Can you please provide the sample code for extended mode advertisement (BLE 5)?
should I use same function "uint32_t update_advertisement_buffer(uint8_t * data)" while updating in ble 5?
Thank you,
Shreya
Thank you,
Shreya
You can refer to this blog post from Novel Bits, which will give you an idea of extended advertising. Could you share which SDK and version you are using here?
Kind Regards,
Abhijith
Hi Abhijith,
Thank you for referral link, I am using nrf52840 and SDK 16.0.
In this post they have mentioned as of 2017 we can use only 31 bytes for extended advertisement. now we can use upto 255 bytes right?!
this function is not used in Ble 5?
Thanks for sharing the information.
Shreya J B said:In this post they have mentioned as of 2017 we can use only 31 bytes for extended advertisement. now we can use upto 255 bytes right?!
Yes, that's true. You can advertise 255 bytes of data.
When it comes to the nRF5 SDK, you can refer to the Running Speed and Cadence Application (Peripheral) and the BLE Running Speed and Cadence Collector Example (Central) to get an idea of extended advertising.
Kind Regards,
Abhijith
Thank you
