I'm trying to make a https post request to my Azure endpoint with a nrf9160 using Zephyr. I've first made the post request in a python script to check if everything is working on the Azure side, and that seems to work fine, I've included the python script below:
(The script first gets a bearer token and then uses that token to make a post request)
import requests
from datetime import datetime
# Define variables
app_id = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
app_secret = "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
tenant_id = "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx"
dce_uri = "https://log-ingestion-xxxx.westeurope-1.ingest.monitor.azure.com"
dcr_immutable_id = "dcr-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
table = "table_name"
# Obtain a bearer token
scope = "https://monitor.azure.com//.default"
body = f"client_id={app_id}&scope={scope}&client_secret={app_secret}&grant_type=client_credentials"
headers = {"Content-Type": "application/x-www-form-urlencoded"}
uri = f"https://login.microsoftonline.com/{tenant_id}/oauth2/v2.0/token"
response = requests.post(uri, data=body, headers=headers)
bearer_token = response.json()["access_token"]
# Generate and send some data
body = [{
"device" : "2405235235211243",
"timestamp" : "2022-02-19T15:30:49.4337994Z",
"log_level": "DEBUG",
"log_message": "This is a test"
headers = {"Authorization": f"Bearer {bearer_token}", "Content-Type": "application/json"}
uri = f"{dce_uri}/dataCollectionRules/{dcr_immutable_id}/streams/Custom-{table}?api-version=2023-01-01"
upload_response = requests.post(uri, json=body, headers=headers)
To implement this on the nrf9160 using Zephyr, I've modified the https_client sample, but I keep getting error -2 on getaddrinfo(). I've included the code below:
* Copyright (c) 2020 Nordic Semiconductor ASA
#include <string.h>
#include <zephyr/kernel.h>
#include <stdlib.h>
#include <zephyr/net/socket.h>
#include <modem/nrf_modem_lib.h>
#include <zephyr/net/tls_credentials.h>
#include <modem/pdn.h>
#include <modem/lte_lc.h>
#include <modem/modem_key_mgmt.h>
#define HTTPS_PORT "443"
#define HTTPS_HOSTNAME "https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/oauth2/v2.0/token"
#define BODY "client_id=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&scope=https://monitor.azure.com//.default&client_secret=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxgrant_type=client_credentials"
// #define HTTP_HEAD \
// "HEAD / HTTP/1.1\r\n" \
// "Host: " HTTPS_HOSTNAME ":" HTTPS_PORT "\r\n" \
// "Connection: close\r\n\r\n"
#define HTTP_HEAD "POST / HTTP/1.1\r\n"\
"Host: "HTTPS_HOSTNAME"\r\n"\
"Connection: close\r\n"\
"Content-type: application/x-www-form-urlencoded\r\n"\
"\r\n"\
""BODY"\r\n\r\n"
#define HTTP_HEAD_LEN (sizeof(HTTP_HEAD) - 1)
#define HTTP_HDR_END "\r\n\r\n"
#define RECV_BUF_SIZE 2048
#define TLS_SEC_TAG 42
#define PDN_IPV6_WAIT_MS 1000
static const char send_buf[] = HTTP_HEAD;
static char recv_buf[RECV_BUF_SIZE];
static K_SEM_DEFINE(pdn_ipv6_up_sem, 0, 1);
/* Certificate for `example.com` */
static const char cert[] = {
#include "../cert/DigiCertGlobalRootCA.pem"
BUILD_ASSERT(sizeof(cert) < KB(4), "Certificate too large");
/* Provision certificate to modem */
int cert_provision(void)
int err;
bool exists;
int mismatch;
/* It may be sufficient for you application to check whether the correct
* certificate is provisioned with a given tag directly using modem_key_mgmt_cmp().
* Here, for the sake of the completeness, we check that a certificate exists
* before comparing it with what we expect it to be.
err = modem_key_mgmt_exists(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, &exists);
if (err) {
printk("Failed to check for certificates err %d\n", err);
return err;
if (exists) {
mismatch = modem_key_mgmt_cmp(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert,
strlen(cert));
if (!mismatch) {
printk("Certificate match\n");
return 0;
printk("Certificate mismatch\n");
err = modem_key_mgmt_delete(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN);
if (err) {
printk("Failed to delete existing certificate, err %d\n", err);
printk("Provisioning certificate\n");
/* Provision certificate to the modem */
err = modem_key_mgmt_write(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert,
sizeof(cert) - 1);
if (err) {
printk("Failed to provision certificate, err %d\n", err);
return err;
return 0;
void pdn_event_handler(uint8_t cid, enum pdn_event event, int reason)
switch (event) {
case PDN_EVENT_CNEC_ESM:
printk("PDP context %d error, %s\n", cid, pdn_esm_strerror(reason));
case PDN_EVENT_ACTIVATED:
printk("PDP context %d activated\n", cid);
case PDN_EVENT_DEACTIVATED:
printk("PDP context %d deactivated\n", cid);
case PDN_EVENT_NETWORK_DETACH:
printk("PDP context %d network detached\n", cid);
#if !IS_ENABLED(CONFIG_PDN_DEFAULT_FAM_IPV4)
case PDN_EVENT_IPV6_UP:
printk("PDP context %d IPv6 up\n", cid);
k_sem_give(&pdn_ipv6_up_sem);
case PDN_EVENT_IPV6_DOWN:
printk("PDP context %d IPv6 down\n", cid);
printk("PDP context %d, unknown event %d\n", cid, event);
/* Setup TLS options on a given socket */
int tls_setup(int fd)
int err;
int verify;
/* Security tag that we have provisioned the certificate with */
const sec_tag_t tls_sec_tag[] = {
TLS_SEC_TAG,
#if defined(CONFIG_SAMPLE_TFM_MBEDTLS)
err = tls_credential_add(tls_sec_tag[0], TLS_CREDENTIAL_CA_CERTIFICATE, cert, sizeof(cert));
if (err) {
return err;
/* Set up TLS peer verification */
enum {
NONE = 0,
OPTIONAL = 1,
REQUIRED = 2,
verify = REQUIRED;
err = setsockopt(fd, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
if (err) {
printk("Failed to setup peer verification, err %d\n", errno);
return err;
/* Associate the socket with the security tag
* we have provisioned the certificate with.
