HTTPS post request to Azure endpoint
I'm trying to make a https post request to my Azure endpoint with a nrf9160 using Zephyr. I've first made the post request in a python script to check if everything is working on the Azure side, and that seems to work fine, I've included the python script below:
(The script first gets a bearer token and then uses that token to make a post request)
import requests
from datetime import datetime
# Define variables
app_id = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
app_secret = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
tenant_id = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
dce_uri = "https://log-ingestion-xxxx.westeurope-1.ingest.monitor.azure.com"
dcr_immutable_id = "dcr-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
table = "table_name"
# Obtain a bearer token
scope = "https://monitor.azure.com//.default"
body = f"client_id={app_id}&scope={scope}&client_secret={app_secret}&grant_type=client_credentials"
headers = {"Content-Type": "application/x-www-form-urlencoded"}
uri = f"https://login.microsoftonline.com/{tenant_id}/oauth2/v2.0/token"
response = requests.post(uri, data=body, headers=headers)
bearer_token = response.json()["access_token"]
# Generate and send some data
body = [{
        "device" : "2405235235211243",
        "timestamp" : "2022-02-19T15:30:49.4337994Z",
        "log_level": "DEBUG",
        "log_message": "This is a test"
headers = {"Authorization": f"Bearer {bearer_token}", "Content-Type": "application/json"}
uri = f"{dce_uri}/dataCollectionRules/{dcr_immutable_id}/streams/Custom-{table}?api-version=2023-01-01"
upload_response = requests.post(uri, json=body, headers=headers)
To implement this on the nrf9160 using Zephyr, I've modified the https_client sample, but I keep getting error -2 on getaddrinfo(). I've included the code below:
 * Copyright (c) 2020 Nordic Semiconductor ASA
#include <string.h>
#include <zephyr/kernel.h>
#include <stdlib.h>
#include <zephyr/net/socket.h>
#include <modem/nrf_modem_lib.h>
#include <zephyr/net/tls_credentials.h>
#include <modem/pdn.h>
#include <modem/lte_lc.h>
#include <modem/modem_key_mgmt.h>
#define HTTPS_PORT "443"
#define HTTPS_HOSTNAME "https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/oauth2/v2.0/token"
#define BODY "client_id=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&scope=https://monitor.azure.com//.default&client_secret=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxgrant_type=client_credentials"
// #define HTTP_HEAD        \
// 	"HEAD / HTTP/1.1\r\n"        \
// 	"Host: " HTTPS_HOSTNAME ":" HTTPS_PORT "\r\n"                                              \
// 	"Connection: close\r\n\r\n"
#define HTTP_HEAD "POST / HTTP/1.1\r\n"\
		"Host: "HTTPS_HOSTNAME"\r\n"\
		"Connection: close\r\n"\
	    "Content-type: application/x-www-form-urlencoded\r\n"\
		"\r\n"\
		""BODY"\r\n\r\n"
#define HTTP_HEAD_LEN (sizeof(HTTP_HEAD) - 1)
#define HTTP_HDR_END "\r\n\r\n"
#define RECV_BUF_SIZE 2048
#define TLS_SEC_TAG 42
#define PDN_IPV6_WAIT_MS 1000
static const char send_buf[] = HTTP_HEAD;
static char recv_buf[RECV_BUF_SIZE];
static K_SEM_DEFINE(pdn_ipv6_up_sem, 0, 1);
/* Certificate for `example.com` */
static const char cert[] = {
#include "../cert/DigiCertGlobalRootCA.pem"
BUILD_ASSERT(sizeof(cert) < KB(4), "Certificate too large");
/* Provision certificate to modem */
int cert_provision(void)
	int err;
	bool exists;
	int mismatch;
	/* It may be sufficient for you application to check whether the correct
	 * certificate is provisioned with a given tag directly using modem_key_mgmt_cmp().
