nRF Connect 2.6 SDK builds crashes but working fine with nRF Connect SDK 2.43
Hi, I'm having trouble finding out which update caused my application to crash. The build works fine with nRF Connect 2.43, but with the latest version (2.6), it doesn't work and gives an error in the device tree. I've checked the release notes from versions 2.5, 2.5.1, 2.5.2, and 2.6, but I didn't find any relevant changes regarding the overlay.
I'm using Windows Windows 11.
Given error:
/spi-interface/spi-interface.c.obj -c C:/vacas/find-my-bull-fw-main/src/spi-interface/spi-interface.c
C:/vacas/find-my-bull-fw-main/src/spi-interface/spi-interface.c: In function 'init_spi':
C:/vacas/find-my-bull-fw-main/src/spi-interface/spi-interface.c:23:20: error: incompatible types when assigning to type 'struct spi_cs_control' from type 'struct spi_cs_control *'
   23 |     _spi_cfg->cs = cs_cfg;
[22/194] Building C object CMakeFiles/app.dir/src/lora-lib/nvs.c.obj
C:/vacas/find-my-bull-fw-main/src/lora-lib/nvs.c: In function 'nvs_read_init_parameter':
C:/vacas/find-my-bull-fw-main/src/lora-lib/nvs.c:80:14: warning: unused variable 'devnonce' [-Wunused-variable]
   80 |         int *devnonce = (void *)data;
C:/vacas/find-my-bull-fw-main/src/lora-lib/nvs.c:79:15: warning: unused variable 'array' [-Wunused-variable]
   79 |         char *array = (void *)data;
C:/vacas/find-my-bull-fw-main/src/lora-lib/nvs.c:77:17: warning: unused variable 'bytes_written' [-Wunused-variable]
   77 |         ssize_t bytes_written;
[24/194] Building C object CMakeFiles/app.dir/src/modem/modem.c.obj
In file included from C:/ncs/v2.6.0/zephyr/include/zephyr/logging/log.h:11,
                 from C:/vacas/find-my-bull-fw-main/src/modem/modem.c:3:
C:/vacas/find-my-bull-fw-main/src/modem/modem.c: In function 'lte_handler':
C:/vacas/find-my-bull-fw-main/src/modem/modem.c:35:17: warning: format '%d' expects argument of type 'int', but argument 2 has type 'uint64_t' {aka 'long long unsigned int'} [-Wformat=]
   35 |         LOG_INF("TAU pre-warning: Active time: %d", evt->time);
      |                                                        uint64_t {aka long long unsigned int}
C:/ncs/v2.6.0/zephyr/include/zephyr/logging/log_core.h:245:42: note: in definition of macro 'Z_LOG2'
  245 |                 z_log_printf_arg_checker(__VA_ARGS__); \
C:/ncs/v2.6.0/zephyr/include/zephyr/logging/log.h:63:24: note: in expansion of macro 'Z_LOG'
   63 | #define LOG_INF(...)   Z_LOG(LOG_LEVEL_INF, __VA_ARGS__)
C:/vacas/find-my-bull-fw-main/src/modem/modem.c:35:9: note: in expansion of macro 'LOG_INF'
C:/vacas/find-my-bull-fw-main/src/modem/modem.c:35:49: note: format string is defined here
      |                                                 int
      |                                                %lld
C:/vacas/find-my-bull-fw-main/src/modem/modem.c: In function 'configure_low_power':
C:/vacas/find-my-bull-fw-main/src/modem/modem.c:71:5: warning: 'lte_lc_rai_req' is deprecated [-Wdeprecated-declarations]
   71 |     err = lte_lc_rai_req(true);
In file included from C:/vacas/find-my-bull-fw-main/src/modem/modem.c:7:
C:/ncs/v2.6.0/nrf/include/modem/lte_lc.h:1613:18: note: declared here
 1613 | __deprecated int lte_lc_rai_req(bool enable);
C:/vacas/find-my-bull-fw-main/src/modem/modem.c: In function 'modem_configure':
C:/vacas/find-my-bull-fw-main/src/modem/modem.c:150:5: warning: 'lte_lc_init_and_connect_async' is deprecated [-Wdeprecated-declarations]
  150 |     err = lte_lc_init_and_connect_async(lte_handler);
C:/ncs/v2.6.0/nrf/include/modem/lte_lc.h:1311:18: note: declared here
 1311 | __deprecated int lte_lc_init_and_connect_async(lte_lc_evt_handler_t handler);
[25/194] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.6.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
Using the 2.43, no error was given.
Overlay File:
// To get started, press Ctrl+Space (or Option+Esc) to bring up the completion menu and view the available nodes.
// You can also use the buttons in the sidebar to perform actions on nodes.
