I added build a conf to my project which has a prj.conf and select board. But the extension overwrites my configs with cache and extra cmake flags, which i dont want.
How can I disable auto configuration to prevent overwritings my configs?
You mean the Ektra Cmake arguments in your screenshot? If you hower over the argument you shold see a pencil icon and a cross icon to the right, an di fyou click the cross, you remove it. If this is not it, perhaps you can elaborate a bit more what the problem is?
It seems every time pristine build is called from the extension, it adds those arguments and changes the configuration dropdown to cached. This means we have edit the build configuration and remove the extra arguments and set the configuration file back to prj.conf every time they need to be updated.
Happens on Linux (Ubuntu 22.04) as well as Win 11.
I have not been able to reproduce this. Can you share wich nRF Connect SDK and which versino of the nRF Connect for VS Code plution you are using, along with exact steps on how to reproduce?
I did a little testing, and in the process the nRF Connect extension was reloaded and updated. It seems the prj.conf is at least refreshed if there's changes in the file, could be that my problem was elsewhere as I can't reproduce it.
Anyhow, the extensions still changes the "Configuration" to the "Use CACHED_CONF_FILE argument", though it might not be a problem in this case as the argument value points to the project prj.conf.
Visual Studio Code Version: 1.89.1 Commit: dc96b837cf6bb4af9cd736aa3af08cf8279f7685 Date: 2024-05-07T05:16:23.416Z (3 wks ago) Electron: 28.2.8 ElectronBuildId: 27744544 Chromium: 120.0.6099.291 Node.js: 18.18.2 V8: 12.0.267.19-electron.0 OS: Linux x64 5.15.0-89-generic (Ubuntu 22.04) nRF Connect for VS Code V2024.3.25 SDK & Toolchain 2.6.1
Steps to reproduce
-DBOARD_ROOT="/home/jyri/nrf_ws/serial_lte_modem" -Dmcuboot_OVERLAY_CONFIG="/home/jyri/ncs/v2.6.1/nrf/modules/mcuboot/tfm.conf;/home/jyri/ncs/v2.6.1/nrf/modules/mcuboot/fih_low_enable.conf;/home/jyri/ncs/v2.6.1/nrf/subsys/partition_manager/partition_manager_enabled.conf;/home/jyri/nrf_ws/serial_lte_modem/child_image/mcuboot.conf" -DCACHED_CONF_FILE="/home/jyri/nrf_ws/serial_lte_modem/prj.conf"
It seems this is working as intended, it's just that in the past (like a year or more back) I don't recall the extension adding those arguments, at least they weren't displayed while editing the build configuration
Thank you for the detailed description. I see the same now. This will be fixed in the next release of the extension and is also fixed in the latest pre-release version (so you can switch to that if you want, but note that the pre-release version may have other issues).