	 * Here, for the sake of the completeness, we check that a certificate exists
	 * before comparing it with what we expect it to be.
	err = modem_key_mgmt_exists(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, &exists);
	if (err) {
		printk("Failed to check for certificates err %d\n", err);
		return err;
	if (exists) {
		mismatch = modem_key_mgmt_cmp(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert,
					      strlen(cert));
		if (!mismatch) {
			printk("Certificate match\n");
			return 0;
		printk("Certificate mismatch\n");
		err = modem_key_mgmt_delete(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN);
		if (err) {
			printk("Failed to delete existing certificate, err %d\n", err);
	printk("Provisioning certificate\n");
	/*  Provision certificate to the modem */
	err = modem_key_mgmt_write(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert,
				   sizeof(cert) - 1);
	if (err) {
		printk("Failed to provision certificate, err %d\n", err);
		return err;
	return 0;
void pdn_event_handler(uint8_t cid, enum pdn_event event, int reason)
	switch (event) {
	case PDN_EVENT_CNEC_ESM:
		printk("PDP context %d error, %s\n", cid, pdn_esm_strerror(reason));
	case PDN_EVENT_ACTIVATED:
		printk("PDP context %d activated\n", cid);
	case PDN_EVENT_DEACTIVATED:
		printk("PDP context %d deactivated\n", cid);
	case PDN_EVENT_NETWORK_DETACH:
		printk("PDP context %d network detached\n", cid);
#if !IS_ENABLED(CONFIG_PDN_DEFAULT_FAM_IPV4)
	case PDN_EVENT_IPV6_UP:
		printk("PDP context %d IPv6 up\n", cid);
		k_sem_give(&pdn_ipv6_up_sem);
	case PDN_EVENT_IPV6_DOWN:
		printk("PDP context %d IPv6 down\n", cid);
		printk("PDP context %d, unknown event %d\n", cid, event);
/* Setup TLS options on a given socket */
int tls_setup(int fd)
	int err;
	int verify;
	/* Security tag that we have provisioned the certificate with */
	const sec_tag_t tls_sec_tag[] = {
		TLS_SEC_TAG,
#if defined(CONFIG_SAMPLE_TFM_MBEDTLS)
	err = tls_credential_add(tls_sec_tag[0], TLS_CREDENTIAL_CA_CERTIFICATE, cert, sizeof(cert));
	if (err) {
		return err;
	/* Set up TLS peer verification */
	enum {
		NONE = 0,
		OPTIONAL = 1,
		REQUIRED = 2,
	verify = REQUIRED;
	err = setsockopt(fd, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
	if (err) {
		printk("Failed to setup peer verification, err %d\n", errno);
		return err;
	/* Associate the socket with the security tag
	 * we have provisioned the certificate with.
	err = setsockopt(fd, SOL_TLS, TLS_SEC_TAG_LIST, tls_sec_tag, sizeof(tls_sec_tag));
	if (err) {
		printk("Failed to setup TLS sec tag, err %d\n", errno);
		return err;
	err = setsockopt(fd, SOL_TLS, TLS_HOSTNAME, HTTPS_HOSTNAME, sizeof(HTTPS_HOSTNAME) - 1);
	if (err) {
		printk("Failed to setup TLS hostname, err %d\n", errno);
		return err;
	return 0;
	int err;
	int fd;
	char *p;
	int bytes;
	size_t off;
	struct addrinfo *res;
	struct addrinfo hints = {
		.ai_flags = AI_NUMERICSERV, /* Let getaddrinfo() set port */
		.ai_socktype = SOCK_STREAM,
	char peer_addr[INET6_ADDRSTRLEN];
	printk("HTTPS client sample started\n\r");
	err = nrf_modem_lib_init();
	if (err) {
		printk("Modem library initialization failed, error: %d\n", err);
		return 0;
	/* Setup a callback for the default PDP context (zero).
