nRF52840 with MCUBoot NCS 2.6.0 fails to build
I've trying to build BLE and MCUBoot Bootloader for a nRF52840 board (Particle Xenon) from the nRF Connect sample "Peripheral LBS".
Without MCUBoot Bootloader, the nRF52840 board builds and runs as expected for BLE.
However, when I enable MCBOOT Bootloader,
CONFIG_BOOTLOADER_MCUBOOT=y
#Include MCUMGR and the dependencies in the build
CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
I get the errors below.
 *  Executing task: nRF Connect: Build: ble_peripheral_lbs/build (active)
Building ble_peripheral_lbs
west build --build-dir /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs
[0/1] Re-running CMake...
Loading Zephyr default modules (Zephyr base (cached)).
-- Application: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs
-- CMake version: 3.21.0
-- Cache files will be written to: /Users/quark11/Library/Caches/zephyr
-- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0/zephyr)
-- Board: particle_xenon
-- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk)
-- Found BOARD.dts: /opt/nordic/ncs/v2.6.0/zephyr/boards/arm/particle_xenon/particle_xenon.dts
-- Found devicetree overlay: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/boards/particle_xenon.overlay
-- Generated zephyr.dts: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/zephyr/dts.cmake
Parsing /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.6.0/zephyr/boards/arm/particle_xenon/particle_xenon_defconfig'
Merged configuration '/Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/prj.conf'
Configuration saved to '/Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/zephyr/.config'
Kconfig header saved to '/Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/zephyr/include/generated/autoconf.h'
-- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found version "3.9.6") found components: Interpreter
=== child image mcuboot -  begin ===
loading initial cache file /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/child_image_preload.cmake
-- Application: /opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr
-- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter
-- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found devicetree overlay: /opt/nordic/ncs/v2.6.0/nrf/modules/mcuboot/usb.overlay
-- Generated zephyr.dts: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/dts.cmake
Parsing /opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration '/opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration '/Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/.config'
Kconfig header saved to '/Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/include/generated/autoconf.h'
-- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
CMake Warning at /opt/nordic/ncs/v2.6.0/nrf/lib/flash_patch/CMakeLists.txt:8 (message):
        --- WARNING: To maintain the integrity of secure boot, ---
        --- enable CONFIG_DISABLE_FLASH_PATCH in production.   ---
-- Using ccache: /opt/nordic/ncs/toolchains/580e4ef81c/bin/ccache
CMake Warning at /opt/nordic/ncs/v2.6.0/zephyr/CMakeLists.txt:862 (message):
  No SOURCES given to Zephyr library: drivers__spi
  Excluding target from build.
MCUBoot bootloader key file: /opt/nordic/ncs/v2.6.0/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot
=== child image mcuboot -  end ===
CMake Warning at /opt/nordic/ncs/v2.6.0/nrf/modules/mcuboot/CMakeLists.txt:382 (message):
          --- WARNING: Using default MCUBoot key, it should not ---
          --- be used for production.                           ---
CMake Warning at /opt/nordic/ncs/v2.6.0/nrf/cmake/partition_manager.cmake:79 (message):
          --- WARNING: Using a bootloader without pm_static.yml.            ---
          --- There are cases where a deployed product can consist of       ---
          --- multiple images, and only a subset of these images can be     ---
          --- upgraded through a firmware update mechanism. In such cases,  ---
          --- the upgradable images must have partitions that are static    ---
          --- and are matching the partition map used by the bootloader     ---
          --- programmed onto the device.                                   ---
  /opt/nordic/ncs/v2.6.0/zephyr/cmake/modules/kernel.cmake:248 (include)
  /opt/nordic/ncs/v2.6.0/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
  /opt/nordic/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /opt/nordic/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
  CMakeLists.txt:8 (find_package)
-- Configuring done
-- Generating done
[1/187] Preparing syscall dependency handling
[4/187] Generating include/generated/version.h
-- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0/zephyr), build: v3.5.99-ncs1
[182/187] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/zephyr_pre0.map
: && ccache /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/libarch__arm__core.a  zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a  zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/libc/common/liblib__libc__common.a  zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a  zephyr/boards/boards/arm/particle_xenon/libboards__arm__particle_xenon.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m+fp/hard"  -L/Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -mfpu=fpv4-sp-d16  -mfloat-abi=hard  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  /opt/nordic/ncs/v2.6.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.19.a  /opt/nordic/ncs/v2.6.0/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cd /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake -E true
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj): in function `k_sleep':
/Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/include/generated/syscalls/kernel.h:135: undefined reference to `z_impl_k_sleep'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/include/generated/syscalls/kernel.h:135: undefined reference to `z_impl_k_sleep'
/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.rodata.spi_nor_config_0+0x0): undefined reference to `__device_dts_ord_101'
collect2: error: ld returned 1 exit status
[159/294] Building C object zephyr/subsys/mgmt/mcumgr/grp/img_mgmt/CMakeFiles/subsys__mgmt__mcumgr__grp__img_mgmt.dir/src/img_mgmt.c.obj
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/zephyr.hex /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot/zephyr/zephyr.elf
cd /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build/mcuboot && /opt/nordic/ncs/toolchains/580e4ef81c/Cellar/cmake/3.21.0/bin/cmake --build . --
[165/294] Building C object zephyr/subsys/mgmt/mcumgr/transport/CMakeFiles/subsys__mgmt__mcumgr__transport.dir/src/smp_bt.c.obj
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake --build /Users/quark11/Documents/2024_dfu_projects/ble_peripheral_lbs/build
 *  The terminal process terminated with exit code: 1.
