In uart_event_handle case APP_UART_DATA_READY
Hello Karl
Transmitting NO\n 1 time via uart to nrf52840
In NRF side
Please use the Insert -> Code feature when sharing code here on DevZone.
It is not apparent from the code you have shared why NO is printed multiple times from the UART.
Please share more of the relevant code.
Karl
#include <stdint.h>
#include <string.h>
#include <stddef.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#include "SEGGER_RTT.h"
#include "nrf_gpio.h"
#include "nrf_drv_uart.h"
#if defined(UART_PRESENT)
#include "nrf_uart.h"
#if defined(UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "CPAPR&D" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 5000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
APP_TIMER_DEF(m_TRAIL_timer_id);
#define TRAIL_TIMER APP_TIMER_TICKS(1000)
static uint8_t array_index = 0;
uint8_t Ble_array_to_apk[240];
static uint8_t data_array[251];
bool overflowflag = false;
bool uartrxrdyflag=false;
uint16_t length;
uint32_t sequence = 0;
uint32_t err_code;
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
uint8_t sent = 0;
int LED_BLINK = NRF_GPIO_PIN_MAP(1, 06);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};
static void timeout_handler(void *p_context);
void AppUartHandler();
// static void advertising_start(void);
static void advertising_init(void);
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
void assert_nrf_callback(uint16_t line_num, const uint8_t *p_file_name)
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
(const uint8_t *)DEVICE_NAME,
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_evt_t *p_evt)
// if (p_evt->type == BLE_NUS_EVT_RX_DATA)
// uint32_t err_code;
// NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on UART.");
// NRF_LOG_INFO("NUS DATA");
// NRF_LOG_HEXDUMP_DEBUG(p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
// for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
// do
// err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
// if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
// NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
// APP_ERROR_CHECK(err_code);
// } while (err_code == NRF_ERROR_BUSY);
// if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
// while (app_uart_put('\n') == NRF_ERROR_BUSY)
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
static void on_conn_params_evt(ble_conn_params_evt_t *p_evt)
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
err_code = bsp_indication_set(BSP_INDICATE_ADVERTISING); // for blinking LED1
case BLE_ADV_EVT_IDLE:
NRF_LOG_INFO("Advertising event received %d", BLE_ADV_EVT_IDLE);
// sleep_mode_enter();
sd_ble_gap_adv_stop(m_advertising.adv_handle);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
static void ble_evt_handler(ble_evt_t const *p_ble_evt, void *p_context)
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
sent = 67;
NRF_LOG_INFO("Connected");
// err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
sent = 68;
NRF_LOG_INFO("Disconnected");
if (p_ble_evt->header.evt_id == BLE_GAP_EVT_DISCONNECTED)
// m_conn_handle = BLE_CONN_HANDLE_INVALID;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
// Pairing not supported
case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST: // FILES
ble_gap_data_length_params_t dl_params;
// Clearing the struct will effectivly set members to @ref BLE_GAP_DATA_LENGTH_AUTO
memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
case BLE_GATTC_EVT_TIMEOUT:
NRF_LOG_INFO("GATTC_TIMEOUT");
err_code = sd_ble_gap_disconnect(p_ble_evt->evt.gattc_evt.conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BLE_GATTS_EVT_TIMEOUT:
NRF_LOG_INFO("GATTS_TIMEOUT");
case BLE_GATTS_EVT_WRITE:
sent = 82; // Notification Enable
// NRF_LOG_INFO("UART SERVICES\n");
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t *p_gatt, nrf_ble_gatt_evt_t const *p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
void uart_event_handle(app_uart_evt_t *p_event)
// int MacAddr;
char buff;
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
// MacAddr = NRF_FICR->DEVICEADDR[0];
NRF_LOG_INFO("UART_COMM_READY\n");
uartrxrdyflag = true;
