https://devzone.nordicsemi.com/f/nordic-q-a/44658/communication-probl
I want to change the code provided in this link to enter the password from the peripheral
You need to swap their IO capabilities:
So that the peripheral has the display, and the central has the keyboard. Then you need to set up the events that displays and enters the key on the other devices. I think it should be pretty straight forward.
best regards,
Edvin
Thank you for your help. Now I can enter the password from the peripheral. But I also want this paring process to be controlled because right now it's automatic pairing and bonding as soon as I power it up. I want the paring process to start when I type "PAIR" in the serial debugging Assistant.Here's my code.
* Copyright (c) 2016 - 2021, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
///////////Added for bonding//////////
#include "peer_manager.h"
#include "peer_manager_handler.h"
#define SEC_PARAM_BOND 1 /**< Perform bonding. */
#define SEC_PARAM_MITM 1 /**< Enable MITM protection */
#define SEC_PARAM_LESC 0 /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS 0 /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_DISPLAY_ONLY /**< Display Only. */ // -Shy
#define SEC_PARAM_OOB 0 /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE 7 /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE 16 /**< Maximum encryption key size. */
//////////////Added for bonding///////
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO 3 /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA 1 /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE Nordic UART Service (NUS) client instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
NRF_BLE_GQ_DEF(m_ble_gatt_queue, /**< BLE GATT Queue instance. */
NRF_SDH_BLE_CENTRAL_LINK_COUNT,
NRF_BLE_GQ_QUEUE_SIZE);
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief NUS UUID. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_NUS_SERVICE,
.type = NUS_SERVICE_UUID_TYPE
////////////Added for bonding///////////
// Static passkey
#define STATIC_PASSKEY "123456"
// static ble_opt_t m_static_pin_option;
uint8_t passkey[] = STATIC_PASSKEY;
static void scan_start(bool erase_bonds);
/**@brief Function for handling asserts in the SoftDevice.
* @details This function is called in case of an assert in the SoftDevice.
* @warning This handler is only an example and is not meant for the final product. You need to analyze
* how your product is supposed to react in case of assert.
* @param[in] line_num Line number of the failing assert call.
* @param[in] p_file_name File name of the failing assert call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling the Nordic UART Service Client errors.
* @param[in] nrf_error Error code containing information about what went wrong.
static void nus_error_handler(uint32_t nrf_error)
APP_ERROR_HANDLER(nrf_error);
////////////Added for bonding//////////////
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void) // -Shy
ret_code_t err_code;
NRF_LOG_INFO("Erase bonds");
err_code = pm_peers_delete();
///**@brief Function to start scanning. */
//static void scan_start(void)
// ret_code_t ret;
// ret = nrf_ble_scan_start(&m_scan);
// APP_ERROR_CHECK(ret);
// ret = bsp_indication_set(BSP_INDICATE_SCANNING);
static void scan_start(bool erase_bonds) // -Shy
ret_code_t ret;
if (erase_bonds == true)
delete_bonds();
// Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
} break;
case NRF_BLE_SCAN_EVT_CONNECTED:
ble_gap_evt_connected_t const * p_connected =
p_scan_evt->params.connected.p_connected;
// Scan is automatically stopped by the connection.
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_connected->peer_addr.addr[0],
p_connected->peer_addr.addr[1],
p_connected->peer_addr.addr[2],
p_connected->peer_addr.addr[3],
p_connected->peer_addr.addr[4],
p_connected->peer_addr.addr[5]
} break;
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("Scan timed out.");
scan_start(false);
} break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
/**@brief Function for handling database discovery events.
* @details This function is a callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function forwards the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service (NUS).
* @details This function takes a list of characters of length data_len and prints the characters out on UART.
* If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
ret_code_t ret_val;
NRF_LOG_DEBUG("Receiving data.");
NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
for (uint32_t i = 0; i < data_len; i++)
do
ret_val = app_uart_put(p_data[i]);
if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_BUSY);
if (p_data[data_len-1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
if (ECHOBACK_BLE_UART_DATA)
// Send data back to the peripheral.
