Not able to build my module with Nordic SDK
I have a software module with OpenThread wrappers. The wrappers are required because we want to support other CoAP libraries as well like libcoap with our software module.
Also we have a platform wrapper which currently supports FreeRTOS and posix that gets built as a separate library in our project. We have CMake as our build system.
Now, we want to support latest Nordic SDK with Zephyr OS and OpenThread with our project.
We are currently trying to build with Nordic SDK 2.6. The problems:
1. We want to zephyr OS module gets automatically resolved with our platform component as a CMake target level which we cant do because of the build procedure referred by Nordic SDK.
2. Similar is the case with OpenThread.
3. Somehow we built the modules with hardcoded zephyr and OT include paths and could generate our libraries and create an app with the "app" target, however at linking time it is not able to resolve functions. We saw the generated "build.ninja" file, which has all the libraries listed for the elf file, still we are getting linking error.
FYI, our libraries are C++ based if that information helps you.
Any recommendations ?
    Can you share how you have included your library and what errors that you see?
    Håkon
  • I can not share much details here, but I have shared some details below. Please have a look if that helps and let me know if you need any further details.
    The CMakelists.txt file which we are using to include our libraries is looks like following
    cmake_minimum_required(VERSION 3.20.0)
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(coap_server)
    project(coap_server VERSION "1.1.0" LANGUAGES C CXX)
    set(CMAKE_VERBOSE_MAKEFILE ON)
    add_subdirectory(${PATH_TO_OUR_LIB})
    FILE(GLOB app_sources src/*.c)
    # NORDIC SDK APP START
    target_sources(app PRIVATE ${app_sources})
    set(IOT_EXAMPLE_SERVER_INCLUDE_DIR
    ${PATH_TO_OUR_INC_DIR}
    target_include_directories(
    app INTERFACE ${IOT_EXAMPLE_SERVER_INCLUDE_DIR}
    target_link_libraries(
    app
    PUBLIC ${OUR_LIB}
    At time of linking we get following errors:
    NRF_802154_CARRIER_FUNCTIONS_ENABLED=0
    NRF_802154_ENERGY_DETECTED_VERSION=1
    NRF_802154_PLATFORM_ASSERT_INCLUDE=nrf_802154_assert_zephyr.h
    NRF_802154_ECB_PRIORITY=-1
    NRF_802154_SWI_PRIORITY=1
    [222/227] Linking CXX executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map C:/Users/MyUser/coap_server/build/zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && ccache C:\ncs\toolchains\cf2149caf2\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-g++.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\Users\MyUser\coap_server\build\zephyr && C:\ncs\toolchains\cf2149caf2\opt\bin\cmake.exe -E true""
    c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: mylib/src/server/libmylibserver.a(mylib_mode_storage.cpp.obj): in function `server::storage::HandleDiscoveryPointResponse(ApplicationContext const&, Transaction const&, DiscoveryResult const&) [clone .constprop.0]':
    mylib_mode_storage.cpp:(.text+0x1202): undefined reference to `infra::mylibMessage::GetSerializedBuffer()'
    c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: mylib/src/server/libmylibserver.a(mylib_server_factory.cpp.obj): in function `server::Factory::Create(config::Configuration const&, adapter_api_tag*, resource_info_tag*, unsigned int, tagmylibSwuApi const*)':
    mylib_server_factory.cpp:(.text+0x54e): undefined reference to `transport::ITransport::Create(config::Configuration::DataLink)'
    c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: mylib/platform/libmylibpal.a(memory.cpp.obj): in function `operator new(unsigned int)':
    memory.cpp:(.text+0x0): undefined reference to `k_malloc'
    c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: mylib/platform/libmylibpal.a(memory.cpp.obj): in function `operator new[](unsigned int)':
    memory.cpp:(.text+0xc): undefined reference to `k_malloc'
    c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: app/libapp.a(server.cpp.obj): in function `main':
    C:/Users/MyUser/coap_server/mylib/example/server/server.cpp:722: undefined reference to `config::Address::Address(config::AddressType, unsigned char const*, unsigned short, unsigned int)'
    c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: C:/Users/MyUser/coap_server/mylib/example/server/server.cpp:751: undefined reference to `config::Configuration::Configuration(config::Address&, mylibAppCtxType*, bool, char const*, unsigned int, unsigned int, unsigned int, unsigned int, SecurityConfiguration const&, Configuration const&, void (*)(), void (*)(tagmylibStatus), unsigned int, unsigned int, bool, unsigned char, char const*)'
    c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi/lib/thumb/v7e-m+fp/hard\libc_nano.a(lib_a-timesr.o): in function `_times_r':
    timesr.c:(.text._times_r+0x2): undefined reference to `_times'
    collect2.exe: error: ld returned 1 exit status
    The linker usually gives you "following errors" - meaning that it is usually the first error that is the most significant, meaning this:
    You'll need to resolve this linker issue. This could be as easy as a missing include directory/file.
