LTE Network latch issue
I'm trying build customized asset tracker. The observation is the network latch fails or the board reboots after
LTE_LC_EVT_LTE_MODE_UPDATE event.
00> *** Booting Zephyr OS build v3.3.99-ncs1 ***
00> [00:00:00.257,202] <inf> at_host: UART check failed: 12. Dropping buffer and retrying.
00>
00> lte_lc_connect_async, success
00> [00:00:00.553,222] <err> lte_lc: Failed to set functional mode. Please check XSYSTEMMODE.
00> MODEM: Failed enabling UICC power, error: -14
00> Modem FW Ver: mfw_nrf9160_1.3.6
00> IMEI: 351516173348939
00> SIM ICCID: 89918740106000231354
00> Waiting for network... OK
00> APN: Error
00> IP Addr: Error
00> Signal Strength: 255
00> OK
00>
00> lte_evt_handler
00> ../src/main.c:lte_evt_handler:132
00>
00> Modem domain event, type: Light searc
00> lte_evt_handler
00> ../src/main.c:lte_evt_handler:79
00>
00> lte_evt_handler
00> ../src/main.c:lte_evt_handler:123
00>
00> LTE cell changed: Cell ID: 1472400, Tracking area: 49249
00> lte_evt_handler
00> ../src/main.c:lte_evt_handler:129
Board reboots after this.
I have attached the code here please help on this.
#include <stdio.h>
#include <stdbool.h>
#include <modem/modem_info.h>
#include <modem/at_params.h>
#include <nrf_modem.h>
#include <modem/lte_lc.h>
#include <modem/nrf_modem_lib.h>
#include <modem/pdn.h>
#include <stdio.h>
#include <stdlib.h>
#include <zephyr/net/socket.h>
#include <zephyr/kernel.h>
void nslookup(const char * hostname, struct addrinfo **results)
	int err;
	struct addrinfo hints = {
		//.ai_family = AF_INET,     // Allow IPv4 Address
		.ai_family = AF_UNSPEC,		// Allow IPv4 or IPv6
		.ai_socktype = SOCK_STREAM,
	err = getaddrinfo(hostname, NULL, &hints, (struct zsock_addrinfo **) results);
	if (err) {
		printf("getaddrinfo() failed, err %d\n", errno);
		return;
void print_addrinfo_results(struct addrinfo **results)
	char ipv4[INET_ADDRSTRLEN];
	char ipv6[INET6_ADDRSTRLEN];
	struct sockaddr_in *sa;
	struct sockaddr_in6 *sa6;
	struct addrinfo *rp;
	for (rp = (struct addrinfo *)results; rp != NULL; rp = rp->ai_next) {
		if (rp->ai_addr->sa_family == AF_INET) {
			// IPv4 Address
			sa = (struct sockaddr_in *) rp->ai_addr;
			inet_ntop(AF_INET, &sa->sin_addr, ipv4, INET_ADDRSTRLEN);
			printf("IPv4: %s\n", ipv4);
		if (rp->ai_addr->sa_family == AF_INET6) {
			// IPv6 Address
			sa6 = (struct sockaddr_in6 *) rp->ai_addr;
			inet_ntop(AF_INET6, &sa6->sin6_addr, ipv6, INET6_ADDRSTRLEN);
			printf("IPv6: %s\n", ipv6);
#if 0
int modem_info_rsrp_register(rsrp_cb_t cb)
	modem_info_rsrp_cb = cb;
	at_monitor_resume(&modem_info_cesq_mon);
	if (nrf_modem_at_printf(AT_CMD_CESQ_ON) != 0) {
		return -EIO;
	return 0;
static void lte_evt_handler(const struct lte_lc_evt *const evt)
	printk("\nlte_evt_handler \n");
	switch (evt->type) {
	case LTE_LC_EVT_NW_REG_STATUS: {
		printk("%s:%s:%d\n", __FILE__,__func__,__LINE__);
		if (evt->nw_reg_status == LTE_LC_NW_REG_UICC_FAIL) {
			printk("\nNo SIM card detected!");
		if ((evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME) ||
		    (evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_ROAMING)) {
			printk("\nNetwork registration status: %s",
				evt->nw_reg_status == LTE_LC_NW_REG_REGISTERED_HOME ?