err = setsockopt(fd, SOL_TLS, TLS_SEC_TAG_LIST, tls_sec_tag, sizeof(tls_sec_tag));
if (err) {
printk("Failed to setup TLS sec tag, err %d\n", errno);
return err;
err = setsockopt(fd, SOL_TLS, TLS_HOSTNAME, HTTPS_HOSTNAME, sizeof(HTTPS_HOSTNAME) - 1);
if (err) {
printk("Failed to setup TLS hostname, err %d\n", errno);
return err;
return 0;
int err;
int fd;
char *p;
int bytes;
size_t off;
struct addrinfo *res;
struct addrinfo hints = {
.ai_flags = AI_NUMERICSERV, /* Let getaddrinfo() set port */
.ai_socktype = SOCK_STREAM,
char peer_addr[INET6_ADDRSTRLEN];
printk("HTTPS client sample started\n\r");
err = nrf_modem_lib_init();
if (err) {
printk("Modem library initialization failed, error: %d\n", err);
return 0;
/* Setup a callback for the default PDP context (zero).
* Do this before switching to function mode 1 (CFUN=1)
* to receive the first activation event.
err = pdn_default_ctx_cb_reg(pdn_event_handler);
if (err) {
printk("pdn_default_ctx_cb_reg() failed, err %d\n", err);
return 0;
#if !defined(CONFIG_SAMPLE_TFM_MBEDTLS)
/* Provision certificates before connecting to the LTE network */
err = cert_provision();
if (err) {
return 0;
printk("Waiting for network.. ");
err = lte_lc_init_and_connect();
if (err) {
printk("Failed to connect to the LTE network, err %d\n", err);
return 0;
printk("OK\n");
printk("Looking up %s\n", HTTPS_HOSTNAME);
err = getaddrinfo(HTTPS_HOSTNAME, HTTPS_PORT, &hints, &res);
if (err) {
printk("getaddrinfo() failed, err %d\n", err);
return 0;
inet_ntop(res->ai_family, &((struct sockaddr_in *)(res->ai_addr))->sin_addr, peer_addr, INET6_ADDRSTRLEN);
printk("Resolved %s (%s)\n", peer_addr, net_family2str(res->ai_family));
if (IS_ENABLED(CONFIG_SAMPLE_TFM_MBEDTLS)) {
fd = socket(res->ai_family, SOCK_STREAM | SOCK_NATIVE_TLS, IPPROTO_TLS_1_2);
} else {
fd = socket(res->ai_family, SOCK_STREAM, IPPROTO_TLS_1_2);
if (fd == -1) {
printk("Failed to open socket!\n");
goto clean_up;
/* Setup TLS socket options */
err = tls_setup(fd);
if (err) {
goto clean_up;
printk("Connecting to %s:%d\n", HTTPS_HOSTNAME, ntohs(((struct sockaddr_in *)(res->ai_addr))->sin_port));
err = connect(fd, res->ai_addr, res->ai_addrlen);
if (err) {
printk("connect() failed, err: %d\n", errno);
goto clean_up;
off = 0;
do {
bytes = send(fd, &send_buf[off], HTTP_HEAD_LEN - off, 0);
if (bytes < 0) {
printk("send() failed, err %d\n", errno);
goto clean_up;
off += bytes;
} while (off < HTTP_HEAD_LEN);
printk("Sent %d bytes\n", off);
off = 0;
do {
bytes = recv(fd, &recv_buf[off], RECV_BUF_SIZE - off, 0);
if (bytes < 0) {
printk("recv() failed, err %d\n", errno);
goto clean_up;
off += bytes;
} while (bytes != 0 /* peer closed connection */);
printk("Received %d bytes\n", off);
/* Make sure recv_buf is NULL terminated (for safe use with strstr) */
if (off < sizeof(recv_buf)) {
recv_buf[off] = '\0';
} else {
recv_buf[sizeof(recv_buf) - 1] = '\0';
/* Print HTTP response */
p = strstr(recv_buf, "\r\n");
if (p) {
off = p - recv_buf;
recv_buf[off + 1] = '\0';
printk("\n>\t %s\n\n", recv_buf);
printk("Finished, closing socket.\n");
clean_up:
freeaddrinfo(res);
(void)close(fd);
lte_lc_power_off();
return 0;
HTTPS client sample started Certificate match Waiting for network.. PDP context 0 activated PDP context 0 error, PDN type IPv4 only allowed OK Looking up https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/oauth2/v2.0/token getaddrinfo() failed, err 0
How do I implement the 2 post request from my python script on the nrf9160 using Zephyr?