    Håkon
  • may be you are correct. However, we are getting these kind of linking errors for every functions. Also if you see the error "memory.cpp:(.text+0x0): undefined reference to `k_malloc'", that is interesting, because the zephyr kernel library is already present in the linker command.
    Following is the final linker command generated. Here we can see all the libraries including ours are available, still we are getting the above linker errors.
    build zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map | ${cmake_ninja_workdir}zephyr/zephyr_pre0.map: CXX_EXECUTABLE_LINKER__zephyr_pre0_ zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj | zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj zephyr/linker_zephyr_pre0.cmd app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/libarch__arm__core.a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a zephyr/lib/libc/newlib/liblib__libc__newlib.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/lib/posix/liblib__posix.a zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a zephyr/subsys/random/libsubsys__random.a zephyr/subsys/net/libsubsys__net.a zephyr/subsys/net/l2/openthread/libsubsys__net__ip__l2__openthread.a zephyr/subsys/net/ip/libsubsys__net__ip.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/entropy/libdrivers__entropy.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/ieee802154/libdrivers__ieee802154.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a modules/nrf/subsys/ieee802154/lib..__nrf__subsys__ieee802154.a modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a modules/nrf/drivers/mpsl/temp_nrf5/lib..__nrf__drivers__mpsl__temp_nrf5.a modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a modules/openthread/platform/libopenthread_platform.a modules/hal_nordic/nrf_802154/libnrf-802154-platform.a modules/nrfxlib/nrf_802154/nrf_802154/driver/libnrf-802154-driver.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/segger/libmodules__segger.a zephyr/kernel/libkernel.a /example/datapoints/sub_system_adapter/libsubsystemadapter.a example/utils/libexampleutils.a example/daemon/platform/lib_daemon_platform.a example/datapoints/app_db_interface/libdatabaseupdate.a example/datapoints/database/libdatabase.a src/server/libserver.a src/libcore.a /src/libcore.a third_party/connectedhomeip/libcrypto.a tinycbor/libTinyCBOR.a platform/libpal.a zephyr/arch/common/libisr_tables.a modules/nrfxlib/nrf_802154/nrf_802154/common/libnrf-802154-common.a modules/hal_nordic/nrf_802154/libnrf-802154-platform.a C$:/ncs/v2.6.0/nrfxlib/nrf_802154/sl/sl/lib/nRF52840/hard-float/libnrf-802154-sl.a modules/openthread/build/src/cli/libopenthread-cli-ftd.a modules/openthread/build/src/core/libopenthread-ftd.a modules/openthread/build/third_party/tcplp/libtcplp-ftd.a modules/openthread/build/src/core/libopenthread-ftd.a modules/openthread/build/third_party/tcplp/libtcplp-ftd.a modules/nrf/subsys/nrf_security/src/libmbedcrypto.a C$:/ncs/v2.6.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.19.a C$:/ncs/v2.6.0/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/hard-float/liboberon_mbedtls_3.0.14.a modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a C$:/ncs/v2.6.0/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/hard-float/liboberon_3.0.14.a C$:/ncs/v2.6.0/nrfxlib/mpsl/fem/common/lib/cortex-m4/hard-float/libmpsl_fem_common.a C$:/ncs/v2.6.0/nrfxlib/mpsl/fem/nrf21540_gpio/lib/cortex-m4/hard-float/libmpsl_fem_nrf21540_gpio.a C$:/ncs/v2.6.0/nrfxlib/mpsl/fem/nrf21540_gpio_spi/lib/cortex-m4/hard-float/libmpsl_fem_nrf21540_gpio_spi.a