I was followed the dev academy nordic course and error was appear only when I flash the project uses "tread" or multithreading.
It seems it can not connect the J-link, Although was successful in other projects.
When I use the debugger it is jump to this function:
static ALWAYS_INLINE void arch_nop(void)
__asm__ volatile("nop");
When i flash the project:
* Executing task: nRF Connect: Flash: fund_less7_exer1/build (active) Flashing build to 1050207889 west flash -d /Users/Documents/nRFworkspace/DevAcademy/ncs-fund/v2.x.x/lesson7/fund_less7_exer1/build --skip-rebuild --dev-id 1050207889 -- west flash: using runner nrfjprog -- runners.nrfjprog: Flashing file: /Users/Documents/nRFworkspace/DevAcademy/ncs-fund/v2.x.x/lesson7/fund_less7_exer1/build/zephyr/zephyr.hex [error] [ Client] - Encountered error -105: Command connect_to_emu_with_snr executed for 14730 milliseconds with result -105 ERROR: Unable to connect to a debugger. [error] [ Worker] - JLinkARM.dll Open returned error 'Cannot connect to J-Link.' ERROR: The JLinkARM DLL timed out while communicating to the J-Link probe. ERROR: If the error condition persists, run the same command again with ERROR: argument -- log, contact Nordic Semiconductor and provide the generated ERROR: log.log file to them. NOTE: For additional output, try running again with logging enabled (--log). NOTE: Any generated log error messages will be displayed. FATAL ERROR: command exited with status 35: nrfjprog --program /Users/Documents/nRFworkspace/DevAcademy/ncs-fund/v2.x.x/lesson7/fund_less7_exer1/build/zephyr/zephyr.hex --sectoranduicrerase --verify -f NRF52 --snr 1050207889 * The terminal process terminated with exit code: 35. * Terminal will be reused by tasks, press any key to close it.
Any help? Thanks