				"Connected - home network" : "Connected - roaming");
	case LTE_LC_EVT_PSM_UPDATE:
		printk("\nPSM parameter update: TAU: %d, Active time: %d",
			evt->psm_cfg.tau, evt->psm_cfg.active_time);
	case LTE_LC_EVT_EDRX_UPDATE: {
		char log_buf[60];
		ssize_t len;
		len = snprintf(log_buf, sizeof(log_buf),
			       "eDRX parameter update: eDRX: %.2f, PTW: %.2f",
			       evt->edrx_cfg.edrx, evt->edrx_cfg.ptw);
		if (len > 0) {
			printk("\n%s", log_buf);
	case LTE_LC_EVT_RRC_UPDATE:
		printk("\nRRC mode: %s",
			evt->rrc_mode == LTE_LC_RRC_MODE_CONNECTED ?
			"Connected" : "Idle");
	case LTE_LC_EVT_CELL_UPDATE:
		printk("\nLTE cell changed: Cell ID: %d, Tracking area: %d",
			evt->cell.id, evt->cell.tac);
	case LTE_LC_EVT_LTE_MODE_UPDATE:
	case LTE_LC_EVT_MODEM_EVENT:
		printk("\nModem domain event, type: %s",
			evt->modem_evt == LTE_LC_MODEM_EVT_LIGHT_SEARCH_DONE ?
				"Light search done" :
			evt->modem_evt == LTE_LC_MODEM_EVT_SEARCH_DONE ?
				"Search done" :
			evt->modem_evt == LTE_LC_MODEM_EVT_RESET_LOOP ?
				"Reset loop" :
			evt->modem_evt == LTE_LC_MODEM_EVT_BATTERY_LOW ?
				"Low battery" :
			evt->modem_evt == LTE_LC_MODEM_EVT_OVERHEATED ?
				"Modem is overheated" :
				"Unknown");
		/* If a reset loop happens in the field, it should not be necessary
		 * to perform any action. The modem will try to re-attach to the LTE network after
		 * the 30-minute block.
		if (evt->modem_evt == LTE_LC_MODEM_EVT_RESET_LOOP) {
			printk("\nFor more information see the nRF91 AT Commands - Command "
					"Reference Guide v2.0 - chpt. 5.36");
/* Handler that notifies the application of events related to the default PDN context, CID 0. */
void pdn_event_handler(uint8_t cid, enum pdn_event event, int reason)
	printk("%s:%s\n",__FILE__,__func__);
	ARG_UNUSED(cid);
	switch (event) {
	case PDN_EVENT_CNEC_ESM:
		printk("\nEvent: PDP context %d, %s", cid, pdn_esm_strerror(reason));
	case PDN_EVENT_ACTIVATED:
		printk("\nPDN_EVENT_ACTIVATED");
	case PDN_EVENT_DEACTIVATED:
		printk("\nPDN_EVENT_DEACTIVATED");
	case PDN_EVENT_IPV6_UP:
		printk("\nPDN_EVENT_IPV6_UP");
	case PDN_EVENT_IPV6_DOWN:
		printk("\nPDN_EVENT_IPV6_DOWN");
	case PDN_EVENT_NETWORK_DETACH:
		printk("\nPDN_EVENT_NETWORK_DETACH");
		printk("Unexpected PDN event!");
static void modem_rsrp_handler(char rsrp_value)
	/* RSRP raw values that represent actual signal strength are
	 * 0 through 97. RSRP is converted to dBm per "nRF91 AT Commands" v1.7.
	if (rsrp_value > 97) {
		return;
	/* Set temporary variable to hold RSRP value. RSRP callbacks and other
	 * data from the modem info module are retrieved separately.
	 * This temporarily saves the latest value which are sent to
	 * the Data module upon a modem data request.
	printk("\nIncoming RSRP status message, RSRP value is %d",
		rsrp_value);
	int err;
	int fd;
	char *p;
	int bytes;
	size_t off;
	err = nrf_modem_lib_init();
	if (err) {
		printk("Modem library initialization failed, error: %d\n", err);
		return 0;
	/* Setup a callback for the default PDP context (zero).
