulled in by upstream zephyr, that seems to offer different options then the `sdk-mbedtls`-fork, like `CONFIG_MBEDTLS_BUILTIN`: https://github.com/zephyrproject-rtos/mbedtls
This confuses me a bit. And I can summarize my questions this way:
  • Which mbedtls-version to use with `sdk-2.6` (sdk vs upsteam, revision v3.5.2-ncs1 vs revision 66ed2279d6222056af172c188eaf4dcfed481032) ?
  • Which way do you recommend to configure MBEDTLS to achieve the goal described above? Could we use `CONFIG_MBEDTLS_CFG_FILE` instead?
  • How can we do all this, while ensuring, that hardware-crypto-acceleration is used when building for the nrf9160?
Thanks in advance and let me know, if you need additional information.
