Can't get BLE device to sleep
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then set a timer to wake the `app_timer_start(m_awake_timer_id, APP_TIMER_TICKS(SLEEP_IN_MS), NULL);`
And I expect the device to go into sleep whilst its BLE is not advertising. Here's my main.c file:
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_crypto_init.h"
#include "nrfx_clock.h"
#include "SEGGER_RTT.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "customble.h"
#include "peripheral.h"
#include "encryption.h"
void timers_init(void)
    nrf_pwr_mgmt_run();
void power_management_init(void)
  ret_code_t err_code;
  NRF_LOG_INIT(NULL);
  ret_code_t reta = nrf_crypto_init();
  APP_ERROR_CHECK(reta);
  timers_init();
  ble_timers_init();
  ble_stack_init();
  power_management_init();
  gap_params_init();
  advertising_init();
  advertising_start();
  for (;;)
    idle_state_handle();
and here's the relevant sections of the customble.c code
void awake_timer_handler()
  NRF_LOG_INFO("Awake and start advertising");
  update_advertising_data_while_advertising();
void sleep_timer_handler()
  NRF_LOG_INFO("asleep");
  sd_ble_gap_adv_stop(m_advertising.adv_handle); // i've tried with and without this
  // Proceed with setting the device to low power mode
  app_timer_start(m_awake_timer_id, APP_TIMER_TICKS(SLEEP_IN_MS), NULL); // 60 seconds
void on_adv_evt(ble_adv_evt_t ble_adv_evt)
  NRF_LOG_INFO("BLE EVENT");
  switch (ble_adv_evt)
  case BLE_ADV_EVT_IDLE:
    NRF_LOG_INFO("Advertising event: Idle");
    sleep_timer_handler();
I have measured the amps on the device and during advertising it jumps to about 3mA and when it's not advertising (when I thought it would sleep) it's using ~1.48mA. What exactly am I doing wrong here?
I have commented lots of things out, and it's not the TWI causing the issue, it's definitely the BLE. When I comment out starting BLE, I get ~400uA constant.
  • prsboy said:
    I have completely removed all reference of DEVELOP_IN_NRF52832.
    What exactly does that mean? I just meant that you should remove it from your preprocessor definitions if you are actually running on an nRF52810 chip.
    1: Are you actually running it on an nRF52810?
    2: Did you remove it from your preprocessor definitions in SES?
    prsboy said:
    #define NRFX_CLOCK_CONFIG_LOG_ENABLED 1 #define NRFX_CLOCK_CONFIG_LOG_LEVEL 4
    From apply_old_config.h:
    #if defined(CLOCK_CONFIG_LOG_ENABLED)
    #undef NRFX_CLOCK_CONFIG_LOG_ENABLED
    #define NRFX_CLOCK_CONFIG_LOG_ENABLED  CLOCK_CONFIG_LOG_ENABLED
    #if defined(CLOCK_CONFIG_LOG_LEVEL)
    #undef NRFX_CLOCK_CONFIG_LOG_LEVEL
    #define NRFX_CLOCK_CONFIG_LOG_LEVEL  CLOCK_CONFIG_LOG_LEVEL
    So try to set CLOCK_CONFIG_LOG_ENABLED = 1 as well, and CLOCK_CONFIG_LOG_LEVEL = 4.
    You can verify the values of NRFX_CLOCK_CONFIG_LOG_ENABLED by printing it to your log from your main.c file:
    NRF_LOG_INFO("clock log enabled: %d, log_level: %d", NRFX_CLOCK_CONFIG_LOG_ENABLED, NRFX_CLOCK_CONFIG_LOG_LEVEL);
    Another check you can do in your application is to add this before you initiate your timers:
    void check_clock_source(void)
      NRF_LOG_INFO("checking LFCLK ...");
      NRF_CLOCK->TASKS_LFCLKSTART = 1;
      while (NRF_CLOCK->EVENTS_LFCLKSTARTED == false)
        // wait...
      NRF_LOG_INFO("LFCLK started!");
        LOG_INIT()
        check_clock_source();
        ble_stack_init()
    And see if that function returns, or if it is stuck. I believe it should return, because you shouldn't be able to initiate the softdevice without an LFCLK.
    If you don't figure it out, can you please upload the updated application that can reproduce the issue you are seeing on a DK?
    Edvin
  • What exactly does that mean? I just meant that you should remove it from your preprocessor definitions if you are actually running on an nRF52810 chip.
    1. Yes, I was deploying it on my PCBA (I am using the NRF52DK to flash the PCBA).
    2. I removed it from everywhere I found it:
    https://gist.github.com/scripter-co/47fad092cd1815eed748b9d47f33a4a2
    But I also did exactly what you said in your message and just removed it through SES from the preprocessor and the same result (no BLE signal detected).
