Matter - fastest time from power up to first detected Event?
We have implemented a simple contact switch using the nrf52840 and the latest zip generator (v99). The device connects to a Samsung Smart things edge router. A contact device shows up in the application and pressing button 2 makes the device close on the screen. I was able to script closures into turning on lamps. So that appears "functional".
What I was hoping I could find information about is the length of time a device needs to contact the router and be detected, from a power off state.
Some testing has shown it can take a very long time. The test is generally holing the switch down and powering on the device. The power profiler shows what appears to be continuous transmission of the button state, however the application can take a minute to finally detect it.
Is there a known set of configuration values that allow the device to inform the edge router that it is not just intermittent but when it does come on it needs to be configured ASAP?
I am very sorry that I do not know the proper MATTER/Thread terminology here.
Does the 32Khz crystal allow the device to be detected faster?
    I will look into this and return with more information tomorrow.
    Marte
    If the device is in a power-off state, Thread must be enabled before it can reconnect to the network. In that case, you can use the Thread state as explained in  Matter/Thread event indicating "ready to update status" and "status confirmed updated" ? .
    Can you explain what you mean by configured?
    I am not sure I understand the end goal. If you want the device to be low-power but also be able to quickly send a message upon an event, I recommend using Sleepy End Device (SED) or Synchronized Sleepy End Device (SSED) instead of power-off. You can read more about this here: Reducing power consumption in Matter.
    Marte
  • Is there a known set of configuration values that allow the device to inform the edge router that it is not just intermittent but when it does come on it needs to be configured ASAP?
    What I want is to inform the hosting system that a device should be assumed present, even if it hasn't communicated lately.
    Thanks for re-pointing me to the SED /SSED page, from my cursory look at the "differences in the 2.6.0" document I made an assumption that SED/SSED terminology is replaced with ICD. But that is only for Matter portions of the documentation and firmware.
    Anyways, the end goal is to have a device that is not only in low power mode but essentially off. The device will power on and transmit its current state and then power off, pretty typical. From the "Reducing power consumption in Matter" page it appears that I want to implement a long idle time device. Unfortunately, this is documented as provisional, and I guess...not supported.
    When the device powers on, I imagine it needs to handshake with the edge router/host to validate it exists. Perhaps I am wrong in this assumption. Perhaps just starting to send messages should give the host system (again a Samsung Smart things hub) all the required information about the devices presence. Unfortunately, what happens it the device floods output with the closed switch state and the application monitoring the Smartthings hub doesn't show a closed switch, for several seconds.
    Let me make some more modifications and come back to this,
    Your link back to my previous response needs amended a little, since in 2.6 the event handling is in  \v2.6.0\nrf\samples\matter\common\src\board\board.cpp .
    A M
    I will continue to help with this ticket.
    I hope to give some answer to your previous reply tomorrow
    Sigurd Hellesvik