Is this because I'm using a bootloader without a pm_static.yml file?
If so, Do I need to create a pm_static.yml with partitions info from the board’s devicetree overlay and add the yml file to the project?
What would the pm_static.yml  be for the devicetree overlay below?
Thank you.
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x00000000 0x0000C000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x00067000>;
		slot1_partition: partition@73000 {
			label = "image-1";
			reg = <0x00073000 0x00067000>;
		scratch_partition: partition@da000 {
			label = "image-scratch";
			reg = <0x000da000 0x0001e000>;
		 * The flash starting at 0x000f8000 and ending at
		 * 0x000fffff is reserved for use by the application.
		 * Storage partition will be used by FCB/LittleFS/NVS
		 * if enabled.
		storage_partition: partition@f8000 {
			label = "storage";
			reg = <0x000f8000 0x00008000>;
  • Hi Amanda,
    I've reviewed Sigurd's "mcuboot_52840dongle_overwrite" example and build it successfully without any changes under NCS 2.6.0.
    However, when I flash the "app_update.bin" onto the nrf52840dongle using mcumgr, the application fails to run and I don't get any serial port enumerated.
    In the example, nrf52840dongle_nrf52840.dts has console configured for cdc_acm_uart (versus uart0 in the Zephyr dts for the board).
    I'm using a nRF52840dongle that has nRF Bootloader and also MCUBoot. The dongle is booted into MCUboot serial recovery mode by plugging the board in with the SW1 button pressed down. Prior to flashing, I've confirmed that serial port "MCUBOOT" gets enumerated on the dongle.
    I've flashed the generated signed "app_update.bin" to the MCUboot serial port using mcumgr.
    Are the steps used for MCUBoot serial recovery mode flashing correct?
    quark11:mcuboot_52840dongle_overwrite quark11$ mcumgr --conntype=serial --connstring='dev=/dev/cu.usbmodem14101,baud=115200' image upload -e /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/zephyr/app_update.bin
     39.32 KiB / 39.32 KiB [========================================================================================] 100.00% 1.89 KiB/s 20s
    Done
    quark11:mcuboot_52840dongle_overwrite quark11$ mcumgr --conntype=serial --connstring='dev=/dev/cu.usbmodem14101,baud=115200' reset
    Done
    *  Executing task: nRF Connect: Generate config nrf52840dongle_nrf52840 for mcuboot_52840dongle_overwrite
    Building mcuboot_52840dongle_overwrite
    west build --build-dir /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite --pristine --board nrf52840dongle_nrf52840 --no-sysbuild --cmake-only -- -DNCS_TOOLCHAIN_VERSION=NONE
    -- Application: /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite
    -- Board: nrf52840dongle_nrf52840
    -- Found BOARD.dts: /opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840.dts
    -- Generated zephyr.dts: /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/zephyr/dts.cmake
    Parsing /opt/nordic/ncs/v2.6.0/zephyr/Kconfig
    Loaded configuration '/opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840_defconfig'
    Merged configuration '/Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/prj.conf'
    Configuration saved to '/Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/zephyr/.config'
    Kconfig header saved to '/Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/zephyr/include/generated/autoconf.h'
    CMake Warning at /opt/nordic/ncs/v2.6.0/zephyr/subsys/usb/device/CMakeLists.txt:22 (message):
      CONFIG_USB_DEVICE_VID has default value 0x2FE3.
      This value is only for testing and MUST be configured for USB products.
    CMake Warning at /opt/nordic/ncs/v2.6.0/zephyr/subsys/usb/device/CMakeLists.txt:28 (message):
      CONFIG_USB_DEVICE_PID has default value 0x100.
    loading initial cache file /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/mcuboot/child_image_preload.cmake
    -- Generated zephyr.dts: /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/mcuboot/zephyr/dts.cmake
    warning: HW_STACK_PROTECTION (defined at arch/Kconfig:259) was assigned the value 'y' but got the
    value 'n'. Check these unsatisfied dependencies: ARCH_HAS_STACK_PROTECTION (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_HW_STACK_PROTECTION and/or look up
    HW_STACK_PROTECTION in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: LOG_DEFAULT_LEVEL (defined at subsys/logging/Kconfig.filtering:13) was assigned the value
    '0' but got the value ''. Check these unsatisfied dependencies: LOG (=n). See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_DEFAULT_LEVEL and/or look up
    LOG_DEFAULT_LEVEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: USB_COMPOSITE_DEVICE (defined at subsys/usb/device/Kconfig:51) was assigned the value 'n'
    but got the value 'y'. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_USB_COMPOSITE_DEVICE and/or look up
    USB_COMPOSITE_DEVICE in the menuconfig/guiconfig interface. The Application Development Primer,
    helpful too.
