I'm devoloping a code that neeed send parameters using ble_uart. I used the ble_nus service as reference and works, but using rtt and not serial pin that I configured.
I tried initialize the code with uart_init and log_init, but inside the log_init function, the error 8 is returned during NRF_LOG_DEFAULT_BACKENDS_INIT() function.
my code is:
bool erase_bonds;
uint32_t deviceID[2]; //ID unico de cada processador
ret_code_t err_code;
//external_clock_init(); // Inicialização do clock externo
// Initialize.
#ifdef BLE_UART_CAL
uart_init(); //todo ble_uart
log_init(); //Inicializa Log serial utilizado pela pilha nrf - ok
gpiote_init();
//continue
and the uart_init function:
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = NRF_UART_PSEL_DISCONNECTED,
.tx_pin_no = NRF_LOG_BACKEND_UART_TX_PIN,
.rts_pin_no = NRF_UART_PSEL_DISCONNECTED,
.cts_pin_no = NRF_UART_PSEL_DISCONNECTED,
.use_parity = false,
#if defined (UART_PRESENT)
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
and the log_init function, the log backends init enabled:
void nrf_log_default_backends_init(void)
int32_t backend_id = -1;
(void)backend_id;
#if defined(NRF_LOG_BACKEND_RTT_ENABLED) && NRF_LOG_BACKEND_RTT_ENABLED
nrf_log_backend_rtt_init();
backend_id = nrf_log_backend_add(&rtt_log_backend, NRF_LOG_SEVERITY_DEBUG);
ASSERT(backend_id >= 0);
nrf_log_backend_enable(&rtt_log_backend);
Using this code, my debug is visualized in debug terminal inside the segger ide:
and according to ble_uart example, the values that I sent my ble application to my device, appears in serial terminal connected on pin that I configured.
When I tried using just pin to serial, the error 8 is returned. The init uart_serial using fifo mode and rtt is not. What is the best solution to transfer my debug terminal to serial pin.
Can you help me?
Regards
Laerte