	 * Do this before switching to function mode 1 (CFUN=1)
	 * to receive the first activation event.
	err = pdn_default_ctx_cb_reg(pdn_event_handler);
	if (err) {
		printk("pdn_default_ctx_cb_reg() failed, err %d\n", err);
		return 0;
	err = lte_lc_init();
		if (err) {
			printk("\nlte_lc_init, error: %d", err);
	//err = lte_lc_init_and_connect();
	err = lte_lc_connect_async(lte_evt_handler);
	if (err) {
		printk("\nlte_lc_connect_async, error: %d\n", err);
		return err;
		printk("\nlte_lc_connect_async, success\n");
	if (err) printk("MODEM: Failed initializing LTE Link controller, error: %d\n", err);
	err = lte_lc_func_mode_set(LTE_LC_FUNC_MODE_ACTIVATE_UICC);
	if (err) printk("MODEM: Failed enabling UICC power, error: %d\n", err);
	k_msleep(100);
	err = modem_info_init();
	if (err) printk("MODEM: Failed initializing modem info module, error: %d\n", err);
	print_modem_info(MODEM_INFO_FW_VERSION);
	print_modem_info(MODEM_INFO_IMEI);
	print_modem_info(MODEM_INFO_ICCID);
	printk("Waiting for network... ");
	printk("OK\n");
	print_modem_info(MODEM_INFO_APN);
	print_modem_info(MODEM_INFO_IP_ADDRESS);
	print_modem_info(MODEM_INFO_RSRP);
	struct addrinfo *res;
//	nslookup("www.youtube.com", &res);
//	print_addrinfo_results(&res);
	printk("OK\n");
err = lte_lc_modem_events_enable();
	if (err) {
		printk("\nModem firmware versions older than 1.3.0 do not support "
			"enabling modem domain events");
//err = modem_data_init();
while(1)
	k_sleep(K_MSEC(7000));
clean_up:
	lte_lc_power_off();
	return 0;
void print_modem_info(enum modem_info info)
	int len;
	char buf[80];
	switch (info) {
		case MODEM_INFO_RSRP:
			printk("Signal Strength: ");
		case MODEM_INFO_IP_ADDRESS:
			printk("IP Addr: ");
		case MODEM_INFO_FW_VERSION:
			printk("Modem FW Ver: ");
		case MODEM_INFO_ICCID:
			printk("SIM ICCID: ");
		case MODEM_INFO_IMSI:
			printk("IMSI: ");
		case MODEM_INFO_IMEI:
			printk("IMEI: ");
		case MODEM_INFO_DATE_TIME:
			printk("Network Date/Time: ");
		case MODEM_INFO_APN:
			printk("APN: ");
			printk("Unsupported: ");
	len = modem_info_string_get(info, buf, 80);
	if (len > 0) {
		printk("%s\n",buf);
	} else {
		printk("Error\n");
void nrf_modem_fault_handler(struct nrf_modem_fault_info *fault_info)
	printk("\nModem error: 0x%x, PC: 0x%x", fault_info->reason, fault_info->program_counter);
void __module_main()
	//dummy function
#include <stdio.h>
#include <zephyr/net/tls_credentials.h>
#define HTTPS_HOSTNAME "firestore.googleapis.com"
#define HTTPS_PORT "443"
int fd = -1;
int tls_setup(int fd);
int https_connect();
void https_send(char* send_buf);
#define HTTP_HEADER "POST /v1/projects/fnld-d28b3/databases/(default)/documents/DeviceData?key=AIzaSyB3B7cEh2-s9Ln_An7iQzJ6lHZ8HlPl54s HTTP/1.1\r\n"
#define POST_LEN "Host: firestore.googleapis.com\r\nContent-Type: application/json\r\nContent-Length: "
#define TLS_SEC_TAG 42
extern int fd;
extern char* send_buf;
extern char *g_gnss_data;
extern char *g_modem_data;
extern char *g_modem_data_static;
void send_location(void)
	send_buf = (char*) k_malloc(sizeof(char) * 1024);
	char *temp = (char *) k_malloc(1 * 512);
	static bool inited = false;
	inited = true;
	sprintf(send_buf,HTTP_HEADER);
	strcpy(temp,POST_LEN);
	char tmp[64] = {0};
	sprintf(tmp,"%lu\r\n\r\n",strlen(g_gnss_data));
	strcat(temp,tmp);
	strcat(send_buf,temp);
	strcat(send_buf,g_gnss_data);
	//strcat(send_buf,"\r\n\r\n");
	printk("send_buf = %s\n",send_buf);
	int32_t bytes = 0, off = 0;
	if(strlen(g_gnss_data) > 0)
		do {
		bytes = send(fd, &send_buf[off], strlen(send_buf), 0);
		if (bytes < 0) {
			printk("\nsend() failed, err %d\n", errno);
			https_connect();
		off += bytes;
		} while (off < strlen(send_buf));
	int err;
	int verify;
	/* Security tag that we have provisioned the certificate with */
	const sec_tag_t tls_sec_tag[] = {
		TLS_SEC_TAG,
#if defined(CONFIG_SAMPLE_TFM_MBEDTLS)
	err = tls_credential_add(tls_sec_tag[0], TLS_CREDENTIAL_CA_CERTIFICATE, cert, sizeof(cert));
	if (err) {
		return err;
	/* Set up TLS peer verification */
	enum {
		NONE = 0,
		OPTIONAL = 1,
		REQUIRED = 2,
	verify = NONE;
	err = setsockopt(fd, SOL_TLS, TLS_PEER_VERIFY, &verify, sizeof(verify));
	if (err) {
		printk("\nFailed to setup peer verification, err %d\n", errno);
		return err;
	/* Associate the socket with the security tag
	 * we have provisioned the certificate with.