    warning: The choice symbol MCUBOOT_LOG_LEVEL_INF (defined at
    subsys/logging/Kconfig.template.log_config:17) was selected (set =y), but no symbol ended up as the
    choice selection. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_MCUBOOT_LOG_LEVEL_INF
    and/or look up MCUBOOT_LOG_LEVEL_INF in the menuconfig/guiconfig interface. The Application
    Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of
    the manual might be helpful too.
    warning: The choice symbol LOG_MODE_MINIMAL (defined at subsys/logging/Kconfig.mode:28) was selected
    (set =y), but no symbol ended up as the choice selection. See
    http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_MODE_MINIMAL and/or look up
    LOG_MODE_MINIMAL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    Merged configuration '/opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr/boards/nrf52840dongle_nrf52840.conf'
    Merged configuration '/Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/child_image/mcuboot.conf'
    Merged configuration '/Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to '/Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/mcuboot/zephyr/.config'
    Kconfig header saved to '/Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/mcuboot/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /Users/quark11/Documents/2024_dfu_projects/mcuboot_52840dongle_overwrite/build_nrf52dongle/mcuboot
      /opt/nordic/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:5 (find_package)
    -- Configuring done
    -- Generating done
     *  Executing task: nRF Connect: Build: mcuboot_52840dongle_overwrite/build_nrf52dongle (active)
    [1/172] Preparing syscall dependency handling
    [1/206] Preparing syscall dependency handling
    [4/206] Generating include/generated/version.h
    [206/206] Linking C executable zephyr/zephyr.elf
               FLASH:       48100 B        64 KB     73.39%
                 RAM:       29464 B       256 KB     11.24%
            IDT_LIST:          0 GB        32 KB      0.00%
    [8/172] Generating include/generated/version.h
    [161/172] Linking C executable zephyr/zephyr.elf
               FLASH:       39600 B     982528 B      4.03%
                 RAM:       16640 B       256 KB      6.35%
    [167/172] Generating ../../zephyr/app_update.bin
    image.py: sign the payload
    [168/172] Generating ../../zephyr/app_signed.hex
    [170/172] Generating ../../zephyr/app_test_update.hex
    [172/172] Generating zephyr/merged.hex
    Sorry for the mislead. My colleague said he hadn't done the work. Now he added the disclaimer.
    The dongle docs has this section on Option 2: Using MCUboot in Serial Recovery Mode
    It does both nRF5 bootloader and MCUboot though, so it's not optimal. However, it should work.
    Amanda H.
  • Hi Amanda,
    Yesterday, I was able to flash & run the signed "app_update.bin" onto the nrf52840dongle using mcumgr for the "mcuboot_52840dongle_overwrite" example and for the "blinky" & "button" examples from "zephyr/samples/basic".
    The problem was that I had MCUBoot generated from a different Zephyr repo (Zephyr 3.6.0). I had to recompile and flash the MCUBoot from NCS 2.6.0 repo. I guess there was a signature mismatch and the applications failed to execute.
    However, I still have an issue
    running successfully a BLE version of "peripheral_lbs" but another project of mine that was originally derived off the "peripheral_lbs"  runs fine.
    Also, another OpenThread Joiner application built within NCS for VSCode doesn't run either.
    Currently I don't know why a few of these applications fail to execute properly. So, I need to dig further.  Any suggestions what may be the reason?
    All of the above applications run fine when targeted for Particle Xenon (nRF52840) and Thingy53 with MCUBoot. They also run fine when I package the applications for the nRF5 Bootloader on the nRF52840Dongle and flash with nrfutil.
    I'd like to get the OpenThread Joiner to run successfully on a nRF52840Dongle with MCUBoot, as I'm planning to use quite a few of the these for an OpenThread network. At the moment, the fallback appears to use the nRF5 Bootloader.
    Thank you for your assistance and providing the link to the bootloader samples. It proved to be useful.
    A few questions regarding MCUBoot bootlaoder
       - How to get into the MCUBoot mode via sw0 & reset?
       - Can the MCUBoot Bootloader be configured as an UF2 Bootloader?
    I'll mark this response as the suggested answer for my ticket. Thank you.
    Ravi
    Pressing RESET will run the Nordic bootloader with the default setting on nRF52840Dongle unless you erase the nRF5 bootloader. however, I won't suggest doing that.
    UF2 Bootloader is not provided by us (NordicSemi), and I don't know how to configure to UF2 bootloader. You can seek help at https://forums.adafruit.com/
    -Amanda H.
