I have the task to integrate MCUboot in a project that will be deployed on a nrf5340. I've enabled MCUboot using KKonfig option `CONFIG_BOOTLOADER_MCUBOOT`. According to this documentation https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/config_and_build/multi_image.html#ug-multi-image-add-child-image-oot I should have added MCUboot also as child image to the CMake configuration. However, this leads to errors when running CMake:
add_custom_target cannot create target "mcuboot_shared_property_target" because another target with the same name already exists.
So I guess, this isn't required anymore in the current version of the SDK, right?
Am I'm right, that `CONFIG_SECURE_BOOT` is not an option meant for MCUboot, but would enable the "Nordic Bootloader"?
According to the MCUBoot / Zephyr documentation, I should provide `boot_partition`, `slot0_partition`, and `slot1_partition` as partitions. However, if I use this as a first version of a partition layout (pm_static.yml):
boot_partition: address: 0x0 size: 0xD000 region: flash_primary slot0_partition: address: 0xD000 size: 0x100000 region: flash_primary slot1_partition: address: 0x10D000 size: 0x100000 region: flash_primary
I get this partitioning (make partition_manager_report):
flash_primary (0x21c200 - 2160kB):
| 0x0: boot_partition (0xd000 - 52kB) |
| 0xd000: slot0_partition (0x100000 - 1024kB) |
| 0x10d000: slot1_partition (0x100000 - 1024kB) |
| 0x20d000: mcuboot (0xc000 - 48kB) |
| 0x219000: EMPTY_0 (0x3000 - 12kB) |
+---0x21c000: mcuboot_primary (0x200 - 512B)--------------+
| 0x21c000: mcuboot_pad (0x200 - 512B) |
+---0x21c200: mcuboot_primary_app (-0x11c200 - -1163776B)-+
| 0x21c200: app (-0x11c200 - -1163776B) |
So, what are the exact names of the partitions that I have to define, to have a partition for MCUboot, the application and a firmware update?
There are some options to configure MCUBoot itself. For example `MCUBOOT_VALIDATE_PRIMARY_SLOT`, which is also mentioned in the Nordic-Zephry documentation. Where does this configurations have to be applied? Are they CMake cache variables or are they KKonfig options?
thanks in advance and best regards
Torsten