// NRF_LOG_INFO("app_uart :%d\n",err_code);
NRF_LOG_INFO("UART_COMM_ERROR\n");
// APP_ERROR_HANDLER(p_event->data.error_communication);
case APP_UART_FIFO_ERROR:
NRF_LOG_INFO("UART_FIFO_ERROR\n");
// APP_ERROR_HANDLER(p_event->data.error_code);
case APP_UART_TX_EMPTY:
uartrxrdyflag = false;
array_index = 0;
// memset(data_array, 0, sizeof(data_array));
// NRF_LOG_INFO("APP_UART_TX_EMPTY\n");
char buff;
// NRF_LOG_INFO("AppUartHandler\n");
app_uart_get(&data_array[array_index]);
array_index++;
buff = data_array[0];
NRF_LOG_INFO("DATA: %s",data_array);
if(data_array[array_index] == 'T')
memcpy(Ble_array_to_apk, data_array, sizeof(data_array));
overflowflag = true;
length = array_index;
array_index = 0;
// if ((array_index >= 240))
if ((data_array[array_index - 1] == '\n'))
switch (buff)
// err_code = ble_nus_data_send(&m_nus, data_array, &length, m_conn_handle);
// index = 0;
case 'N':
array_index = 0;
// NRF_LOG_INFO("BLE_ON\n");
sequence = 0;
ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
case 'L':
array_index = 0;
// NRF_LOG_INFO("BLE_OFF\n");
if ((sent == 67) || (sent == 82))
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
// NRF_LOG_INFO("uart_init..\n");
uint32_t err_code;
UART_APP_RX,
UART_APP_TX,
0,
0,
APP_UART_FLOW_CONTROL_DISABLED,
false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
APP_UART_FIFO_INIT(&comm_params,UART_RX_BUF_SIZE,UART_TX_BUF_SIZE,uart_event_handle,APP_IRQ_PRIORITY_HIGH,err_code);
// APP_UART_INIT(&comm_params,uart_event_handle,APP_IRQ_PRIORITY_LOWEST,err_code);
// NRF_LOG_INFO("advertising_init..\n");
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
static void log_init(void)
// NRF_LOG_INFO("LOG init..\n");
// NRF_LOG_INFO("PWR_MAN init.\n");
nrf_pwr_mgmt_run();
// // nrf_gpio_pin_toggle(LED_BLINK)
// uint32_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Application main function.
uart_init();
log_init();
SEGGER_RTT_Init();
timers_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
app_timer_create(&m_TRAIL_timer_id, APP_TIMER_MODE_REPEATED, timeout_handler);
app_timer_start(m_TRAIL_timer_id, TRAIL_TIMER, NULL);
// nrf_gpio_cfg_output(LED_BLINK);
// Start execution.
// advertising_start();
for (;;)
idle_state_handle();
if(uartrxrdyflag == true)
AppUartHandler();
if (overflowflag == true)
sequence += 1;
err_code = ble_nus_data_send(&m_nus, Ble_array_to_apk, &length, m_conn_handle);
// if(err_code == NRF_SUCCESS)
memset(Ble_array_to_apk, 0, sizeof(Ble_array_to_apk));
NRF_LOG_INFO("err_code: %d,sequence: %d\n", err_code, sequence);
// NRF_LOG_INFO("sent :%d\n",sent);
UNUSED_PARAMETER(p_context);
// NRF_LOG_INFO("trail started..\n");
app_uart_put(sent);
In this way i trasmit 240 bytes every 10ms there will be loss happens.
How can i rectify this
manobala12 said:In this way i trasmit 240 bytes every 10ms there will be loss happens.
Please be as specific as possible when you are writing about the issue.
Do you mean that this code aims to send 240 bytes over BLE each second, but you are seeing the same kind of issue as you have described and illustrated with your logs earlier?
Looking through your code it seems to me that you are trying to implement something very similar to the functionality in the unmodified BLE NUS peripheral example - could elaborate on how you would like to change the functionality of the original example?
In your case you are for instance not checking the returned error code for the app_uart_get function, which if it fails will cause the remaining of your AppUartHandler to fail.
I think your issue lies in the AppUartHandler in this case. Is your intention to just check the received UART data for some specific bytes (local commands, such as N and L), and then to also send this same data over BLE to another device? If so, have you ensured that this data never will contain the 'command symbols'?
Please elaborate on the functionality you are trying to achieve here, so that I may best advice you on how to approach this.
Karl
Hi karl
i got solution now there is no data loss
I changed min and max_conn_interval to 10
But 1MB data transmitting time 1min36sec it takes how can i reduce it
