Zigbee router generates ZB_NWK_SIGNAL_NO_ACTIVE_LINKS_LEFT signal all the time
Hello everyone,
I'm encountering an issue with my Zigbee network that I hope someone can assist me with. Despite my efforts, I haven't been able to find a resolution.
I'm using two nrf52840 DK boards, one serving as the coordinator and the other as a router. Initially, the router successfully joins the network, but I consistently receive the ZB_NWK_SIGNAL_NO_ACTIVE_LINKS_LEFT signal thereafter. Strangely, the state signal appears to be normal. I've attached a Wireshark log along with logs from both the router and coordinator for further reference.
Any insights or assistance on resolving this would be greatly appreciated.
Thank you,
Julen
*** Booting nRF Connect SDK v2.5.1 ***
[00:00:00.012,420] <err> main: RESET
[00:00:00.012,451] <dbg> main: get_reset_reason: Reset cause is: RESET_PIN
[00:00:00.012,481] <inf> nvram_app: Page info: size 4096, start offset 1024000
[00:00:00.012,542] <dbg> fs_nvs: nvs_recover_last_ate: Recovering last ate from sector 0
[00:00:00.020,568] <inf> fs_nvs: 3 Sectors of 4096 bytes
[00:00:00.020,599] <inf> fs_nvs: alloc wra: 0, fc8
[00:00:00.020,599] <inf> fs_nvs: data wra: 0, 2c
[00:00:00.020,629] <inf> nvram_app: NVRAM initialized
[00:00:00.020,690] <inf> zb_conf: NVRAM first id is correct
[00:00:00.020,751] <dbg> zb_conf: zb_conf_read_from_nvram: Extended PAN ID:
                                  88 88 00 00 00 00 00 00                          |........
[00:00:00.020,751] <wrn> zb_conf: Reading Node Identifier from NVRAM
[00:00:00.020,812] <wrn> zb_conf: Node Identifier:
[00:00:00.020,812] <wrn> zb_conf: Size of Node Identifier: 21
[00:00:00.020,874] <inf> zb_conf: Node Identifier: TCU_SUNNER_ID_198
[00:00:00.020,935] <dbg> zb_conf: zb_get_mac_addr_high: Zigbee long address:
[00:00:00.020,965] <dbg> zb_conf: zb_get_mac_addr_high: MAC address:
                                  a2 46 b3 cc 1f 36 ce f4                          |.F...6..
[00:00:00.020,996] <dbg> zb_conf: zb_get_mac_addr_high: MAC address:
                                  1f 36 ce f4                                      |.6..
[00:00:00.021,026] <dbg> zb_conf: zb_get_mac_addr_low: Zigbee long address:
[00:00:00.021,057] <dbg> zb_conf: zb_get_mac_addr_low: MAC address:
                                  f4 ce 36 1f cc b3 46 a2                          |..6...F.
[00:00:00.021,087] <dbg> zb_conf: zb_get_mac_addr_low: MAC address:
                                  a2 46 b3 cc                                      |.F..
[00:00:00.021,301] <inf> main: Router started successfully
[00:00:00.703,521] <wrn> main: SIGNAL 23 , state not OK
[00:00:00.703,552] <inf> zigbee_app_utils: Production configuration is not present or invalid (status: -1)
[00:00:00.704,132] <wrn> main: SIGNAL 1 , state OK
[00:00:00.704,162] <wrn> main: Parent Node: 0xffff
[00:00:00.704,193] <inf> zigbee_app_utils: Zigbee stack initialized
[00:00:00.710,998] <wrn> main: SIGNAL 5: Device started for the first time after the NVRAM erase
[00:00:00.710,998] <inf> zigbee_app_utils: Device started for the first time
[00:00:00.711,029] <inf> zigbee_app_utils: Start network steering
[00:00:00.711,059] <inf> zigbee_app_utils: Started network rejoin procedure.
