Hello
I'm using nRF Connect SDK v2.5.0 and have defined a pm_static and the corresponding partitions in the dts with the same address ranges (BTW: is there a way to sync them?). DFU over Bluetooth is working as expected.
pm_static and dts partitions (the strange cryptic node name is just for testing):
app:
address: 0x7200
region: flash_primary
mcuboot:
address: 0x0
placement:
before:
- mcuboot_primary
mcuboot_pad:
address: 0x7000
placement:
align:
start: 0x1000
before:
- mcuboot_primary_app
mcuboot_primary:
address: 0x7000
orig_span: &id001
- mcuboot_pad
- app
span: *id001
mcuboot_primary_app:
address: 0x7200
orig_span: &id002
- app
span: *id002
mcuboot_secondary:
address: 0x41000
placement:
after:
- mcuboot_primary
align:
start: 0x1000
align_next: 0x1000
align_dummy_1:
address: 0x7b000
placement:
after:
- mcuboot_secondary
align:
start: 0x1000
appdata:
address: 0x7c000
placement:
after:
- align_dummy_1
align:
start: 0x1000
flash_primary (0x80000 - 512kB):
| 0x0: mcuboot (0x7000 - 28kB) |
+---0x7000: mcuboot_primary (0x3a000 - 232kB)-----+
| 0x7000: mcuboot_pad (0x200 - 512B) |
+---0x7200: mcuboot_primary_app (0x39e00 - 231kB)-+
| 0x7200: app (0x39e00 - 231kB) |
| 0x41000: mcuboot_secondary (0x3a000 - 232kB) |
| 0x7b000: align_dummy_1 (0x1000 - 4kB) |
| 0x7c000: appdata (0x4000 - 16kB) |
&flash0 {
partitions {
#address-cells = <1>;
#size-cells = <1>;
boot_partition: partition@0 {
label = "mcuboot";
reg = <0x0 0x7000>;
slot0_partition: partition@7000 {
label = "image-0";
reg = <0x7000 0x3a000>;
slot1_partition: partition@41000 {
label = "image-1";
reg = <0x41000 0x3a000>;
myadt_partition: partition@7c000 {
label = "appdata";
reg = <0x7c000 0x4000>;
Then I added the code from the soc_flash_nrf sample, and adapted the dts node:
#define DATAPART_DT_LABEL myadt_partition #define DATAPART_OFFSET FIXED_PARTITION_OFFSET(DATAPART_DT_LABEL) #define DATAPART_DT_DEVICE FIXED_PARTITION_DEVICE(DATAPART_DT_LABEL)
But it can't get compiled:
C:/ncs/v2.5.0/nrf/include/flash_map_pm.h:52:18: error: 'PM_PM_PM_myadt_partition_ID_LABEL_OFFSET' undeclared (first use in this function) 52 | UTIL_CAT(PM_, UTIL_CAT(UTIL_CAT(PM_, UTIL_CAT(PM_ID(label), _LABEL)), x)) ... (many macro expansion notes) ../flash.c:49:25: note: in expansion of macro 'FIXED_PARTITION_OFFSET' 49 | #define DATAPART_OFFSET FIXED_PARTITION_OFFSET(DATAPART_DT_LABEL)
I tested it with an additional prj_nodfu.conf, whith is the same as the one used in my project but with disabled DFU:
CONFIG_BOOTLOADER_MCUBOOT=n CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=n
then it compiles and the flash operations work as expected. But I obviously have no DFU.
I also looked in to the diff of the two .conf files in the two build directories and added them to the no-dfu config:
CONFIG_BOOTLOADER_MCUBOOT=n CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=n # to have the same flash stuff config as with MCUboot CONFIG_USE_DT_CODE_PARTITION=y CONFIG_PARTITION_MANAGER_ENABLED=y CONFIG_FLASH_MAP_CUSTOM=y CONFIG_FLASH_MAP=y CONFIG_STREAM_FLASH=y CONFIG_STREAM_FLASH_ERASE=y
Then also the no-dfu config raises the same compiler errors as the actual project config.
How can I configure my project, so that flash_write, flash_read and flash_erase can be used on my internal data partition with MCUboot and DFU enabled?
Best regards