// Actions currently available include:
// * Enabling / disabling the node
// * Adding the bus to a bus
// * Removing the node
// * Connecting ADC channels
// For more help, browse the DeviceTree documentation at https://docs.zephyrproject.org/latest/guides/dts/index.html
// You can also visit the nRF DeviceTree extension documentation at https://nrfconnect.github.io/vscode-nrf-connect/devicetree/nrfdevicetree.html
lsm6dsx: &spi1 {
    status = "okay";
    pinctrl-0 = <&spi1_default>;
    pinctrl-names = "default";
    cs-gpios = <&gpio0 10 (GPIO_ACTIVE_LOW)>;
&pinctrl {
    spi1_default: spi1_default {
        group1 {
            psels = <NRF_PSEL(SPIM_SCK, 0, 11)>;
/delete-node/ &{/pin-controller/spi3_default/group1/};
/delete-node/ &{/pin-controller/spi3_sleep/group1/};
&spi3 {
    status = "disabled";
&button2 {
    gpios = <&gpio0 0 0>;
&button3 {
    gpios = <&gpio0 1 0>;
&spi1_default {
    group1 {
        psels = <NRF_PSEL(SPIM_SCK, 0, 11)>,
                <NRF_PSEL(SPIM_MISO, 0, 9)>,
                <NRF_PSEL(SPIM_MOSI, 0, 8)>;
	aliases {
		lora0 = &lora;
&spi3 {
    status = "okay";
    pinctrl-0 = <&spi3_default>;
    cs-gpios = <&gpio0 15 GPIO_ACTIVE_LOW>;
    lora: sx1276@0 {
		compatible = "semtech,sx1276";
        status = "okay";
		reg = <0>;
		dio-gpios = <&gpio0 22 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>, //0
			<&gpio0 21 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>, //1
			<&gpio0 20 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>, //2
			<&gpio0 25 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>, //3
			<&gpio0 24 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>, //4
			<&gpio0 23 (GPIO_PULL_DOWN | GPIO_ACTIVE_HIGH)>; //5
		reset-gpios = <&gpio0 14 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
		spi-max-frequency		 = 	<1000000>;
        power-amplifier-output = "pa-boost";
		// pa-boost-enable-gpios		= <&gpio0 xx GPIO_ACTIVE_HIGH>;
		// power-amplifier-output	 = "rfo";
		// rfo-enable-gpios		 = 	<&gpio0 25 GPIO_ACTIVE_HIGH>;
		// antenna-enable-gpios		= <&gpio0 xx GPIO_ACTIVE_HIGH>;
&spi3_default {
	group1 {
		psels = <NRF_PSEL(SPIM_SCK, 0, 16)>,
		  <NRF_PSEL(SPIM_MISO, 0, 18)>,
		  <NRF_PSEL(SPIM_MOSI, 0, 17)>;
  • Hi
    I don't see anything devicetree related in the error you posted there. which version of the lsm6 are you using as there is different versions found in the Zephyr bindings?
    For me it also looks like you lack the compatible field for sensor in your devicetree. Below I added a very rough sample of how I expected it to look
    &spi1 {
        compatible = "nordic,nrf-spi";
        status = "okay";
        pinctrl-1 = <&spi1_sleep>;
        cs-gpios = <&gpio0 30 GPIO_ACTIVE_LOW>;
        lsm6dso: lsm6dso@0 {
        	compatible = "st,lsm6dso";
        	reg = <0>;
    	spi-max-frequency = <125000>;
    Could you also post the part of the code which throws an error?
    Regards
    Runar
  • Hi, thanks for the fast response Runar! You're right, the error actually isn't related to the device tree.
    C:/vacas/find-my-bull-fw-main/src/main.c:32:10: fatal error: src/messages/messages.pb.h: No such file or directory
       32 | #include "src/messages/messages.pb.h"
    I don't know why, but the protobuf files(c and h) aren't being generated during the build. They were causing an error, which I ended up ignoringwas leading to a cascade of other errors.
    Generating the files manually through the terminal, it builds normally.
    Thanks for the help.I hope you can fix the error in this version. Again, thank you for the response, sorry for the inconvenience!
    So building with west from CLI included the messages.pb.h while building from VScode build button did not include it? That sounds a bit strange to me
    From what I can see protobuf should include in the toolchain. Did you change toolchain when you changed to NCS 2.6?
    Regards
    Runar
  • Actually, building both from West and VSCode does not include the messages.pb.h. Making the proto files in the terminal using the nanopb generator commands builds the files, but the application does not locate the file. I'm sending the CMake that i'm using.
