Serial lTE Modem example: FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\Users\NTMK1\Documents\Project\Apps\serial_lte_modem\build'
I am trying to build the Serial lTE Modem example from SDK directory C:\ncs\v2.5.1\nrf\applications\serial_lte_modem in VScode then resulting the error:
-- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.5.1/zephyr/.cache
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/tfm
[17/405] No configure step for 'tfm'
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
cmd.exe /C "cd /D C:\Users\NTMK1\Documents\GunfireTracker\Apps\serial_lte_modem\build\mcuboot && C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.exe --build . --"
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\Users\NTMK1\Documents\GunfireTracker\Apps\serial_lte_modem\build'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
However, I tried different application such as tfm_hello_world and was the same I got the error:
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\Users\NTMK1\Documents\GunfireTracker\Apps\tfm_hello_world\build'
My SDK version is v2.5.1.
Does any software environment setup or cmake configuration being wrong?
    I'm not able to reproduce the issue. Could you please provide the output from the command nRF Connect: Generate support information? This can be triggered from the VS Code command palette.
    My initial concern is the path of the example folder. Could you test with e.g. C:\ncs\Apps\serial_lte_modem\ ?
    Øyvind
  • This project build is based on creating a new project via copying the sample from C:/ncs/Apps/serial_lte_modem/ in VScode.
    The complete build message from the terminal shown below.
    Please diagnose the issues as much as you can:
    Executing task: nRF Connect: Generate config nrf9160dk_nrf9160_ns for c:\Users\NTMK1\Documents\GunfireTracker\Apps\serial_lte_modem
    Building serial_lte_modem
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem --pristine --board nrf9160dk_nrf9160_ns --no-sysbuild --cmake-only -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DCONFIG_CORTEX_M_DEBUG_MONITOR_HOOK=y -DCONFIG_SEGGER_DEBUGMON=y -DEXTRA_DTC_OVERLAY_FILE=boards/nrf9160dk_nrf9160_ns.overlay -DBOARD_ROOT=c:/users/ntmk1/documents/gunfiretracker/apps/serial_lte_modem -Dmcuboot_OVERLAY_CONFIG=C:/ncs/v2.5.1/nrf/modules/mcuboot/tfm.conf;C:/ncs/v2.5.1/nrf/modules/mcuboot/fih_low_enable.conf;C:/ncs/v2.5.1/nrf/subsys/partition_manager/partition_manager_enabled.conf;C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/child_image/mcuboot.conf -DCACHED_CONF_FILE=c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/prj.conf;c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/boards/nrf9160dk_nrf9160_ns.conf"
    -- Application: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem
    -- CMake version: 3.20.5
    -- Zephyr version: 3.4.99 (C:/ncs/v2.5.1/zephyr)
    -- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
    -- Board: nrf9160dk_nrf9160_ns, Revision: 0.14.0
    -- Found host-tools: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/c57af46cb7/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v2.5.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
    -- Found devicetree overlay: C:/ncs/v2.5.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_0_14_0.overlay
    -- Found devicetree overlay: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/boards/nrf9160dk_nrf9160_ns.overlay
    -- Found devicetree overlay: boards/nrf9160dk_nrf9160_ns.overlay
    -- Generated zephyr.dts: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/zephyr/dts.cmake
    warning: Experimental symbol TFTP_LIB is enabled.
    warning: Experimental symbol HTTP_CLIENT is enabled.
    Parsing C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/Kconfig
    Loaded configuration 'C:/ncs/v2.5.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
    Merged configuration 'c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/prj.conf'
    Merged configuration 'c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/boards/nrf9160dk_nrf9160_ns.conf'
    Merged configuration 'C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/zephyr/.config'
    Kconfig header saved to 'C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    Changed board to secure nrf9160dk_nrf9160 (NOT NS)
    === child image mcuboot - begin ===
    loading initial cache file C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot/child_image_preload.cmake
    -- Application: C:/ncs/v2.5.1/bootloader/mcuboot/boot/zephyr
    -- Board: nrf9160dk_nrf9160, Revision: 0.14.0
    -- Found BOARD.dts: C:/ncs/v2.5.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
    -- Found devicetree overlay: C:/ncs/v2.5.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_0_14_0.overlay
    -- Found devicetree overlay: C:/ncs/v2.5.1/bootloader/mcuboot/boot/zephyr/app.overlay
    -- Generated zephyr.dts: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot/zephyr/dts.cmake
    Parsing C:/ncs/v2.5.1/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.5.1/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
    Merged configuration 'C:/ncs/v2.5.1/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/ncs/v2.5.1/nrf/modules/mcuboot/tfm.conf'
    Merged configuration 'C:/ncs/v2.5.1/nrf/modules/mcuboot/fih_low_enable.conf'
    Merged configuration 'C:/ncs/v2.5.1/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration 'C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/child_image/mcuboot.conf'
    Merged configuration 'C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot/zephyr/include/generated/autoconf.h'
    CMake Warning at C:/ncs/v2.5.1/zephyr/CMakeLists.txt:893 (message):
    No SOURCES given to Zephyr library: drivers__console
    Excluding target from build.