[00:00:10.304,534] <dbg> main: diagnostic_zigbee_info: Zigbee application joined the network: bellow some info:
[00:00:10.304,565] <dbg> main: diagnostic_zigbee_info: zigbee shrot addr:  0xa1ee
[00:00:10.304,595] <dbg> main: diagnostic_zigbee_info: Extended PAN ID:
                               00 00 00 00 00 00 88 88                          |........
[00:00:10.304,626] <dbg> main: diagnostic_zigbee_info: zigbee role router
[00:00:10.304,626] <dbg> main: diagnostic_zigbee_info: zigbee channel: 23
[00:00:10.974,975] <wrn> main: SIGNAL 54 , state OK
[00:00:10.974,975] <wrn> main: Parent Node: 0x0000
[00:00:10.975,006] <inf> zigbee_app_utils: Unimplemented signal (signal: 54, status: 0)
[00:00:11.435,241] <wrn> main: SIGNAL 54 , state OK
[00:00:11.435,272] <wrn> main: Parent Node: 0x0000
[00:00:11.435,302] <inf> zigbee_app_utils: Unimplemented signal (signal: 54, status: 0)
[00:00:11.438,323] <wrn> main: SIGNAL 10 , state OK
[00:00:11.438,354] <wrn> main: Parent Node: 0x0000
[00:00:11.438,385] <wrn> main: Device is encountering issues during steering.
[00:00:11.438,598] <inf> zigbee_app_utils: Joined network successfully (Extended PAN ID: 0000000000008888, PAN ID: 0x1226)
[00:00:11.438,598] <inf> zigbee_app_utils: Network rejoin procedure stopped.
[00:01:00.002,471] <dbg> main: display_counters: APS RX COUNTERS: Total 0, Binary 0, Commis 0
[00:01:00.002,502] <dbg> main: display_counters: Uart frames: Tx 0, Rx 0
[00:01:10.901,214] <wrn> main: SIGNAL 24 , state OK
[00:01:10.901,245] <wrn> main: Parent Node: 0x0000
[00:01:10.901,275] <wrn> main: Device is encountering issues during steering.
[00:01:10.901,275] <wrn> zigbee_app_utils: Parent is unreachable
[00:01:25.868,591] <wrn> main: SIGNAL 24 , state OK
[00:01:25.868,621] <wrn> main: Parent Node: 0x0000
[00:01:25.868,621] <wrn> main: Device is encountering issues during steering.
[00:01:25.868,652] <wrn> zigbee_app_utils: Parent is unreachable
[00:01:40.828,735] <wrn> main: SIGNAL 24 , state OK
[00:01:40.828,765] <wrn> main: Parent Node: 0x0000
[00:01:40.828,796] <wrn> main: Device is encountering issues during steering.
[00:01:40.828,796] <wrn> zigbee_app_utils: Parent is unreachable
[00:01:55.835,479] <wrn> main: SIGNAL 24 , state OK
[00:01:55.835,510] <wrn> main: Parent Node: 0x0000
[00:01:55.835,510] <wrn> main: Device is encountering issues during steering.
[00:01:55.835,540] <wrn> zigbee_app_utils: Parent is unreachable
[00:02:00.004,760] <dbg> main: display_counters: APS RX COUNTERS: Total 0, Binary 0, Commis 0
[00:02:00.004,821] <dbg> main: display_counters: Uart frames: Tx 0, Rx 0
[00:02:10.808,898] <wrn> main: SIGNAL 24 , state OK
[00:02:10.808,929] <wrn> main: Parent Node: 0x0000
[00:02:10.808,929] <wrn> main: Device is encountering issues during steering.
[00:02:10.808,959] <wrn> zigbee_app_utils: Parent is unreachable
[00:02:25.789,459] <wrn> main: SIGNAL 24 , state OK
[00:02:25.789,489] <wrn> main: Parent Node: 0x0000
[00:02:25.789,489] <wrn> main: Device is encountering issues during steering.