	 * Do this before switching to function mode 1 (CFUN=1)
	 * to receive the first activation event.
	err = pdn_default_ctx_cb_reg(pdn_event_handler);
	if (err) {
		printk("pdn_default_ctx_cb_reg() failed, err %d\n", err);
		return 0;
#if !defined(CONFIG_SAMPLE_TFM_MBEDTLS)
	/* Provision certificates before connecting to the LTE network */
	err = cert_provision();
	if (err) {
		return 0;
	printk("Waiting for network.. ");
	err = lte_lc_init_and_connect();
	if (err) {
		printk("Failed to connect to the LTE network, err %d\n", err);
		return 0;
	printk("OK\n");
	printk("Looking up %s\n", HTTPS_HOSTNAME);
	err = getaddrinfo(HTTPS_HOSTNAME, HTTPS_PORT, &hints, &res);
	if (err) {
		printk("getaddrinfo() failed, err %d\n", err);
		return 0;
	inet_ntop(res->ai_family, &((struct sockaddr_in *)(res->ai_addr))->sin_addr, peer_addr, INET6_ADDRSTRLEN);
	printk("Resolved %s (%s)\n", peer_addr, net_family2str(res->ai_family));
	if (IS_ENABLED(CONFIG_SAMPLE_TFM_MBEDTLS)) {
		fd = socket(res->ai_family, SOCK_STREAM | SOCK_NATIVE_TLS, IPPROTO_TLS_1_2);
	} else {
		fd = socket(res->ai_family, SOCK_STREAM, IPPROTO_TLS_1_2);
	if (fd == -1) {
		printk("Failed to open socket!\n");
		goto clean_up;
	/* Setup TLS socket options */
	err = tls_setup(fd);
	if (err) {
		goto clean_up;
	printk("Connecting to %s:%d\n", HTTPS_HOSTNAME, ntohs(((struct sockaddr_in *)(res->ai_addr))->sin_port));
	err = connect(fd, res->ai_addr, res->ai_addrlen);
	if (err) {
		printk("connect() failed, err: %d\n", errno);
		goto clean_up;
	off = 0;
	do {
		bytes = send(fd, &send_buf[off], HTTP_HEAD_LEN - off, 0);
		if (bytes < 0) {
			printk("send() failed, err %d\n", errno);
			goto clean_up;
		off += bytes;
	} while (off < HTTP_HEAD_LEN);
	printk("Sent %d bytes\n", off);
	off = 0;
	do {
		bytes = recv(fd, &recv_buf[off], RECV_BUF_SIZE - off, 0);
		if (bytes < 0) {
			printk("recv() failed, err %d\n", errno);
			goto clean_up;
		off += bytes;
	} while (bytes != 0 /* peer closed connection */);
	printk("Received %d bytes\n", off);
	/* Make sure recv_buf is NULL terminated (for safe use with strstr) */
	if (off < sizeof(recv_buf)) {
		recv_buf[off] = '\0';
	} else {
		recv_buf[sizeof(recv_buf) - 1] = '\0';
	/* Print HTTP response */
	p = strstr(recv_buf, "\r\n");
	if (p) {
		off = p - recv_buf;
		recv_buf[off + 1] = '\0';
		printk("\n>\t %s\n\n", recv_buf);
	printk("Finished, closing socket.\n");
clean_up:
	freeaddrinfo(res);
	(void)close(fd);
	lte_lc_power_off();
	return 0;
Certificate match
Waiting for network.. PDP context 0 activated
PDP context 0 error, PDN type IPv4 only allowed
OK
Looking up https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/oauth2/v2.0/token
getaddrinfo() failed, err 0
How do I implement the 2 post request from my python script on the nrf9160 using Zephyr?
  • You cannot use a socket that has been closed. You will need to open a new socket.
    Though it is also possible to change the receive logic to not have to close the connection in the first place. One such example would be the download_client library, which uses a series of content-range requests to download large files. To see how it is done, you can look at the code in nrf\subsys\net\lib\download_client\src\download_client.c. In NCS v2.6.0, the download loop itself is on line 830-885.
