systick sometime paused
Hi, i have run out of timers and would like to use SysTick to measure time.
It seems as SysTick counts a bit too slow which i assume is due to CPU entering sleep.
Does the SD 112 enter sleep such that the systick is paused? if so, is there any way to stop that?
is there any other reason for SysTick to be paused? for example reading from slower clocked peripherals?
    Systick is suspended during sleep, which is one of the reasons it is normally not used. If yo need more timers you can often achieve what you want by using the app timer library, where you can have an arbitrary number of "soft" timers based on a single RTC instance.
  • Hi
    I know that systick is suspended during sleep, does the SD 112 ever go in to sleep? and if so, can i controll that?
    I know about your app timer library. i want to measure time to the us level and are already using the timer 1 and 2 for pwm generation on 6 gpio so i cant use the HF timers and i cant use RTC as it is too slow.
    Not automatically, but in all low powe rapplications you will want to go to sleep (sytem ON low power mode). When using a SoftDevice that is done by calling sd_app_evt_wait(), but many examples call it indirectly via nrf_pwr_mgmt_run() from the power management module).
    I see. In that case perhaps an alternative could be to re-use a timer instance, for intance by using several CC registers (I don't know how you use the timer so it may not be suitable in your case).