    MCUBoot bootloader key file: C:/ncs/v2.5.1/bootloader/mcuboot/root-ec-p256.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot
    === child image mcuboot - end ===
    CMake Warning at C:/ncs/v2.5.1/nrf/modules/mcuboot/CMakeLists.txt:320 (message):
    --- WARNING: Using default MCUBoot key, it should not ---
    --- be used for production. ---
    CMake Warning at C:/ncs/v2.5.1/nrf/cmake/partition_manager.cmake:79 (message):
    --- WARNING: Using a bootloader without pm_static.yml. ---
    --- There are cases where a deployed product can consist of ---
    --- multiple images, and only a subset of these images can be ---
    --- upgraded through a firmware update mechanism. In such cases, ---
    --- the upgradable images must have partitions that are static ---
    --- and are matching the partition map used by the bootloader ---
    --- programmed onto the device. ---
    C:/ncs/v2.5.1/zephyr/cmake/modules/kernel.cmake:247 (include)
    C:/ncs/v2.5.1/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
    C:/ncs/v2.5.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
    C:/ncs/v2.5.1/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    CMakeLists.txt:9 (find_package)
    Dropping partition 'nrf_modem_lib_trace' since its size is 0.
    -- Configuring done
    -- Generating done
    * Executing task: nRF Connect: Generate config nrf9160dk_nrf9160_ns for c:\Users\NTMK1\Documents\GunfireTracker\Apps\serial_lte_modem
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem --pristine --board nrf9160dk_nrf9160_ns --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DCONFIG_CORTEX_M_DEBUG_MONITOR_HOOK=y -DCONFIG_SEGGER_DEBUGMON=y -DBOARD_ROOT=c:/users/ntmk1/documents/gunfiretracker/apps/serial_lte_modem"
    Merged configuration 'C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/prj.conf'
    Merged configuration 'C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/boards/nrf9160dk_nrf9160_ns.conf'
    -- Configuring done
    -- Generating done
    -- Configuring done
    -- Generating done
    [2/405] Generating include/generated/version.h
    -- Zephyr version: 3.4.99 (C:/ncs/v2.5.1/zephyr), build: v3.4.99-ncs1-1
    [3/178] Generating include/generated/version.h
    [173/178] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf -fuse-ld=bfd -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/boards/boards/arm/nrf9160dk_nrf9160/libboards__arm__nrf9160dk_nrf9160.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main+fp/hard" -LC:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie C:/ncs/v2.5.1/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_platform_0.9.18.a C:/ncs/v2.5.1/nrfxlib/crypto/nrf_cc310_bl/lib/cortex-m33/hard-float/no-interrupts/libnrf_cc310_bl_0.9.12.a && cmd.exe /C "cd /D C:\Users\NTMK1\Documents\GunfireTracker\Apps\serial_lte_modem\build\mcuboot\zephyr && C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.exe -E true""
    'cmd.exe' is not recognized as an internal or external command,
    operable program or batch file.
    [12/405] Generating ../../tfm/CMakeCache.txt
    CMake Warning at cmake/version.cmake:22 (message):
    Actual TF-M version is not available from Git repository. Settled to
    v1.8.0
    CMakeLists.txt:22 (include)
    -- Found Git: C:/ncs/toolchains/c57af46cb7/mingw64/bin/git.exe (found version "2.37.3.windows.1")
    CMake Deprecation Warning at C:/ncs/v2.5.1/zephyr/cmake/modules/FindDeprecated.cmake:121 (message):
    'PYTHON_PREFER' variable is deprecated. Please use Python3_EXECUTABLE
    instead.
