Solved! I had issues with connected sensors.
I am using the Actinius Icarus board. I want to use the AWS_IOT sample to migrate my application from SDK 2.3 to 2.6. I want do disable UART to reduce the current consumption.
I have created a function:
void uart_set_enable(bool enable) { const struct device *uart0_dev = DEVICE_DT_GET(DT_NODELABEL(uart0)); const struct device *uart1_dev = DEVICE_DT_GET(DT_NODELABEL(uart1)); if (device_is_ready(uart0_dev)) { pm_device_action_run(uart0_dev, enable ? PM_DEVICE_ACTION_RESUME : PM_DEVICE_ACTION_SUSPEND); } if (device_is_ready(uart1_dev)) { pm_device_action_run(uart1_dev, enable ? PM_DEVICE_ACTION_RESUME : PM_DEVICE_ACTION_SUSPEND); } }
and I am calling this function in main
uart_set_enable(false);
I get an error:
[00:00:00.255,462] <inf> aws_iot_sample: The AWS IoT sample started, version: v1.0.0 16:39:39:590 -> [00:00:00.255,523] <inf> aws_iot_sample: Bringing network interface up and connecting to the network 16:39:39:601 -> [00:00:00.489,929] <inf> nrf_modem_lib_trace: Trace thread ready 16:39:39:606 -> [00:00:00.497,222] <inf> nrf_modem_lib_trace: Trace level override: 2 16:39:39:617 -> [00:00:00.536,956] <inf> aws_iot_sample: Hardware ID: 351901936128515 16:39:39:622 -> ASSERTION FAIL [!data->async->tx_size] @ WEST_TOPDIR/zephyr/drivers/serial/uart_nrfx_uarte.c:1901 16:39:39:627 -> [00:00:00.537,689] <err> os: r0/a1: 0x00000004 r1/a2: 0x0000076d r2/a3: 0x00000009 16:39:39:638 -> [00:00:00.537,719] <err> os: r3/a4: 0x20011080 r12/ip: 0x00000014 r14/lr: 0x0002628b 16:39:39:649 -> [00:00:00.537,719] <err> os: xpsr: 0x41000000 16:39:39:654 -> [00:00:00.537,750] <err> os: Faulting instruction address (r15/pc): 0x0003a4f0 16:39:39:659 -> [00:00:00.537,780] <err> os: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0 16:39:39:665 -> [00:00:00.537,811] <err> os: Current thread: 0x200137b0 (unknown) 16:39:39:675 -> [00:00:00.645,904] <err> fatal_error: Resetting system
I guess this is due to the modem trace lib in proj.conf, so I will comment these lines:
# # Modem trace # CONFIG_NRF_MODEM_LIB_TRACE=y # CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_UART=y # CONFIG_NRF_MODEM_LIB_TRACE_BACKEND_UART_ZEPHYR=y # CONFIG_UART_ASYNC_API=y # CONFIG_UART_1_ASYNC=y # CONFIG_UART_1_INTERRUPT_DRIVEN=n
But after this the device is not booting anymore. Serial is not working anymore and power consumption is stable so I guess it is locked in a loop at boot.
I am wondering if the connection manager is using the modem trace? What would be the best way to turn off the UART to lower the power consumption?
Thanks
