Extended Connection Events while using Coded PHY as a central?
Does the SoftDevice (using NCS v2.5.0) support Extended Connection Events while using the Coded PHY as a central?
I implemented the following in my main.c after calling bt_enable() on both the central and the peripheral (it's a closed system).
	sdc_hci_cmd_vs_conn_event_extend_t conn_evt_ext = {
		.enable = true
	sdc_hci_cmd_vs_conn_event_extend(&conn_evt_ext);
However, the sniffer capture shows that the connection event is not extended even though the More Data bit is set.  See below.  The connection interval is set to 30 ms.