    C:/ncs/v2.5.1/zephyr/cmake/modules/python.cmake:16 (find_package)
    C:/ncs/v2.5.1/zephyr/cmake/modules/user_cache.cmake:30 (include)
    C:/ncs/v2.5.1/zephyr/cmake/modules/extensions.cmake:5 (include)
    C:/ncs/v2.5.1/nrf/subsys/nrf_security/tfm/CMakeLists.txt:36 (include)
    -- Configuring done
    -- Generating done
    Could you please elaborate more on how you are copying this sample? The path does not correspond with the correct path to where serial_lte_modem application resides. You should copy, or create a new application from the application found under C:\ncs\v2.5.1\nrf\applications\serial_lte_modem
    This is the build logs, can you please provide the support information from VS code command palette (CTRL+SHIFT+P)?
    Øyvind
  • Here is it!
    [21:16:28] Update available nsscprodmedia.blob.core.windows.net/.../nrf-command-line-tools-10.24.1-x64.exe
    [21:22:39] cmd.exe /d /s /c "west build --build-dir c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem --pristine --board nrf9160dk_nrf9160_ns --no-sysbuild --cmake-only -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DCONFIG_CORTEX_M_DEBUG_MONITOR_HOOK=y -DCONFIG_SEGGER_DEBUGMON=y -DEXTRA_DTC_OVERLAY_FILE=boards/nrf9160dk_nrf9160_ns.overlay -DBOARD_ROOT=c:/users/ntmk1/documents/gunfiretracker/apps/serial_lte_modem -Dmcuboot_OVERLAY_CONFIG=C:/ncs/v2.5.1/nrf/modules/mcuboot/tfm.conf;C:/ncs/v2.5.1/nrf/modules/mcuboot/fih_low_enable.conf;C:/ncs/v2.5.1/nrf/subsys/partition_manager/partition_manager_enabled.conf;C:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/child_image/mcuboot.conf -DCACHED_CONF_FILE=c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/prj.conf;c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/boards/nrf9160dk_nrf9160_ns.conf"
    [21:22:39] =========== Toolchain validation report for nRF Connect SDK Toolchain v2.5.1 ===========
    Package Using the nRF Connect SDK v2.5.1 at c:\ncs\v2.5.1
    No issues were detected with the toolchain.
    [21:23:52] Success.
    [21:27:44] cmd.exe /d /s /c "west build --build-dir c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem/build c:/Users/NTMK1/Documents/GunfireTracker/Apps/serial_lte_modem --pristine --board nrf9160dk_nrf9160_ns --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DCONFIG_CORTEX_M_DEBUG_MONITOR_HOOK=y -DCONFIG_SEGGER_DEBUGMON=y -DBOARD_ROOT=c:/users/ntmk1/documents/gunfiretracker/apps/serial_lte_modem"
    [21:29:25] Failure (code 1).
    [11:48:46] nrfutil-device --json device-info --serial-number 000960071349 --skip-overhead
    [11:48:49] Success.
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.19045",
        "vscode": "1.87.2",
        "electron": "27.3.2",
        "node": "v18.17.1"
      "system": {
        "date": "2024-04-04T11:01:19.100Z",
        "vscodeRoot": "c:\\Users\\NTMK1\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "38:45:06",
        "osUptime": "46:16:51",
        "cpu": "Intel(R) Core(TM) i3-8100 CPU @ 3.60GHz"
      "workspace": {
        "name": "serial_lte_modem (Workspace)",
        "workspaceFile": "c:\\Users\\NTMK1\\Documents\\GunfireTracker\\Apps\\serial_lte_modem\\serial_lte_modem.code-workspace",
        "folders": [
          "c:\\Users\\NTMK1\\Documents\\GunfireTracker\\Apps\\serial_lte_modem"
      "sdks": [
          "version": "v2.5.1",
          "path": "c:\\ncs\\v2.5.1"
      "activeBuild": "c:\\Users\\NTMK1\\Documents\\GunfireTracker\\Apps\\serial_lte_modem\\build",
      "apps": [
          "workspace": "c:\\Users\\NTMK1\\Documents\\GunfireTracker\\Apps\\serial_lte_modem",
          "uri": "c:\\Users\\NTMK1\\Documents\\GunfireTracker\\Apps\\serial_lte_modem",
          "buildConfigurations": [
              "id": "c:\\Users\\NTMK1\\Documents\\GunfireTracker\\Apps\\serial_lte_modem\\build",
              "name": "build",
              "boardId": "nrf9160dk_nrf9160_ns",
              "type": "Zephyr",
              "isChild": false,
              "isStale": false,
              "taskBindings": {
                "build": [],
                "pristineBuild": [],
                "flash": [],
                "eraseAndFlash": []
      "topdir": "c:\\ncs\\v2.5.1",
      "workspaceState": "freestanding-ready",
      "toolchains": [
          "version": "2.5.1",
          "path": "c:\\ncs\\toolchains\\c57af46cb7"
      "connectedDevices": [
          "serialNumber": "000960071349",
          "boardVersion": "PCA10090",
          "deviceFamily": "NRF91_FAMILY",
          "deviceVersion": "NRF9160_xxAA_REV2",
          "jlinkObFirmwareVersion": "J-Link OB-K22-NordicSemi compiled Oct 30 2023 12:12:53"
      "deviceProvider": "nrfutil",
      "tools": {
        "zephyr-sdk": "Not found",
        "C:\\Program Files\\SEGGER\\JLink_V794e\\JLink.exe": "7.94e",
        "nrfjprog": "Not found",
        "nrfutil": "Not found",
        "cmake": "Not found",
        "west": "Not found",
        "python": "Not found",
        "ninja": "Not found",
        "gperf": "Not found",
        "dtc": "Not found",
        "gn": "Not found",
        "git": "Not found",
        "gdbPath": "c:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.0.0",
