Environment:
1. node version: v20.12.2
2. pc-nrfconnect-launcher tag v4.4.1
Build Steps:
1. npm install
2. npm run build:prod:main
3. npm run app
Environment:
Build Steps:
1. npm install
3. npm run app
use Ctrl + R to refresh the page, I got this error
Hi Hugh,
Where did you install the nRF Connect for Desktop application from?
Did you also install the nRF Command Line Tools?
Which OS are you working on?
Priyanka
1. There is an installation on my windows 11 system, the version is 4.4.1. The installer is downloaded from Nordic Offical website, the problem I met is run from source code and the code tag is V4.4.1
2. Yes, I installed command line tools, version is 10.24.1
Hi Hugh,
I am looking into this. Do you get this error when you open the Desktop app ? Is the app just blank when you open it?
Priyanka
Hi, Priyanka:
Thanks.
The Desktop app installed from offifical installer works properly, it will NO show blank.
The bank window shows is that I build pc-nrfconnect-launcher from source code.
Environment:
Build & Run Steps:
1. npm install
3. npm run app