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
/**@brief Function for handling app_uart events.
* @details This function receives a single character from the app_uart module and appends it to
* a string. The string is sent over BLE when the last character received is a
* 'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
static uint16_t index = 0;
uint32_t ret_val;
switch (p_event->evt_type)
/**@snippet [Handling data from UART] */
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= (m_ble_nus_max_data_len)))
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
} while (ret_val == NRF_ERROR_RESOURCES);
index = 0;
NRF_LOG_ERROR("Communication error occurred while handling UART.");
case APP_UART_FIFO_ERROR:
NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
* @details This function is called to notify the application of NUS client events.
* @param[in] p_ble_nus_c NUS client handle. This identifies the NUS client.
* @param[in] p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
case BLE_NUS_C_EVT_NUS_TX_EVT:
ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start(false);
* @brief Function for handling shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
// Prepare wakeup buttons.
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_CONNECTED:
err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
// /////////Add for bonding///////////
// /** 唤起配对请求*/
// ble_gap_sec_params_t sec_params_auth;
// sd_ble_gap_authenticate(p_ble_evt->evt.gap_evt.conn_handle,&sec_params_auth);
NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
p_gap_evt->conn_handle,
p_gap_evt->params.disconnected.reason);
case BLE_GAP_EVT_TIMEOUT:
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
/////////Remove for bonding///////////
/* case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
// Pairing not supported.
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
break;*/
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// case BLE_GAP_EVT_SEC_REQUEST: /** 返回配对请求*/
// ble_gap_sec_params_t sec_params;
// memset(&sec_params,0,sizeof(ble_gap_sec_params_t));
// err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle,BLE_GAP_SEC_STATUS_SUCCESS,&sec_params,NULL);
// printf("sd_ble_gap_sec_params_reply1\n");
// APP_ERROR_CHECK(err_code);
// printf("sd_ble_gap_sec_params_reply2\n");
case BLE_GAP_EVT_AUTH_STATUS:
if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS) {
NRF_LOG_INFO("Pair success!");
} else {
NRF_LOG_INFO("Pair failed!");
sd_ble_gap_disconnect(p_ble_evt->evt.gap_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("ATT MTU exchange completed.");
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
switch (event)
case BSP_EVENT_SLEEP:
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
static void uart_init(void)
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
/**@brief Function for initializing the Nordic UART Service (NUS) client. */
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
init.error_handler = nus_error_handler;
init.p_gatt_queue = &m_ble_gatt_queue;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for handling Peer Manager events.
* @param[in] p_evt Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
pm_handler_on_pm_evt(p_evt);
// pm_handler_disconnect_on_sec_failure(p_evt);
pm_handler_flash_clean(p_evt);
switch (p_evt->evt_id)
scan_start(false);
/////////////Added for bonding/////////////
//////////////Added for bonding//////////////
/**@brief Function for initializing the Peer Manager.
* @param[in] erase_bonds Indicates whether the bonding information must be cleared from
* persistent storage during the initialization of the Peer Manager.
static void peer_manager_init()
err_code = pm_init();
sec_param.bond = SEC_PARAM_BOND;
sec_param.mitm = SEC_PARAM_MITM;
sec_param.lesc = SEC_PARAM_LESC;
sec_param.keypress = SEC_PARAM_KEYPRESS;
sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
sec_param.oob = SEC_PARAM_OOB;
sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
sec_param.kdist_own.enc = 1;
sec_param.kdist_own.id = 1;
sec_param.kdist_peer.enc = 1;
sec_param.kdist_peer.id = 1;
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
static void log_init(void)
/** @brief Function for initializing the database discovery module. */
static void db_discovery_init(void)
ble_db_discovery_init_t db_init;
memset(&db_init, 0, sizeof(ble_db_discovery_init_t));
db_init.evt_handler = db_disc_handler;
db_init.p_gatt_queue = &m_ble_gatt_queue;
ret_code_t err_code = ble_db_discovery_init(&db_init);
* @details Handles any pending log operations, then sleeps until the next event occurs.