          "binPath": "c:\\Users\\NTMK1\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.3.25-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device"
        "nrfutil-toolchain-manager": {
          "version": "0.14.1",
          "binPath": "c:\\Users\\NTMK1\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.3.25-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
      "environment": {
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\NTMK1",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\NTMK1",
          "PATH": "C:\\ncs\\toolchains\\c57af46cb7;C:\\ncs\\toolchains\\c57af46cb7\\mingw64\\bin;C:\\ncs\\toolchains\\c57af46cb7\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\c57af46cb7\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\Users\\NTMK1\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.3.25-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;C:\\Users\\NTMK1\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\Common Files\\InstallShield\\;C:\\Users\\NTMK1\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;",
          "ZEPHYR_BASE": "c:\\ncs\\v2.5.1\\zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk",
          "PYTHONPATH": "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Lib;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Lib\\site-packages"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;C:\\Users\\NTMK1\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\Common Files\\InstallShield\\;C:\\Users\\NTMK1\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;",
          "PATH": "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin;C:\\Users\\NTMK1\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\Common Files\\InstallShield\\;C:\\Users\\NTMK1\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;"
        "toolchainPath": "c:\\ncs\\toolchains\\c57af46cb7",
        "toolchainBinPath": "c:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
        "toolchainVersion": "2.5.1"
      "terminal": {
        "defaultProfile": null
      "config": {
          "topdir": "",
          "toolchain": {
            "path": ""
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig"
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "buildTerminal": {
            "condensedProgress": true
          "debugging": {
            "flash": true,
            "bindings": {
              "${workspaceFolder}/build": "Launch build"
            "justMyCode": true
          "deviceProvider": "",
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": true,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": null
          "nrfutil": {
            "home": null
          "defaultOpenAction": "ask"
          "terminalMode": "character"
      "extensions": {
        "internal": {
            "version": "2024.3.25",
            "path": "c:\\Users\\NTMK1\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.3.25-win32-x64",
            "isActive": true
            "version": "2024.3.15",
            "path": "c:\\Users\\NTMK1\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.3.15",
            "isActive": true
            "version": "2024.3.78",
            "path": "c:\\Users\\NTMK1\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2024.3.78",
            "isActive": true
            "version": "2024.3.21",
            "path": "c:\\Users\\NTMK1\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2024.3.21",
            "isActive": true
        "external": {
          "marus25.cortex-debug": null,
          "ms-vscode.cpptools": "1.20.0",
          "ms-vscode.js-debug": "1.87.0",
          "ms-vscode.js-debug-companion": "1.1.2",
          "ms-vscode.vscode-js-profile-table": "1.0.8",
          "ms-vscode.cmake-tools": "1.17.17",
          "ms-vscode.hexeditor": "1.9.14",
          "twxs.cmake": "0.0.17"
  • Hello, and thanks for providing these details. There seems to be an issue with your installation.
    Here is the paths from you support information:
      "tools": {
        "dtc": "Not found",
        "gn": "Not found",
        "git": "Not found",
    Here is mine:
      "connectedDevices": [],
      "tools": {
        "C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.1",
        "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.23.4",
        "C:\\ncs\\nrfutil.exe": "7.6.0",
        "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\cmake.exe": "3.20.5",
        "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Scripts\\west.exe": "1.1.0",
        "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\python.exe": "3.8.2",
        "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\ninja.exe": "1.9.0",
        "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\gperf.exe": "3.1",
        "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\dtc.exe": "1.4.7",
        "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\gn.exe": "2122",
        "C:\\ncs\\toolchains\\c57af46cb7\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    Have you installed the nRF Command Line Tools desktop tool on you computer?