[00:02:25.789,520] <wrn> zigbee_app_utils: Parent is unreachable
[00:02:40.772,369] <wrn> main: SIGNAL 24 , state OK
[00:02:40.772,430] <wrn> main: Parent Node: 0x0000
[00:02:40.772,430] <wrn> main: Device is encountering issues during steering.
[00:02:40.772,460] <wrn> zigbee_app_utils: Parent is unreachable
[00:02:55.740,661] <wrn> main: SIGNAL 24 , state OK
[00:02:55.740,692] <wrn> main: Parent Node: 0x0000
[00:02:55.740,692] <wrn> main: Device is encountering issues during steering.
ZB_NWK_SIGNAL_NO_ACTIVE_LINKS_LEFT_LOG.pcapng
W: JULEN ZB_ZDO_SIGNAL_DEVICE_AUTHORIZED
I: Device authorization event received (short: 0xd239, long: f4ce361fccb346a2, authorization type: 0, authorization status: 0)
I: Unimplemented signal (signal: 54, status: 0)
I: Network steering finished
I: nRF5 802154 radio initialized
I: Starting ZBOSS Coordinator example
I: ZBOSS Coordinator example started
W: JULEN ZB_ZDO_SIGNAL_PRODUCTION_CONFIG_READY
I: Production configuration is not present or invalid (status: -1)
W: JULEN ZB_ZDO_SIGNAL_SKIP_STARTUP
I: Zigbee stack initialized
I: Device started for the first time
I: Start network formation
W: JULEN ZB_BDB_SIGNAL_FORMATION
I: Network formed successfully, start network steering (Extended PAN ID: 0000000000008888, PAN ID: 0x1226)
I: Allow pre-Zigbee 3.0 devices to join the network
I: Network steering started
W: JULEN ZB_NWK_SIGNAL_DEVICE_ASSOCIATED
W: Obsolete signals, used for pre-R21 ZBOSS API. Ignore
W: JULEN ZB_ZDO_SIGNAL_DEVICE_UPDATE
I: Device update received (short: 0x5710, long: f4ce361fccb346a2, status: 1)
I: Device authorization event received (short: 0x5710, long: f4ce361fccb346a2, authorization type: 0, authorization status: 0)
I: Top level commissioning restated
I: Device update received (short: 0xa1ee, long: f4ce361fccb346a2, status: 1)
I: Device authorization event received (short: 0xa1ee, long: f4ce361fccb346a2, authorization type: 0, authorization status: 0)
    All devices are currently within radio range. Every time we restart the device, we clear out old factory data using zb_set_nvram_erase_at_start(ZB_TRUE). I'd like to confirm if this approach aligns with best practices.
    Julen
  • Hello Julen,
    And are all the devices reset at once? If they are reset one by one, it could lead to some weird behavior, if one device is reset, but the other device thinks it is still part of the network, perhaps starting the onboarding process for the newly reset device, and then you reset the other device as well. In this case, the device that was reset first will be halfway through the commissioning process, and the device reset last will not know about this.
    Can you try to erase all the devices (nrfjprog --eraseall) and then re-program them? Does it behave the same then? As long as all the devices are erased at the same time, we can rule out that there is some old network data in the loop.
    Also, properly erasing the device using a programmer can rule out whether the zb_set_nvram_erase_at_start() completes successfully or not. For debugging purposes.
    When you get this all working properly, it would be sufficient to halt all the devices before you start resetting them (nrfjprog --halt)
    Edvin
  • Dear Edvin,
    I've identified the error. The problem arose when trying to connect a router with encryption disabled to an encrypted network. In the past, encountering this issue would result in the router leaving the network with some messagges related to transportation key  However, this time, that didn't appear so I didn't realize the problem could be related to encryption.
    I truly appreciate your efforts to help resolve this issue.
    Julen
