Trying to implement longpress function for keypad, but don't know what to set in the device tree for input-device
I'm running V2.60 NCD on a custom n5340 processor and I can't decipher what is the proper device tree based on the examples.
I have a 10 button keypad and want to detect short and long presses on all the keys.
i tried the test suite code here: v2.6.0\zephyr\tests\subsys\input\input_longpress  which runs (simulating keypresses) and I get the test_cb() to execute.  I can read the keypad via
gpio_pin_get_dt() manually, so I know that is all connected ok.
 Here is the zephyr testsuite code and their devicetree
tatic const struct device *const fake_dev = DEVICE_DT_GET(
		DT_NODELABEL(fake_input_device));
static const struct device *const longpress_dev = DEVICE_DT_GET(
		DT_NODELABEL(longpress));
DEVICE_DT_DEFINE(DT_INST(0, vnd_input_device), NULL, NULL, NULL, NULL,
		 PRE_KERNEL_1, CONFIG_KERNEL_INIT_PRIORITY_DEVICE, NULL);
static int event_count;
static struct input_event last_events[2];
static void test_cb(struct input_event *evt)
	TC_PRINT("%s: %d %x %d\n", __func__, event_count, evt->code, evt->value);
	event_count++;
	memcpy(&last_events[1], &last_events[0], sizeof(struct input_event));
	memcpy(&last_events[0], evt, sizeof(struct input_event));
INPUT_CALLBACK_DEFINE(longpress_dev, test_cb);
Their Device tree
#include <zephyr/dt-bindings/input/input-event-codes.h>
	fake_input_device: fake-device {
		compatible = "vnd,input-device";
	longpress: longpress {
		input = <&fake_input_device>;
		compatible = "zephyr,input-longpress";
		input-codes = <INPUT_KEY_0>, <INPUT_KEY_1>;
		short-codes = <INPUT_KEY_A>, <INPUT_KEY_B>;
		long-codes = <INPUT_KEY_X>, <INPUT_KEY_Y>;
		long-delay-ms = <100>;
I used that same code changing from the "fake" names to mine, but  but I get this error during build:
C:/ncs/v2.6.0/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "zephyr-code must be specified to use the input-gpio-keys driver".
here's my devicetree file.  I don't know what to use for the kp_input_device compatible value (probably causing the error?).  The test code uses "vnd,input-device" which is a dummy device for test suite.
 my device tree
	buttons: buttons {
		 compatible = "gpio-keys";
		 btntopleft: button_0 {
			gpios = <&gpio0 23 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "BTN_TOP_LEFT";
			zephyr,code = <INPUT_KEY_0>;
		btntopmid: button_1 {
			gpios = <&gpio1 5 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "BTN_TOP_MIDDLE";
			zephyr,code = <INPUT_KEY_1>;
		btntopright: button_2 {
			gpios = <&gpio1 7 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "BTN_TOP_RIGHT";
			zephyr,code = <INPUT_KEY_2>;
		btnleft: button_3 {
			gpios = <&gpio1 9 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "BTN_LEFT";
			zephyr,code = <INPUT_KEY_3>;
		btndpadleft: button_4 {
			gpios = <&gpio0 24 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "BTN_DPAD_LEFT";
			zephyr,code = <INPUT_KEY_4>;
		btndpadtop: button_5 {
			gpios = <&gpio0 25 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "BTN_DPAD_TOP";
			zephyr,code = <INPUT_KEY_5>;
		btndpadright: button_6 {
		   	gpios = <&gpio0 26 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
		   	label = "BTN_DPAD_RIGHT";
			   zephyr,code = <INPUT_KEY_6>;
		 btndpadbot: button_7 {
			gpios = <&gpio0 28 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "BTN_DPAD_BOTTOM";
			zephyr,code = <INPUT_KEY_7>;
		 btnright: button_8 {
			gpios = <&gpio0 27 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			label = "BTN_RIGHT";
			zephyr,code = <INPUT_KEY_8>;
		 btnbot: button_9 {
//			gpios = <&gpio0 29 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
			gpios = <&gpio1 10 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;		// trigger for testing
			label = "BTN_BOTTOM";
			zephyr,code = <INPUT_KEY_9>;
	kp_input_device: kp-device {
		input = <&kp_input_device>;
        input-codes = <INPUT_KEY_0>,<INPUT_KEY_1>,<INPUT_KEY_2>,<INPUT_KEY_3>,<INPUT_KEY_4>,<INPUT_KEY_5>,<INPUT_KEY_6>,<INPUT_KEY_7>,<INPUT_KEY_8>, <INPUT_KEY_9>;
        short-codes = <INPUT_KEY_A>,<INPUT_KEY_B>,<INPUT_KEY_C>,<INPUT_KEY_D>,<INPUT_KEY_E>,<INPUT_KEY_F>,<INPUT_KEY_G>,<INPUT_KEY_H>,<INPUT_KEY_I>, <INPUT_KEY_J>;
		long-codes  = <INPUT_KEY_K>,<INPUT_KEY_L>,<INPUT_KEY_M>,<INPUT_KEY_N>,<INPUT_KEY_O>,<INPUT_KEY_P>,<INPUT_KEY_Q>,<INPUT_KEY_R>,<INPUT_KEY_S>, <INPUT_KEY_T>;
        long-delay-ms = <1000>;
my longpress code
#include <zephyr/device.h>
#include <zephyr/input/input.h>
#include <zephyr/kernel.h>
//#include <zephyr/ztest.h>
LOG_MODULE_REGISTER(longpress, LOG_LEVEL_INF);
static const struct device *const kp_dev = DEVICE_DT_GET(
		DT_NODELABEL(kp_input_device));
static void longpress_cb(struct input_event *evt)
	printk("%s: %d %x %d\n", __func__, event_count, evt->code, evt->value);
	event_count++;
INPUT_CALLBACK_DEFINE(longpress_dev, longpress_cb);
there is a good example code here: \v2.6.0\zephyr\subsys\input that has all the processing inside, but this has the same problem as above.
thanks
  • here's the code where I get the keys from the device tree in case I'm missing something...
     static const struct gpio_dt_spec key_topleft = GPIO_DT_SPEC_GET(DT_NODELABEL(btntopleft), gpios);
     gpio_pin_configure_dt(&key_topleft, GPIO_INPUT);
  • thanks Siguard.  That is working, but I was trying to use the longpress feature in the devicetree (using CONFIG_INPUT=y).  I thought that would be an easier way.  The other question using the longpress feature, if it would work to detect two buttons pressed together.  I'll stay with your solution unless I hear otherwise.
  •   You should pass a different phandle (buttons) to the longpress device to be as an input reference (input = <&buttons>). So your device tree will look like this:
    	buttons: buttons {
    		btnleft: button_3 {
    			label = "BTN_LEFT";
    		 btnbot: button_9 {
        // No need for kp_input_device
    		input = <&buttons>;
    In your source code you don't need lines
    and
    since your keypad device is actually buttons and they've already been instantiated by Zephyr.
    Thanks!
