I am having a strange problem with nRF Connect SDK for VS Code, and would appreciate some help.
I don't know what I did, but suddenly I am not able to "Generate Configuration" from the VS Code extension, as it gets stuck/hangs at "ld.bfd". (see attached for logs).
Building blinky_tutorial west build --build-dir /Users/minoue/Repository/Playground_Nordic/blinky_tutorial/build /Users/minoue/Repository/Playground_Nordic/blinky_tutorial --pristine --board thingy91_nrf9160_ns --no-sysbuild --cmake-only -- -DNCS_TOOLCHAIN_VERSION=NONE -DCONF_FILE=/Users/minoue/Repository/Playground_Nordic/blinky_tutorial/prj.conf -DBOARD_ROOT=/Users/minoue/Repository/Playground_Nordic/blinky_tutorial -- west build: generating a build system Loading Zephyr default modules (Zephyr base). -- Application: /Users/minoue/Repository/Playground_Nordic/blinky_tutorial -- CMake version: 3.21.0 -- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter -- Cache files will be written to: /Users/minoue/Library/Caches/zephyr -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0/zephyr) -- Found west (found suitable version "1.2.0", minimum required is "0.14.0") -- Board: thingy91_nrf9160_ns -- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk) -- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6") -- Found BOARD.dts: /opt/nordic/ncs/v2.6.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns.dts -- Generated zephyr.dts: /Users/minoue/Repository/Playground_Nordic/blinky_tutorial/build/zephyr/zephyr.dts -- Generated devicetree_generated.h: /Users/minoue/Repository/Playground_Nordic/blinky_tutorial/build/zephyr/include/generated/devicetree_generated.h -- Including generated dts.cmake file: /Users/minoue/Repository/Playground_Nordic/blinky_tutorial/build/zephyr/dts.cmake Parsing /opt/nordic/ncs/v2.6.0/zephyr/Kconfig Loaded configuration '/opt/nordic/ncs/v2.6.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns_defconfig' Merged configuration '/Users/minoue/Repository/Playground_Nordic/blinky_tutorial/prj.conf' Configuration saved to '/Users/minoue/Repository/Playground_Nordic/blinky_tutorial/build/zephyr/.config' Kconfig header saved to '/Users/minoue/Repository/Playground_Nordic/blinky_tutorial/build/zephyr/include/generated/autoconf.h' -- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38") * Terminal will be reused by tasks, press any key to close it.
Strange things is that:
1. I am able to build from the terminal in VS Code without issues (i.e. "west build --board <board_name>")
2. I am also able to "Generate Configuration" button if I set the tool chain to "Zephyr SDK 0.16.5-1".
Maybe an environmental variable is misconfigured...?
I've attached my environment info (generated via "Generate Support Information" button in the extension).
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
"platform": {
"os": "darwin",
"osVersion": "Darwin Kernel Version 23.4.0: Fri Mar 15 00:19:22 PDT 2024; root:xnu-10063.101.17~1/RELEASE_ARM64_T8112",
"osKernel": "23.4.0",
"vscode": "1.88.0",
"electron": "28.2.8",
"node": "v18.18.2"
"system": {
"date": "2024-04-08T09:29:02.978Z",
"vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
"vscodeUptime": "00:16:59",
"osUptime": "79:34:58",
"cpu": "Apple M2"
"workspace": {
"name": "blinky_tutorial (Workspace)",
"workspaceFile": "/Users/minoue/Repository/Playground_Nordic/three_threads/src/blinky_tutorial.code-workspace",
"folders": [
"/Users/minoue/Repository/Playground_Nordic/blinky_tutorial"
"sdks": [
"version": "v2.6.99",
"path": "/Users/minoue/Repository/PT-Node-Workspace"
"version": "v2.6.0",
"path": "/opt/nordic/ncs/v2.6.0"
"version": "v2.5.2",
"path": "/opt/nordic/ncs/v2.5.2"
"activeBuild": "/Users/minoue/Repository/Playground_Nordic/blinky_tutorial/build",
"apps": [
"workspace": "/Users/minoue/Repository/Playground_Nordic/blinky_tutorial",
"uri": "/Users/minoue/Repository/Playground_Nordic/blinky_tutorial",
"buildConfigurations": [
"id": "/Users/minoue/Repository/Playground_Nordic/blinky_tutorial/build",
"name": "build",
"boardId": "thingy91_nrf9160_ns",
"type": "Zephyr",
"isChild": false,
"isStale": true,
"taskBindings": {
"build": [],
"pristineBuild": [],
"flash": [],
"eraseAndFlash": []
"topdir": "/opt/nordic/ncs/v2.6.0",
"workspaceState": "freestanding-ready",
"toolchains": [
"version": "2.6.0",
"path": "/opt/nordic/ncs/toolchains/580e4ef81c"
"version": "2.5.2",
"path": "/opt/nordic/ncs/toolchains/20d68df7e5"
"connectedDevices": [],
"deviceProvider": "nrfutil",
"tools": {
"/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc": "0.16.5",
"/Applications/SEGGER/JLink/JLinkExe": "7.96b",
"/usr/local/bin/nrfjprog": "10.24.1",
"nrfutil": "Not found",
"/opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake": "3.21.0",
"/opt/nordic/ncs/toolchains/580e4ef81c/bin/west": "1.2.0",
