NRF5340 long time test for BT, some devices failed.
Hi Devzone,
Test under -20 ℃.
About 500 hours, we found that BT can no longer be used until reboot system. We test 10pcs devices, and 5pcs devices have this issues.
Detail test:  we would start BT scan for 3 seconds then stop BT scan, Test  every 10minutes.
//scan param:
struct bt_le_scan_param common_scan_param = {
    .type = BT_LE_SCAN_TYPE_PASSIVE, // BT_LE_SCAN_TYPE_ACTIVE,
    .options = BT_LE_SCAN_OPT_FILTER_DUPLICATE,
    .interval = 0x800, // BT_GAP_SCAN_FAST_INTERVAL,
    .window = 0x400, // BT_GAP_SCAN_FAST_WINDOW,
    .timeout = 0U,
// scan call zephyr api:
err = bt_le_scan_start(&common_scan_param, NULL);
//stop scan call zephyr api:
err = bt_le_scan_stop();
BT issue detail errors:
1. Stop scan, return -120;
the error code -120 means:  -EALREADY;
2. Update adv param failed.
call api:
err = bt_le_ext_adv_update_param(ext_adv, common_param);
failed log:
//<wrn> bt_hci_core: opcode 0x2036 status 0x0c
//<err> atd560_bt: bt_le_ext_adv_update_param failed, err(-5).
The error code -5 means: -EIO.
Can you help us to find root cause and fix this issue?
