Configuration for native tls (no offload to modem)
Dear Support-Team,
due to the 2KB limitation of the secure buffers of the nrf9160 modem I am trying to setup native tls. I found the https_client sample which sounded promising, but when I use the same configuration as described in the sample (prj.conf + overlay-tfm_mbedtls.conf) I get a "region FLASH overflow", so I am a trying to figure out which settings do what.
Using https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.5.0/kconfig/index.html does not help as the description gives no clue at all:
Examples:
CONFIG_NRF_SECURITY_ADVANCED
Advanced mbed TLS Configuration Settings
This configuration has no effect and will be deprecated. It is kept in to ensure projects setting this aren't affected.
or
CONFIG_TFM_PROFILE_TYPE_NOT_SET
TF-M build profile is not set
Is there any other documentation for those configurations?
Best regards
Context: I am working on a MQTT project and I have provisioned the certificates to the modem. With setting set_native_tls in the mqtt_sec_config struct I am able to connect to the server and get the data I expect (> offloading to the modem). Now I have to change to native tls in order to receive some other data which does not fit into the 2kB secure buffer of the modem.
    How much are you overflowing with?
    You can adjust the size of TFM using this configuration:
    CONFIG_PM_PARTITION_SIZE_TFM
    Note that the alignment can be a bit tricky here, especially when combining this with mcuboot.
    Try for instance 0x27E00 if you're building with mcuboot.
    Håkon
  • Hi Håkon,
    thanks a lot for your suggestion. I am currently using the https_client demo and reverse engineer the meaning of the different CONFIG options used there.
    Resizing a partition might be an option, but resizing because I don't know how to configure the mbed tls library is not a solution.
    Thanks
    Stefan
    Can you share the build output?
    Håkon
     I can share my configuration and the final build output. With this configuration (related to mbedTLS)
    # MbedTLS and security
    CONFIG_TFM_PROFILE_TYPE_MINIMAL=y
    CONFIG_MBEDTLS_ENABLE_HEAP=y
    CONFIG_MBEDTLS_SSL_IN_CONTENT_LEN=8192
    CONFIG_MBEDTLS_SSL_OUT_CONTENT_LEN=4096
    CONFIG_MBEDTLS_HEAP_SIZE=32768
    CONFIG_MBEDTLS_RSA_C=y
    CONFIG_MBEDTLS_GCM_C=y
    CONFIG_MBEDTLS_DHM_C=y
    CONFIG_MBEDTLS_TLS_LIBRARY=y
    CONFIG_MBEDTLS_X509_LIBRARY=y
    CONFIG_MBEDTLS_X509_REMOVE_INFO=y
    CONFIG_MBEDTLS_PKCS1_V15=y
    CONFIG_NRF_SECURITY=y
    CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
    I get this build output:
    [153/157] Linking C executable bin/tfm_s.axf
    Memory region         Used Size  Region Size  %age Used
               FLASH:       64332 B      65024 B     98.94%
                 RAM:       18888 B        32 KB     57.64%
    [433/444] Linking C executable zephyr/zephyr.elf
               FLASH:      349572 B       352 KB     96.98%
                 RAM:      150204 B     211608 B     70.98%
            IDT_LIST:          0 GB         2 KB      0.00%
  • Ok, when I remove
    CONFIG_DEBUG=y
    CONFIG_DEBUG_INFO=y
    CONFIG_DEBUG_THREAD_INFO=y
    I get
    FLASH: 31544 B 32256 B 97.79%
    RAM: 14736 B 32 KB 44.97%
    and
    FLASH: 276600 B 384 KB 70.34%
    RAM: 149948 B 211608 B 70.86%