nrf_pwr_mgmt_run();
/**@brief Function for setting the BLE transmit power.
static void ble_tx_power_set(void)
int8_t tx_power_level = RADIO_TXPOWER_TXPOWER_Max;
// ret_code_t err_code;
sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT, NULL, tx_power_level);
//设置静态密钥
static void set_static_passkey()
//定义一个BLE选项结构体变量
//定义一个保存静态密码的数组
//m_static_pin_option中的密钥指针指向存放静态密钥的数组
m_static_pin_option.gap_opt.passkey.p_passkey = &passkey[0];
//设置GAP选项中的密钥选项的值
uint32_t err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &m_static_pin_option);
//检查函数返回值
// Initialize.
log_init();
timer_init();
uart_init();
buttons_leds_init();
db_discovery_init();
power_management_init();
ble_stack_init();
set_static_passkey();
gatt_init();
nus_c_init();
scan_init();
peer_manager_init();
// Start execution.
printf("BLE UART central example started.\r\n");
NRF_LOG_INFO("BLE UART central example started.");
ble_tx_power_set();
scan_start(false);
// Enter main loop.
for (;;)
idle_state_handle();
* Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_ble_qwr.h"
#include "ble_nus.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#define SEC_PARAM_MITM 1 /**< Man In The Middle protection is enabled. */
#define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_KEYBOARD_ONLY /**< Keyboard Only. */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nordic_UART" /**< Name of device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(10, UNIT_1_25_MS) //20 /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(15, UNIT_1_25_MS) //75 /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(200, UNIT_10_MS) //4000 /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
// Static passkey
//static ble_opt_t m_static_pin_option;
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
* @param[in] ble_adv_evt Advertising event.
// uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
// err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING);
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
uint32_t err_code;
NRF_LOG_INFO("Connected");
// LED1 OFF
err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
err_code = pm_conn_secure(m_conn_handle, false);
printf("pm_conn_secure1\n");
if (err_code != NRF_ERROR_BUSY)
printf("pm_conn_secure2\n");
NRF_LOG_INFO("Disconnected");
// LED1 ON
} break;
case BLE_GAP_EVT_AUTH_KEY_REQUEST:
err_code = sd_ble_gap_auth_key_reply(m_conn_handle, BLE_GAP_AUTH_KEY_TYPE_PASSKEY, &passkey[0]);
printf("sd_ble_gap_auth_key_reply1\n");
// asm("nop");
printf("sd_ble_gap_auth_key_reply2\n");
/////////Removed for ebonding process//////////
/*case BLE_GAP_EVT_SEC_PARAMS_REQUEST:
break;*/
/* case BLE_GATTS_EVT_SYS_ATTR_MISSING:
break;*/
/////////Removed for bonding process//////////
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
uint32_t err_code;
switch (event)
sleep_mode_enter();
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
index++;
(index >= m_ble_nus_max_data_len))
if (index > 1)
do
} while (err_code == NRF_ERROR_RESOURCES);
index = 0;
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
uint32_t err_code;
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
err_code);
uint32_t err_code;
ble_advertising_init_t init;
int8_t tx_power_level = 8;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, tx_power_level);
if (err_code == NRF_SUCCESS)
// 发射功率设置成功
NRF_LOG_INFO("Transmit power set successfully.");
// 发射功率设置失败
NRF_LOG_INFO("Failed to set transmit power. Error code: %d\n", err_code);
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
advertising_start();
/**@brief Function for the Peer Manager initialization.
static void peer_manager_init(void)
nrf_pwr_mgmt_run();
/**@brief Application main function.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
// Enter main loop.
for (;;)
The pairing/bonding process is initiated when one of the devices calls "pm_conn_secure()". In your case, I see that you call it from the central in the BLE_GAP_EVT_CONNECTED event in ble_evt_handler(). Remove this call, and add it wherever you want to (such as in the event of a UART interrupt, if the user has input "PAIR".
BR,
Edvin
Did you followed these steps:
