What are the flashing pins for the nRF52820 chip and how do I flash with the flashing pins?
I want to know what are the flashing pins for the part nRF52820, and what is the procedure for flashing the program with these pins? Should I use the comands? If yes, please help me with the commands?
Note: I am using nRF connect desktop SDK
Gotak
    All nRF52 series chips are programmed through the SWD interface. You will need a debugger/programmer that supports the SWD interface, we recommend using Segger J-Link, which is available on our DKs (also for programming custom boards through the debug output connectors).
    Once you have the J-Link connected to your board, you can program the chip through nRF Connect Programmer or nrfjprog.
    Jørgen
    Thanks for the reply! I will try that.
    While I was going through flashing I got struck at one point at the very initial. What build configuration should I choose for flashing a custom nrf52820, all I could find is
    1. nrf52833dk_nrf52820
    2. nrf52820dongle_nrf52820
    Both of these build configurations gave be incomplete build fatal errors. What should I do? Or , Is there any other build configuration that would work for nrf52820 custom board?
    Thanks
    Gotak
  • The nrf52833dk_nrf52820 target would be the best starting point in nRF Connect SDK. We do not have a dedicated development kit for nRF52820, but nRF52833 DK can work as a "emulated" development platform. You can also reference "Adding custom board support" lesson in nRF Connect SDK Intermediate course in DevAcademy on how to implement your custom board in NCS.
    Depending on what application you are building, you might need to set different configurations or devicetree overlays to build and run successfully.
    If you post which sample you build, and attach the build log, we can help you resolve the problems.
  • So when I am trying to build the configurations for my nRF52820 custom board with nrf52833dk_nrf52820 with the central sample, I am getting this errors:
    * Executing task: nRF Connect: Build: central/build (active)
    Building central
    C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/ncs/v2.5.2/nrf/samples/bluetooth/central/build c:/ncs/v2.5.2/nrf/samples/bluetooth/central"
    [1/6] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\ncs\v2.5.2\nrf\samples\bluetooth\central\build\zephyr && C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.exe -E true""
    c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
    c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `noinit' will not fit in region `RAM'
    c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 7776 bytes
    c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `RAM' overflowed by 11040 bytes
    collect2.exe: error: ld returned 1 exit status
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\ncs\v2.5.2\nrf\samples\bluetooth\central\build'
    * The terminal process terminated with exit code: 1.
    * Terminal will be reused by tasks, press any key to close it.
    only when I am using these prj.conf:
    CONFIG_BT=y
    CONFIG_BT_CENTRAL=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_NVS=y
    CONFIG_LOG=y
    CONFIG_LOG_MODE_IMMEDIATE=y
    CONFIG_NVS_LOG_LEVEL_DBG=y
    CONFIG_REBOOT=y
    CONFIG_MPU_ALLOW_FLASH_WRITE=y
    CONFIG_BT_SMP=y
    CONFIG_BT_GATT_CLIENT=y
    CONFIG_BT_GATT_DM=y
    CONFIG_HEAP_MEM_POOL_SIZE=1024
    CONFIG_BT_GATT_DM_DATA_PRINT=y
    CONFIG_UART_ASYNC_API=y
    CONFIG_NRFX_UARTE0=y
    CONFIG_SERIAL=y
    CONFIG_GPIO=y
    CONFIG_CONSOLE=y
    CONFIG_UART_CONSOLE=y
    CONFIG_HEAP_MEM_POOL_SIZE=2048
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_APPEARANCE=833
    CONFIG_BT_MAX_CONN=6
    CONFIG_BT_MAX_PAIRED=1
    CONFIG_BT_NUS=y
    CONFIG_BT_SETTINGS=y
    CONFIG_FLASH_MAP=y
    CONFIG_SETTINGS=y
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=y
    CONFIG_LOG_PRINTK=y
    CONFIG_ASSERT=y
    # CONFIG_UART_INTERRUPT_DRIVEN=y
    # CONFIG_UART_0_INTERRUPT_DRIVEN=y
    #thread
    CONFIG_WATCHDOG=y
    CONFIG_WDT_LOG_LEVEL_DBG=y
    CONFIG_WDT_DISABLE_AT_BOOT=y
    CONFIG_TASK_WDT=y
    CONFIG_TASK_WDT_MIN_TIMEOUT=500
    CONFIG_THREAD_NAME=y
    # Required to disable default behavior of deep sleep on timeout
    CONFIG_PM_DEVICE=y
    CONFIG_GPIO=y
    # Optional select RAM retention (nRF52 only)
    #CONFIG_APP_RETENTION=y
    CONFIG_CRC=y
    CONFIG_POWEROFF=y
    CONFIG_ASSERT=y
    CONFIG_ASSERT_LEVEL=2
    CONFIG_CMSIS_RTOS_V1=y
    CONFIG_NUM_PREEMPT_PRIORITIES=56
    CONFIG_HEAP_MEM_POOL_SIZE=256
    CONFIG_THREAD_STACK_INFO=y
    CONFIG_THREAD_MONITOR=y
    CONFIG_INIT_STACKS=y
    CONFIG_POLL=y
    CONFIG_SCHED_SCALABLE=y
    CONFIG_THREAD_CUSTOM_DATA=y
    Gotak
    Any update on this?
    I am trying to flash the code image into my external custom nrf52820 board with my nrf52833 DK.
    Is these any board switch settings to do on the nRF52833 DK to flash on the nRF52820 externally?
    Gotak