"/opt/nordic/ncs/toolchains/580e4ef81c/bin/python3": "3.9.6",
"/opt/nordic/ncs/toolchains/580e4ef81c/bin/ninja": "1.10.2",
"/opt/nordic/ncs/toolchains/580e4ef81c/bin/gperf": "3.1",
"/opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc": "1.6.1",
"/opt/nordic/ncs/toolchains/580e4ef81c/bin/gn": "2154",
"/opt/nordic/ncs/toolchains/580e4ef81c/bin/git": "2.37.3",
"gdbPath": "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gdb"
"nrfutil": {
"nrfutil-device": {
"version": "2.0.0",
"binPath": "/Users/minoue/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.3.25-darwin-arm64/platform/nrfutil/bin/nrfutil-device"
"nrfutil-toolchain-manager": {
"version": "0.14.1",
"binPath": "/Users/minoue/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.3.25-darwin-arm64/platform/nrfutil/bin/nrfutil-toolchain-manager"
"environment": {
"westEnv": {
"ELECTRON_RUN_AS_NODE": "1",
"GIT_EXEC_PATH": "/opt/nordic/ncs/toolchains/580e4ef81c/Cellar/git/2.37.3/libexec/git-core",
"HOME": "/Users/minoue",
"PATH": "/opt/nordic/ncs/toolchains/580e4ef81c/bin:/opt/nordic/ncs/toolchains/580e4ef81c/usr/bin:/opt/nordic/ncs/toolchains/580e4ef81c/usr/local/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/nanopb/generator-bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/aarch64-zephyr-elf/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/x86_64-zephyr-elf/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin:/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/riscv64-zephyr-elf/bin:/opt/nordic/ncs/v2.6.0/zephyr/scripts:/Users/minoue/.docker/bin:/usr/local/sbin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/minoue/Repository/go-workspace/bin:/usr/local/opt/go/libexec/bin:/opt/nordic/ncs/v2.6.0/zephyr/scripts:/Users/minoue/.docker/bin:/usr/local/sbin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/minoue/Repository/go-workspace/bin:/usr/local/opt/go/libexec/bin",
"ZEPHYR_BASE": "/opt/nordic/ncs/v2.6.0/zephyr",
"ZEPHYR_SDK_INSTALL_DIR": "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk",
"USER": "minoue"
"inherited": {
"PATH": "/opt/nordic/ncs/v2.6.0/zephyr/scripts:/Users/minoue/.docker/bin:/usr/local/sbin:/usr/local/bin:/System/Cryptexes/App/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/local/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/bin:/var/run/com.apple.security.cryptexd/codex.system/bootstrap/usr/appleinternal/bin:/Library/Apple/usr/bin:/Users/minoue/Repository/go-workspace/bin:/usr/local/opt/go/libexec/bin",
"USER": "minoue"
"toolchainPath": "/opt/nordic/ncs/toolchains/580e4ef81c",
"toolchainBinPath": "/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin",
"toolchainVersion": "2.6.0"
"terminal": {
"defaultProfile": null
"config": {
"topdir": "${nrf-connect.sdk:2.6.0}",
"toolchain": {
"path": "${nrf-connect.toolchain:2.6.0}"
"ozonePath": "",
"applications": [],
"applicationOptions": {},
"kconfig": {
"interface": "kconfig"
"west": {
"env": {
"$base": "terminal"
"boardRoots": [],
"taskBindings": {},
"buildTerminal": {
"condensedProgress": true
"debugging": {
"flash": true,
"bindings": {},
"justMyCode": true
"deviceProvider": "",
"flash": {
"softreset": false,
"erase": false,
"recover": false
"enableTelemetry": false,
"thirdpartyIntegration": {},
"toolchainManager": {
"indexURL": null,
"installDirectory": null
"nrfutil": {
"home": null
"defaultOpenAction": "ask",
"welcome": {
"showOnStartup": true
"terminalMode": "character"
"extensions": {
"internal": {
"version": "2024.3.25",
"path": "/Users/minoue/.vscode/extensions/nordic-semiconductor.nrf-connect-2024.3.25-darwin-arm64",
"isActive": true
"version": "2024.3.15",
"path": "/Users/minoue/.vscode/extensions/nordic-semiconductor.nrf-terminal-2024.3.15",
"isActive": true
"version": "2024.3.78",
"path": "/Users/minoue/.vscode/extensions/nordic-semiconductor.nrf-devicetree-2024.3.78",
"isActive": true
"version": "2024.3.21",
"path": "/Users/minoue/.vscode/extensions/nordic-semiconductor.nrf-kconfig-2024.3.21",
"isActive": true
"external": {
"marus25.cortex-debug": null,
"ms-vscode.cpptools": "1.19.9",
"ms-vscode.js-debug": "1.88.0",
"ms-vscode.js-debug-companion": "1.1.2",
"ms-vscode.vscode-js-profile-table": "1.0.8",
"dawhite.mustache": "1.1.1",
"ecmel.vscode-html-css": "2.0.9",
"github.vscode-github-actions": "0.26.2",
"GitHub.vscode-pull-request-github": "0.86.0",
"GrapeCity.gc-excelviewer": "4.2.59",
"ms-azuretools.vscode-docker": "1.29.0",
"ms-python.debugpy": "2024.4.0",
"ms-python.isort": "2023.10.1",
"ms-python.python": "2024.4.0",
"ms-python.vscode-pylance": "2024.4.1",
"ms-vscode-remote.remote-containers": "0.354.0",
"qwtel.sqlite-viewer": "0.3.13",
"samuelcolvin.jinjahtml": "0.20.0",
"tamasfe.even-better-toml": "0.19.2",
"twixes.pypi-assistant": "2.0.3"
Thanks!
Makoto
