Not able to determine BLE encryption after enabling from nrf SDKs
Hello All,
I am using nrf52805M from fanstel (LINK), and code which is based on nrf sdk softdevice S112.
Things works great normally, but in order to satisfy the cyber security requirements I am enabling BLE encryption and MIMA protection using below code in NRF sdk,
After enabling (just modified line 61 and 62 SEC_OPEN to SEC_MITM ) I am not able to communicate, when i write using the write characteristics using NRF CONNECT APP it says "Insufficient Encryption"
Do i need to modified anything else as well ?
uint32_t ble_nus_init(ble_nus_t * p_nus, ble_nus_init_t const * p_nus_init)
    ret_code_t            err_code;
    ble_uuid_t            ble_uuid;
    ble_uuid128_t         nus_base_uuid = NUS_BASE_UUID;
    ble_add_char_params_t add_char_params;
    printf("\nDbg8\n");
    VERIFY_PARAM_NOT_NULL(p_nus);
    VERIFY_PARAM_NOT_NULL(p_nus_init);
    // Initialize the service structure.
    p_nus->data_handler = p_nus_init->data_handler;
    /**@snippet [Adding proprietary Service to the SoftDevice] */
    // Add a custom base UUID.
    err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_nus->uuid_type);
    VERIFY_SUCCESS(err_code);
    ble_uuid.type = p_nus->uuid_type;
    ble_uuid.uuid = BLE_UUID_NUS_SERVICE;
    // Add the service.
    err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                        &ble_uuid,
                                        &p_nus->service_handle);
    // Add the RX Characteristic.
    memset(&add_char_params, 0, sizeof(add_char_params));
    add_char_params.uuid                     = BLE_UUID_NUS_RX_CHARACTERISTIC;
    add_char_params.uuid_type                = p_nus->uuid_type;
    add_char_params.max_len                  = BLE_NUS_MAX_RX_CHAR_LEN;
    add_char_params.init_len                 = sizeof(uint8_t);
    add_char_params.is_var_len               = true;
    add_char_params.char_props.write         = 1;
    add_char_params.char_props.write_wo_resp = 1;
    add_char_params.read_access  = SEC_OPEN;
    add_char_params.write_access = SEC_OPEN;
    err_code = characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->rx_handles);
    if (err_code != NRF_SUCCESS)
        return err_code;
    printf("\r\nRX UUID: %x\r\n", add_char_params.uuid);
    // Add the TX Characteristic.
    /**@snippet [Adding proprietary characteristic to the SoftDevice] */
    add_char_params.uuid              = BLE_UUID_NUS_TX_CHARACTERISTIC;
    add_char_params.max_len           = BLE_NUS_MAX_TX_CHAR_LEN;
    add_char_params.char_props.notify = 1;
    add_char_params.write_access      = SEC_MITM //enable encryption with MITM
    add_char_params.cccd_write_access = SEC_MITM //enable encryption with MITM
    printf("\r\nTX UUID: %x\r\n", add_char_params.uuid);
    return characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->tx_handles);
Below is the Definition for SEC_MITM
/**@brief Function for setting security requirements of a characteristic.
 * @param[in]  level   required security level.
 * @param[out] p_perm  Characteristic security requirements.
 * @return     encoded security level and security mode.
static inline void set_security_req(security_req_t level, ble_gap_conn_sec_mode_t * p_perm)
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(p_perm);
    switch (level)
        case SEC_NO_ACCESS:
        case SEC_OPEN:
            BLE_GAP_CONN_SEC_MODE_SET_OPEN(p_perm);
        case SEC_JUST_WORKS:
            BLE_GAP_CONN_SEC_MODE_SET_ENC_NO_MITM(p_perm);
        case SEC_MITM:
            BLE_GAP_CONN_SEC_MODE_SET_ENC_WITH_MITM(p_perm);
        case SEC_SIGNED:
            BLE_GAP_CONN_SEC_MODE_SET_SIGNED_NO_MITM(p_perm);
        case SEC_SIGNED_MITM:
            BLE_GAP_CONN_SEC_MODE_SET_SIGNED_WITH_MITM(p_perm);
    return;
