Good morning
Doing the BLE fundamentals course and cant seem to build lesson 4 ex 3. Have picked up this thread BLE Fundamentals lesson 4 exercise 3 failure to build - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com) with no solution.
using the latest tool chain, nrf52840DK 2.02.
The errors in the function below im receiving are
C:/ncs/v2.6.0/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "pointer type mismatch in CONTAINER_OF"
87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
in this line
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
ARG_UNUSED(dev);
static size_t aborted_len;
struct uart_data_t *buf;
static uint8_t *aborted_buf;
static bool disable_req;
switch (evt->type) {
case UART_TX_DONE:
LOG_DBG("UART_TX_DONE");
if ((evt->data.tx.len == 0) || (!evt->data.tx.buf)) {
return;
if (aborted_buf) {
buf = CONTAINER_OF(aborted_buf, struct uart_data_t, data);
aborted_buf = NULL;
aborted_len = 0;
} else {
buf = CONTAINER_OF(evt->data.tx.buf, struct uart_data_t, data);
k_free(buf);
buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
if (!buf) {
return;
if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
LOG_WRN("Failed to send data over UART");
case UART_RX_RDY:
LOG_DBG("UART_RX_RDY");
buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
buf->len += evt->data.rx.len;
if (disable_req) {
return;
if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
(evt->data.rx.buf[buf->len - 1] == '\r')) {
disable_req = true;
uart_rx_disable(uart);
case UART_RX_DISABLED:
LOG_DBG("UART_RX_DISABLED");
disable_req = false;
buf = k_malloc(sizeof(*buf));
if (buf) {
buf->len = 0;
} else {
LOG_WRN("Not able to allocate UART receive buffer");
k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
return;
uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_WAIT_FOR_RX);
case UART_RX_BUF_REQUEST:
LOG_DBG("UART_RX_BUF_REQUEST");
if (buf) {
buf->len = 0;
uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
} else {
case UART_RX_BUF_RELEASED:
LOG_DBG("UART_RX_BUF_RELEASED");
buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t, data);
if (buf->len > 0) {
/* STEP 9.1 - Push the data received from the UART peripheral into the fifo_uart_rx_data FIFO */
k_fifo_put(&fifo_uart_rx_data, buf);
} else {
k_free(buf);
case UART_TX_ABORTED:
LOG_DBG("UART_TX_ABORTED");
if (!aborted_buf) {
aborted_buf = (uint8_t *)evt->data.tx.buf;
aborted_len += evt->data.tx.len;
uart_tx(uart, &buf->data[aborted_len], buf->len - aborted_len, SYS_FOREVER_MS);
I have tried to build the solution as well with the same outcome
Thanks in advance for any assistance.
