MCUBoot stuck in BOOT_UPGRADE_TEST swap loop after upgrade
Trying to implement FOTA DFU over BLE.
My application uses my proprietary code (instead of mcumgr) to download signed OTA firmware image to secondary slot (in my case it is located in external flash)
After image download is complete and checksum is verified, application calls
int rc = boot_request_upgrade_multi(0, BOOT_UPGRADE_TEST);
if (rc) {
    printk("failed to request image update\n");
} else {
    printk("Rebooting to complete firmware update\n");
    sys_reboot(SYS_REBOOT_COLD);
Upon reboot MCUBoot does what it needs to do, validates image, performs swap between slots and correctly boots downloaded image (which is now in primary slot)
That image, almost immediately upon start (while still in main function ) calls
#if defined(CONFIG_MCUBOOT_IMG_MANAGER)
if (!boot_is_img_confirmed()) {
     printk("Image is not confirmed, so confirm\n");
     int err = boot_write_img_confirmed();
     if (err) {
          printk("Error: couldn't confirm this image: %d\n", err);
} else {
     printk("Image is already confirmed\n");
(I verified that this code is indeed executed)
which causes write image_ok = BOOT_FLAG_SET (1) to be written to primary slot header
After this, I would expect subsequent reboots to NOT perform additional swaps, as the image is confirmed as good, so upon reboot I expect the image that is now in primary slot (which is result of FOTA DFU) to be booted. At least this is how I understood BOOT_UPGRADE_TEST is expected to work.
Unfortunately that is not what is happening...
Subsequent reset causes another swap, as the code in boot_prepare_image_for_update ---> boot_validated_swap_type
keep determining that BOOT_SWAP_TYPE(state) == BOOT_SWAP_TYPE_TEST
Upon code inspection, I see why it happens,
My primary slot state is: magic==GOOD, image_ok==1(SET), copy_done==1(SET)
My secondary slot state is: magic=GOOD, image_ok==3(UNSET), copy_done=3(UNSET)
Table #0 in boot_swap_tables[] matches the state of my primary and secondary slots
.magic_primary_slot = BOOT_MAGIC_ANY,
.magic_secondary_slot = BOOT_MAGIC_GOOD,
.image_ok_primary_slot = BOOT_FLAG_ANY,
.image_ok_secondary_slot = BOOT_FLAG_UNSET,
.copy_done_primary_slot = BOOT_FLAG_ANY,
.swap_type = BOOT_SWAP_TYPE_TEST,
That brings my question: what steps am I missing ? Do I need to alongside calling boot_write_img_confirmed() also mark secondary slot somehow as invalid to avoid swap on next reboot ?
I don't see any examples that do that...
But I don't see how one can get out this forever swap
  • After reading this
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/mcuboot/design.html#boot-swap-types
    it appears that my problem is caused by the fact that original TEST swap was supposed to set
    secondary_slot.magic = UNSET
    whereas mine is set to proper BOOT_MAGIC value
    Not sure how that could have happened, I haven't made any changes to my SDK code (v2.1.2)
    Is that something that I should do manually after swap ?
    I don't see existing public APIs allowing application to do that, but I can implement my own boot_unset_secondary_magic() or somethign like that
  • int err = boot_write_img_confirmed();
    if (err) {
    /* Erase first sector of secondary MCUBoot slot */
    spi_flash_erase_sector(0, 0, 0);  <-----------------------------------------
    This wipes out entire trailer, which solves the problem
    Still, this looks liek a silly workaround, there must be a proper way to confirm image and stop MCUBoot from swapping on every reboot
  • Hi Alex_S@Aperia,
    I will need more time to look into this. Could you please let me know which version of the nRF Connect SDK you are using?
    You likely know this already, but this invalidates the secondary slot, which would be holding the original application before the DFU. This would make it entirely impossible to revert to the original application. Unless this is something you can accept for sure, I can't really recommend it.
    Hieu
  • Hi Hieu,
    2.1.2
    As you can see I only do it when I confirm the image in primary slot, which means I'm happy with what is in primary slot  and no longer need to revert.
    My point is - this is just a workaround, I shouldn't have to do this erase
    If bootloader would mark the secondary slot image as UNSET after swap - as it should have according to
    then after first swap (doe to BOOT_UPGRADE_TEST) and subsequent confirmation the image in primary slot would become permanent. But in my case I see that secondary slot image magic is GOOD, so it continues swapping on every reboot
  • Hi Hieu !
    Just wondering if you had a chance to take a look and/or have any update on this ?
    I would rather not use the described workaround...
    As you pointed out -
    I totally agree with your recommendation, but I need some solution to move forward