C$:/ncs/v2.6.0/nrfxlib/mpsl/fem/simple_gpio/lib/cortex-m4/hard-float/libmpsl_fem_simple_gpio.a C$:/ncs/v2.6.0/nrfxlib/mpsl/lib/cortex-m4/hard-float/libmpsl.a zephyr/linker_zephyr_pre0.cmd || app/libapp.a example/daemon/platform/lib_daemon_platform.a example/datapoints/app_db_interface/libdatabaseupdate.a example/datapoints/database/libdatabase.a example/datapoints/sub_system_adapter/libsubsystemadapter.a example/utils/libexampleutils.a platform/libpal.a src/libcore.a src/server/libserver.a third_party/connectedhomeip/libcrypto.a modules/hal_nordic/nrf_802154/libnrf-802154-platform.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a modules/nrf/drivers/mpsl/temp_nrf5/lib..__nrf__drivers__mpsl__temp_nrf5.a modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a modules/nrf/subsys/ieee802154/lib..__nrf__subsys__ieee802154.a modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a modules/nrf/subsys/nrf_security/src/libmbedcrypto.a modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a modules/nrfxlib/nrf_802154/nrf_802154/common/libnrf-802154-common.a modules/nrfxlib/nrf_802154/nrf_802154/driver/libnrf-802154-driver.a modules/openthread/build/src/cli/libopenthread-cli-ftd.a modules/openthread/build/src/core/libopenthread-ftd.a modules/openthread/platform/libopenthread_platform.a modules/segger/libmodules__segger.a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a zephyr/arch/arch/arm/core/libarch__arm__core.a zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a zephyr/arch/common/libarch__common.a zephyr/arch/common/libisr_tables.a zephyr/driver_validation_h_target zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/entropy/libdrivers__entropy.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/ieee802154/libdrivers__ieee802154.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a zephyr/kernel/libkernel.a zephyr/kobj_types_h_target zephyr/lib/libc/common/liblib__libc__common.a zephyr/lib/libc/newlib/liblib__libc__newlib.a zephyr/lib/posix/liblib__posix.a zephyr/libzephyr.a zephyr/linker_zephyr_prebuilt_script_target zephyr/offsets zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a zephyr/subsys/net/ip/libsubsys__net__ip.a zephyr/subsys/net/l2/openthread/libsubsys__net__ip__l2__openthread.a zephyr/subsys/net/libsubsys__net.a zephyr/subsys/random/libsubsys__random.a zephyr/syscall_list_h_target zephyr/zephyr_generated_headers
    LINK_FLAGS = -gdwarf-4
    LINK_LIBRARIES = zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -fuse-ld=bfd -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=C:/Users/Z004S4BW/coap_server/build/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/libarch__arm__core.a zephyr/arch/arch/arm/core/cortex_m/libarch__arm__core__cortex_m.a zephyr/arch/arch/arm/core/mpu/libarch__arm__core__mpu.a zephyr/lib/libc/newlib/liblib__libc__newlib.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/lib/posix/liblib__posix.a zephyr/soc/soc/arm/nordic_nrf/libsoc__arm__nordic_nrf.a zephyr/subsys/random/libsubsys__random.a zephyr/subsys/net/libsubsys__net.a zephyr/subsys/net/l2/openthread/libsubsys__net__ip__l2__openthread.a zephyr/subsys/net/ip/libsubsys__net__ip.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/entropy/libdrivers__entropy.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/ieee802154/libdrivers__ieee802154.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/dk_buttons_and_leds/lib..__nrf__lib__dk_buttons_and_leds.a modules/nrf/lib/multithreading_lock/lib..__nrf__lib__multithreading_lock.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/subsys/nrf_security/src/zephyr/libmbedtls_zephyr.a modules/nrf/subsys/mpsl/init/lib..