SDK 2.6.0 cmake error: CONFIG_BT_RPMSG has been renamed to CONFIG_BT_HCI_IPC
Just upgraded to NRF v 2.6.0 (Mac OS; VS Code). Our code previous built and ran successfully on our custom board with v 2.5.0 of the SDK.
Now we get the following error which breaks the build process, and it is unclear how to resolve it (e.g. setting CONFIG_BT_RPMSG=n in prj.conf just produces a different error).
CMake Error at /opt/nordic/ncs/v2.6.0/zephyr/drivers/bluetooth/hci/CMakeLists.txt:5 (message):
Kindly advise. Thanks! Dan.
    Due to the Easter holidays in Norway, we are less staffed than usual. You can expect a delayed answer.
    The HCI implementation for both the Host and the Controller sides has been renamed for the IPC transport. The CONFIG_BT_RPMSG Kconfig option is now CONFIG_BT_HCI_IPC, and the zephyr,bt-hci-rpmsg-ipc Devicetree chosen is now zephyr,bt-hci-ipc. The existing sample has also been renamed, from samples/bluetooth/hci_rpmsg to samples/bluetooth/hci_ipc. (GitHub #64391)
    See the https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/zephyr/releases/migration-guide-3.6.html#bluetooth
    Amanda H.
  • Hi Amanda - yes - I saw that, but it's not clear to me how to fix it so it can build. I am not setting these configs anywhere in my code - they are getting included upstream (our application is a Matter application) and I don't know where/what I should change to make it build. What do you recommend?
  • Could you share the complete log via Insert -> code?
  • Hi Amanda - here is the build log:
    Building wb
    west build --build-dir /Users/ydr/dev/nordic/wb/build_2.6.0 /Users/ydr/dev/nordic/wb --pristine --board wb_nrf5340_cpuapp --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=/Users/ydr/dev/nordic;/Users/ydr/dev/nordic/wb -DCACHED_CONF_FILE=/Users/ydr/dev/nordic/wb/prj.conf -DDTC_OVERLAY_FILE=/Users/ydr/dev/nordic/wb/boards/wb_nrf5340_cpuapp.overlay
    -- Application: /Users/ydr/dev/nordic/wb
    -- CMake version: 3.21.0
    -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /Users/ydr/Library/Caches/zephyr
    -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0/zephyr)
    -- Board: wb_nrf5340_cpuapp
    -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /Users/ydr/dev/nordic/boards/arm/wb_nrf5340/wb_nrf5340_cpuapp.dts
    -- Found devicetree overlay: /Users/ydr/dev/nordic/wb/boards/wb_nrf5340_cpuapp.overlay
    -- Generated zephyr.dts: /Users/ydr/dev/nordic/wb/build_2.6.0/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/ydr/dev/nordic/wb/build_2.6.0/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/ydr/dev/nordic/wb/build_2.6.0/zephyr/dts.cmake
    warning: Experimental symbol COAP_SERVER is enabled.
    Parsing /Users/ydr/dev/nordic/wb/Kconfig
    Loaded configuration '/Users/ydr/dev/nordic/boards/arm/wb_nrf5340/wb_nrf5340_cpuapp_defconfig'
    Merged configuration '/Users/ydr/dev/nordic/wb/prj.conf'
    Configuration saved to '/Users/ydr/dev/nordic/wb/build_2.6.0/zephyr/.config'
    Kconfig header saved to '/Users/ydr/dev/nordic/wb/build_2.6.0/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    See also "/Users/ydr/dev/nordic/wb/build_2.6.0/CMakeFiles/CMakeOutput.log".
    See also "/Users/ydr/dev/nordic/wb/build_2.6.0/CMakeFiles/CMakeError.log".
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 -B/Users/ydr/dev/nordic/wb/build_2.6.0 -GNinja -DBOARD=wb_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION=NONE '-DBOARD_ROOT=/Users/ydr/dev/nordic;/Users/ydr/dev/nordic/wb' -DCACHED_CONF_FILE=/Users/ydr/dev/nordic/wb/prj.conf -DDTC_OVERLAY_FILE=/Users/ydr/dev/nordic/wb/boards/wb_nrf5340_cpuapp.overlay -S/Users/ydr/dev/nordic/wb
     *  The terminal process terminated with exit code: 1.
    Thanks! Dan,
  • Hi Dan, I'm facing the same problem,
    I believe you are using the board definitions from a previous sdk (eg some sdk example)
    looks on the new Kconfig.defconfig
    you may want to update to new board definitions
    ncs/v2.6.0/zephyr/boards/arm/*