    Given Error:
    C:/vacas2.6/find-my-bull-fw-main/src/main.c:32:10: fatal error: messages.pb.h: No such file or directory
    32 | #include "messages.pb.h"
    cmake_minimum_required(VERSION 3.20.0)
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(cow-sys-fw)
    list(APPEND CMAKE_MODULE_PATH ${ZEPHYR_BASE}/modules/nanopb)
    include(nanopb)
    zephyr_nanopb_sources(app src/messages/messages.proto)
    FILE(GLOB app_sources src/main.c)
    FILE(GLOB lib_sources src/**/*.c)
    target_sources(app PRIVATE ${app_sources} ${lib_sources})
    The old version was like this, but since it wasn't generating the files messages.pb.h and messages.pb.c, I changed it. Using this file and version 2.4.3, it worked.
    project(cow-sys-fw)
    set(NANOPB_OPTIONS "-I${CMAKE_SOURCE_DIR}")
    nanopb_generate_cpp(proto_sources proto_headers RELPATH .
    zephyr_library_include_directories(${CMAKE_CURRENT_BINARY_DIR})
    target_sources(app PRIVATE ${app_sources} ${proto_sources} ${lib_sources})
  • Hi, I changed the project roots and I modified the CMake. The path error was fixed... but another one came up.
    New roots and new CMake:
    root
    |-MainProject
    | |-src
    | | |-main.cpp
    | | |-lib
    | | | |-libraries file
    | | |-messages
    | | | |-messages.ph.h
    | | | |-messages.ph.c
    | | | |-messages.proto
    | '-CMakeLists.txt
    project(cow-sys-fw)
    include(nanopb)
    FILE(GLOB proto_sources src/messages/messages.proto)
    FILE(GLOB lib_sources src/lib/**/*.c)
    target_sources(app PRIVATE ${app_sources} ${lib_sources} ${proto_sources})
    New error given:
    src/lib/spi-interface/spi-interface.c:23:20: error: incompatible types when assigning to type 'struct spi_cs_control' from type 'struct spi_cs_control *'
    spi-interface.c:
    #include <zephyr/kernel.h>
    #include <zephyr/drivers/spi.h>
    #include "spi-interface.h"
    struct spi_handle *init_spi(const struct device *spi, const struct device *gpio, uint8_t pin)
        struct gpio_dt_spec cs_gpio =
                .port = gpio,
                .pin = pin,
                .dt_flags = GPIO_ACTIVE_LOW};
        struct spi_cs_control *cs_cfg = (struct spi_cs_control *)k_malloc(sizeof(struct spi_cs_control));
        cs_cfg->gpio = cs_gpio;
        cs_cfg->delay = 0;
        struct spi_config *_spi_cfg = (struct spi_config *)k_malloc(sizeof(struct spi_config));
        _spi_cfg->frequency = 8000000;
        _spi_cfg->operation = SPI_TRANSFER_MSB | SPI_WORD_SET(8);
        struct spi_handle *spi_handle = (struct spi_handle *)k_malloc(sizeof(struct spi_handle));
        spi_handle->device = spi;
        spi_handle->config = _spi_cfg;
        return spi_handle;
    int32_t spi_register_write(void *handle, uint8_t Reg, const uint8_t *Bufp, uint16_t len)
        const struct spi_handle *spi = (const struct spi_handle *)handle;
        struct spi_buf tx_buf[2] = {
                .buf = &Reg,
                .len = 1,
                .buf = (uint8_t *)Bufp,
                .len = len,
        const struct spi_buf_set tx = {
            .buffers = tx_buf,
            .count = 2,
        return spi_write(spi->device, spi->config, &tx);
    int32_t spi_register_read(void *handle, uint8_t Reg, uint8_t *Bufp, uint16_t len)
        // const struct spi_config *config = spi->device->config;
        uint8_t tx_buffer[2] = {Reg | (1 << 7), 0x00};
        struct spi_buf tx_buf = {
            .buf = tx_buffer,
            .len = 2};
            .buffers = &tx_buf,
            .count = 1};
        struct spi_buf rx_buf[2] = {
            {.buf = NULL,
             .len = 1},
            {.buf = Bufp,
             .len = len}};
        const struct spi_buf_set rx = {
            .buffers = rx_buf,
            .count = 2};
        int ret = spi_transceive(spi->device, spi->config, &tx, &rx);
        return ret;
    spi-interface.h :100
    #ifndef SPI_INTERFACE_H
    #define SPI_INTERFACE_H
    struct spi_handle
        const struct device *device;
        const struct spi_config *config;
    struct spi_handle *init_spi(const struct device *spi, const struct device *gpio, uint8_t pin);
    int32_t spi_register_write(void *handle, uint8_t Reg, const uint8_t *Bufp, uint16_t len);
    int32_t spi_register_read(void *handle, uint8_t Reg, uint8_t *Bufp, uint16_t len);
    #endif // SPI_INTERFACE_H
