ANCS problem
Hi all, I find a problem when testing the ANCS program. It seems that after you connect the device with ANCS with an iphone, you cannot connect the device with another iphone even if you forget the device on settings. And I find that if you want to pair with another iphone, you need to select the device on settings again and when the dialog box appears to remind you of pairing or not, choose "cancel" to cancel the pairing. Then you can pair with another iphone. Now the question is that I want to directly pair with another iphone, simply after I forget the device on settings without the following operation. How can I modify the program? SDK version:9.0.0 SoftDevice version:8.0 Best Regards!
