[SOLVED] Compile error with nRF5 SDK - nrf_log_frontend
Hi everyone,
I try to compile a couple of examples which include the nrf_log_frontend.c and they all fail with the same error:
Compiling file: nrf_log_frontend.c
In function 'nrf_log_module_name_get',
    inlined from 'module_name_get' at ../../../../../../components/libraries/log/src/nrf_log_frontend.c:1361:26:
../../../../../../components/libraries/log/src/nrf_log_frontend.c:219:29: error: array subscript 'nrf_log_module_const_data_t[0]' is partly outside array bounds of 'nrf_log_module_const_data_t[0]' [-Werror=array-bounds=]
  219 |         return p_module_data->p_module_name;
The complete error log is in the attached files,
The example used in that case was /examples/peripheral/usbd_cdc_acm/pca10056/blank/armgcc
Other examples without the logger work perfectly.
Fresh download of the SDK, v17.1.0 Same issue with v16.0.0, just on a different line
The only thing changed is the path of the compiler in /sdk/components/toolchain/gcc/Makefile.posix
GNU_INSTALL_ROOT ?= /usr/local/bin/
GNU_VERSION ?= 13.2.1
GNU_PREFIX ?= arm-none-eabi
Any idea about that?
Thanks
8081.nrf5_sdk.log.zip