__nrf__subsys__mpsl__init.a modules/nrf/subsys/mpsl/fem/lib..__nrf__subsys__mpsl__fem.a modules/nrf/subsys/ieee802154/lib..__nrf__subsys__ieee802154.a modules/nrf/drivers/mpsl/clock_control/lib..__nrf__drivers__mpsl__clock_control.a modules/nrf/drivers/mpsl/flash_sync/lib..__nrf__drivers__mpsl__flash_sync.a modules/nrf/drivers/mpsl/temp_nrf5/lib..__nrf__drivers__mpsl__temp_nrf5.a modules/nrf/drivers/hw_cc3xx/lib..__nrf__drivers__hw_cc3xx.a modules/openthread/platform/libopenthread_platform.a modules/hal_nordic/nrf_802154/libnrf-802154-platform.a modules/nrfxlib/nrf_802154/nrf_802154/driver/libnrf-802154-driver.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"c:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m+fp/hard" -LC:/Users/Z004S4BW/coap_server/build/zephyr -lgcc /example/datapoints/sub_system_adapter/libsubsystemadapter.a /example/utils/libexampleutils.a /example/daemon/platform/lib_daemon_platform.a /example/datapoints/app_db_interface/libdatabaseupdate.a /example/datapoints/database/libdatabase.a /src/server/libserver.a /src/libcore.a /src/libcore.a /third_party/connectedhomeip/libcrypto.a tinycbor/libTinyCBOR.a /platform/libpal.a -lstdc++ zephyr/arch/common/libisr_tables.a modules/nrfxlib/nrf_802154/nrf_802154/common/libnrf-802154-common.a modules/hal_nordic/nrf_802154/libnrf-802154-platform.a C:/ncs/v2.6.0/nrfxlib/nrf_802154/sl/sl/lib/nRF52840/hard-float/libnrf-802154-sl.a -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -lstdc++ -Wl,-no-pie -lm -Wl,-lc -L"C:/ncs/toolchains/cf2149caf2/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi"/lib/thumb/v7e-m+fp/hard -Wl,-lgcc -lc -specs=nano.specs modules/openthread/build/src/cli/libopenthread-cli-ftd.a modules/openthread/build/src/core/libopenthread-ftd.a modules/openthread/build/third_party/tcplp/libtcplp-ftd.a modules/openthread/build/src/core/libopenthread-ftd.a modules/openthread/build/third_party/tcplp/libtcplp-ftd.a modules/nrf/subsys/nrf_security/src/libmbedcrypto.a C:/ncs/v2.6.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/hard-float/no-interrupts/libnrf_cc310_platform_0.9.19.a C:/ncs/v2.6.0/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/hard-float/liboberon_mbedtls_3.0.14.a modules/nrf/subsys/nrf_security/src/libmbedcrypto_base.a -mcpu=cortex-m4 -mthumb -mabi=aapcs -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mfp16-format=ieee C:/ncs/v2.6.0/nrfxlib/crypto/nrf_oberon/lib/cortex-m4/hard-float/liboberon_3.0.14.a -lc C:/ncs/v2.6.0/nrfxlib/mpsl/fem/common/lib/cortex-m4/hard-float/libmpsl_fem_common.a C:/ncs/v2.6.0/nrfxlib/mpsl/fem/nrf21540_gpio/lib/cortex-m4/hard-float/libmpsl_fem_nrf21540_gpio.a C:/ncs/v2.6.0/nrfxlib/mpsl/fem/nrf21540_gpio_spi/lib/cortex-m4/hard-float/libmpsl_fem_nrf21540_gpio_spi.a C:/ncs/v2.6.0/nrfxlib/mpsl/fem/simple_gpio/lib/cortex-m4/hard-float/libmpsl_fem_simple_gpio.a C:/ncs/v2.6.0/nrfxlib/mpsl/lib/cortex-m4/hard-float/libmpsl.a
    OBJECT_DIR = zephyr\CMakeFiles\zephyr_pre0.dir
    POST_BUILD = cmd.exe /C "cd /D C:\Users\Z004S4BW\coap_server\build\zephyr && C:\ncs\toolchains\cf2149caf2\opt\bin\cmake.exe -E true"
    PRE_LINK = cd .
    RESTAT = 1
    TARGET_FILE = zephyr\zephyr_pre0.elf
    TARGET_PDB = zephyr_pre0.elf.dbg
    RSP_FILE = CMakeFiles\zephyr_pre0.rsp
    If you have included zephyr/kernel.h, and still see the k_malloc() undefined reference, you should check the following configuration:
    https://github.com/nrfconnect/sdk-zephyr/blob/v3.5.99-ncs1/kernel/mempool.c#L59
    Do you have CONFIG_HEAP_MEM_POOL_SIZE set to a non-zero value?
    Håkon