	err = setsockopt(fd, SOL_TLS, TLS_SEC_TAG_LIST, tls_sec_tag, sizeof(tls_sec_tag));
	if (err) {
		printk("\nFailed to setup TLS sec tag, err %d\n", errno);
		return err;
	err = setsockopt(fd, SOL_TLS, TLS_HOSTNAME, HTTPS_HOSTNAME, sizeof(HTTPS_HOSTNAME) - 1);
	if (err) {
		printk("\nFailed to setup TLS hostname, err %d\n", errno);
		return err;
	return 0;
#include "modem/modem_key_mgmt.h"
static const char cert[] = {
#include "DigiCertGlobalRootCA.pem"
void key_press_expiry_function(struct k_timer *timer_id)
	printk("\nSOS_EVENT : Sending location information");
	send_location();
int cert_provision(void)
	int err;
	bool exists;
	int mismatch;
	/* It may be sufficient for you application to check whether the correct
	 * certificate is provisioned with a given tag directly using modem_key_mgmt_cmp().
	 * Here, for the sake of the completeness, we check that a certificate exists
	 * before comparing it with what we expect it to be.
	err = modem_key_mgmt_exists(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, &exists);
	if (err) {
		printk("Failed to check for certificates err %d\n", err);
		return err;
	if (exists) {
		mismatch = modem_key_mgmt_cmp(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert,
					      strlen(cert));
		if (!mismatch) {
			printk("Certificate match\n");
			return 0;
		printk("Certificate mismatch\n");
		err = modem_key_mgmt_delete(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN);
		if (err) {
			printk("Failed to delete existing certificate, err %d\n", err);
	printk("Provisioning certificate\n");
	/*  Provision certificate to the modem */
	err = modem_key_mgmt_write(TLS_SEC_TAG, MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN, cert,
				   sizeof(cert) - 1);
	if (err) {
		printk("Failed to provision certificate, err %d\n", err);
		return err;
	return 0;
int https_connect()
					int err;
	char *p;
	int bytes;
	size_t off;
		.ai_flags = AI_NUMERICSERV, /* Let getaddrinfo() set port */
		.ai_family = AF_INET6
	char peer_addr[INET6_ADDRSTRLEN];
		printk("\nLooking up %s\n", HTTPS_HOSTNAME);
	err = getaddrinfo(HTTPS_HOSTNAME, HTTPS_PORT, &hints, &res);
	if (err) {
		printk("\ngetaddrinfo() failed, err %d\n", errno);
		return -1;
	inet_ntop(res->ai_family, &((struct sockaddr_in *)(res->ai_addr))->sin_addr, peer_addr,
		  INET6_ADDRSTRLEN);
	printk("\nResolved %s (%s)\n", peer_addr, net_family2str(res->ai_family));
	close(fd);
	if (IS_ENABLED(CONFIG_SAMPLE_TFM_MBEDTLS)) {
		fd = socket(res->ai_family, SOCK_STREAM | SOCK_NATIVE_TLS, IPPROTO_TLS_1_2);
	} else {
		fd = socket(res->ai_family, SOCK_STREAM, IPPROTO_TLS_1_2);
	if (fd == -1) {
		printk("\nFailed to open socket!\n");
	/* Setup TLS socket options */
	err = tls_setup(fd);
	if (err) {
		printk("\n\n\nTLS setup failed\n\n");
	printk("\nConnecting to %s:%d\n", HTTPS_HOSTNAME,
	       ntohs(((struct sockaddr_in *)(res->ai_addr))->sin_port));
	err = connect(fd, res->ai_addr, res->ai_addrlen);
	if (err) {
		printk("\nconnect() failed, err: %d\n", errno);
		return -1;
		printk("\nconnection success\n");
	off = 0;
	freeaddrinfo(res);
	return 0;
