MCUBoot stuck in BOOT_UPGRADE_TEST swap loop after upgrade
Trying to implement FOTA DFU over BLE.
My application uses my proprietary code (instead of mcumgr) to download signed OTA firmware image to secondary slot (in my case it is located in external flash)
After image download is complete and checksum is verified, application calls
int rc = boot_request_upgrade_multi(0, BOOT_UPGRADE_TEST);
if (rc) {
    printk("failed to request image update\n");
} else {
    printk("Rebooting to complete firmware update\n");
    sys_reboot(SYS_REBOOT_COLD);
Upon reboot MCUBoot does what it needs to do, validates image, performs swap between slots and correctly boots downloaded image (which is now in primary slot)
That image, almost immediately upon start (while still in main function ) calls
#if defined(CONFIG_MCUBOOT_IMG_MANAGER)
if (!boot_is_img_confirmed()) {
     printk("Image is not confirmed, so confirm\n");
     int err = boot_write_img_confirmed();
     if (err) {
          printk("Error: couldn't confirm this image: %d\n", err);
} else {
     printk("Image is already confirmed\n");
(I verified that this code is indeed executed)
which causes write image_ok = BOOT_FLAG_SET (1) to be written to primary slot header
After this, I would expect subsequent reboots to NOT perform additional swaps, as the image is confirmed as good, so upon reboot I expect the image that is now in primary slot (which is result of FOTA DFU) to be booted. At least this is how I understood BOOT_UPGRADE_TEST is expected to work.
Unfortunately that is not what is happening...
Subsequent reset causes another swap, as the code in boot_prepare_image_for_update ---> boot_validated_swap_type
keep determining that BOOT_SWAP_TYPE(state) == BOOT_SWAP_TYPE_TEST
Upon code inspection, I see why it happens,
My primary slot state is: magic==GOOD, image_ok==1(SET), copy_done==1(SET)
My secondary slot state is: magic=GOOD, image_ok==3(UNSET), copy_done=3(UNSET)
Table #0 in boot_swap_tables[] matches the state of my primary and secondary slots
.magic_primary_slot = BOOT_MAGIC_ANY,
.magic_secondary_slot = BOOT_MAGIC_GOOD,
.image_ok_primary_slot = BOOT_FLAG_ANY,
.image_ok_secondary_slot = BOOT_FLAG_UNSET,
.copy_done_primary_slot = BOOT_FLAG_ANY,
.swap_type = BOOT_SWAP_TYPE_TEST,
That brings my question: what steps am I missing ? Do I need to alongside calling boot_write_img_confirmed() also mark secondary slot somehow as invalid to avoid swap on next reboot ?
I don't see any examples that do that...
But I don't see how one can get out this forever swap
  • Hi Alex_S@Aperia,
    My apology for the long wait. I have not fully figure out this issue yet.
    I will continue to look into it, and keep you more regularly update. I will return no later than end of Wednesday.
  • Hi Alex_S@Aperia,
    Thank you for your patience.
    I cannot figure out any issue from looking at the SDK code.
    How did you get the state of the images as you listed?
    I think it would be helpful to look at how the image header fields are changed over time.
    Could you please setup this test:
    • Enable MCUmgr and the Image Management Group of commands.
    • Enable MCUboot debug level logging.
    • Check the image status at the following points:
      • After download is completed.
      • After the new image is swapped, before the confirmation.
      • After the new image is swapped and confirmed.
      • After the issue happen, and the old image is swapped in,
    The reason I mentioned MCUmgr is because I usually use it for this kind of probing. If you have used a different method, this is also an opportunity to check if there is any mismatch.
    Please also retrieve the MCUboot debug level log.
    My apology again for the long wait.
    Hieu
  • Have you checked that the stock image (the one flashed with a programmer) has the same partition map as the image you're sending OTA?
    I had a similar issue where devices seemed to do FOTA just fine, boot_img_confirm() ran without issues, but devices still reverted at the next reboot. This was because the images were built with different partitions, and unlike with ESP-IDF, the partition table is not saved in the flash as a separate file but used while compiling the image, the FOTA application wrote the confirmation in the wrong place, and at the reboot the mcuboot checked a trailer at different address, which was still untouched.
    So check that you have a pm_static.yml, at least for the relevant partitions, if not, compare the mapping in the build ouput files between the stock and FOTA builds.
  • Hi Jiri !
    Thanks for the suggestion.
    I'll double check, but the images should have the same partition map, as both are built with the same pm_static.yml.
    But I double check explicitly by making a fresh build
    (the image I'm sending with OTA is embedded in mobile app, which makes logistics of updating it complicated)
  • For me this happened when I upgraded the SDK, and mcuboot was updated as well. This resulted in having newly flashed development units and older deployed devices in the field having different versions installed, and the older ones have a single-stage immutable bootloader.
    Fortunately, with the partitions now statically defined both work with the same app images.
