I want to develop a device using nRF52833. I am using QFN40, so can I use two UART connections. If yes, then what are the Tx, Rx pins for both the UART's
Can I use GPIO Standard drive, low frequency I/O for LED, Switch
Yes, as long as the switching frequency of the pin is below 10kHz and you do not draw large current from the pin (standard drive can source/sink a maximum of 1-4mA according to GPIO Electrical Specification).
what are the pins need to consider while i need to flash program from nRF52840 DK to external nRF52833 QDAA QFN40 SOC and share the procedure
Sai Mukesh said:what are the pins need to consider while i need to flash program from nRF52840 DK to external nRF52833 QDAA QFN40 SOC and share the procedure
Make the following connections:
The VTG/SWDIO/SWDCLK pins are available on P20 header on nRF52840 DK.
as of know we dont had any soc but we had two development kits i.e. nRF52840 and nRF52833 both are DK's. now tried flashing the program form nRF52840DK of debug out (P20) to nRF52833DK debug in with help of 10pin bus cable .but we are facing the below issue
could please help us .
Flashing build_1 to 1050257546
C:\WINDOWS\system32\cmd.exe /d /s /c "west flash -d c:\Users\Pranathi\central_2\build_1 --skip-rebuild --dev-id 1050257546 --erase"
-- west flash: using runner nrfjprog
-- runners.nrfjprog: mass erase requested
-- runners.nrfjprog: Flashing file: c:\Users\Pranathi\central_2\build_1\zephyr\zephyr.hex
[error] [ Client] - Encountered error -102: Command read_device_info executed for 139 milliseconds with result -102
[error] [ Worker] - An unknown error.
[error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 31 milliseconds with result -102
Failed to read device memories.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program 'c:\Users\Pranathi\central_2\build_1\zephyr\zephyr.hex' --chiperase --verify -f NRF52 --snr 1050257546