    I also added the debug/log messages:
    <info> app: checking LFCLK ...
    <info> app: LFCLK started!
    <info> app_timer: RTC: initialized.
    <info> CLOCK: Function: nrfx_clock_init, error code: NRF_SUCCESS.
    <info> clock: Function: nrf_drv_clock_init, error code: NRF_SUCCESS.
    <info> app: Starting temperature measurement.
    <info> app: Reading temperature data.
    <info> app: Calculated temperature: 22.66 C
    <info> app: number: 2266
    <info> app: Starting humidity measurement.
    <info> app: Reading humidity data.
    <info> app: number: 5953
    <info> app: BLE EVENT
    <info> app: start ble
    so it seems that everything is working as it should.
    ---- 5 hours later ----
    Oh! I've spent the the whole day looking into this and I've noticed that the custom board is actually advertising - despite the interval set to advertise every 5 seconds (as an example), when I scan for the device using both laptop/phone, it takes a very long time to pick up the signal (5 mins after started searching):
    the DK is picked up straight away. I just happened to notice this after I changed the configuration of NRF Connect to not timeout after 2 minutes and then notice it show up 5 minutes later.
    So I guess the question now is, what could cause the BLE advertising to be so intermittent when deployed to the custom PCBA when using RC oscillator? The signal is not regular - the advertising packets are received very sporadically and unreliably.
    edit:
    I've played around with the advertising interval and timeout and increasing/decreasing the `ble_adv_fast_interval` makes no difference to the ability to pick anything up. Even when I set ble_adv_fast_timeout = 0 it still behaves the same.
    prsboy said:
    ok, I was afraid you removed every instance in the SDK, but that is not the case. Good.
    These log messages are coming at a regular speed, right (Like within one second)? Or is it significantly slower when you are using RC than when you are using the SYNTH?
    Good to know. Make sure you select the "common" in the upper left corner before removing it (I tried to mark it in my screenshot). However, if you removed all like you did in the git diff, then that should have been removed as well.
    Advertising every 5 seconds is pretty slow. I see that you tried experimenting with different advertising intervals. Have you tried running one of the simpler samples on your custom board? The ble_app_hrs, for example, isn't dependent on any other peripherals (it uses UART for logging, but you can change that to RTT, or remove it). Also remember to change the clock to the RC oscillator, like you did for your application. Do you see any advertisements there?
    Just to explain my thoughts. Usually when there are issues with custom boards, the clock configuration is one of the first things we look into. Seeing as it works if you are using the SYNTH, this suggests that your HFCLK setup is fine, this for two reasons:
    1: You are able to pick up the advertising packets, meaning that the packets generated by the radio are correct. The HFCLK is used to send these packets.
    2: The synthesized LFLCK is running of the HFLCK, meaning that - at least if the advertising interval seems correct - the HFCLK is also fine.
    So this leaves the LFCLK. This is only used to keep track of the time between the packets when you are using the softdevice. So it can be quite off, as long as you are only advertising. The only issue would be that the advertising interval would be a bit off (more than the random 0-10ms added delay).
    I noticed a warning when building your application again, that NRFX_RNG_ENABLED was defined more than once. It may be that your current application is slightly different than mine, but can you please try to run the attached application, and let me know what the (RTT) log says, and whether you are able to see the advertisements:
    output_edvin.zip
    It should print the actual values (compile time) of the clock configuration definitions. Do you see something like this?
    <info> app: NRFX_RNG_ENABLED 1
    <info> app: CLOCK_CONFIG_LF_SRC 0
    <info> app: NRF_SDH_CLOCK_LF_SRC 0
    <info> app: NRF_SDH_CLOCK_LF_RC_CTIV 16
    <info> app: NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    <info> app: NRF_SDH_CLOCK_LF_ACCURACY 1
    <info> app: my addr: D7:72:C7:D6:4A:E1
    If you are still not able to see the advertisements, can you please test the attached project? It should start blinking the LEDs every 1 second (2 second period). Does it seem correct? Or is it way to fast/slow?
    2768.blinky.zip
    (pca10040e\blank\ses)
    Does that work on your board?
    Edvin
  • Advertising every 5 seconds is pretty slow. I see that you tried experimenting with different advertising intervals. Have you tried running one of the simpler samples on your custom board?
    I misspoke when I said this, sorry. I meant timeout, not interval. So 5 seconds advertising (100ms interval) - sleep for 10 seconds - repeat.
    I believe that to not be an issue, it's when I was setting up the crypto libraries. I believe it's when I define both
    #define RNG_ENABLED 1
    #define NRFX_RNG_ENABLED 1
    They're the same thing?
    That being said, here is the output of the application you requested:
    <info> app: my addr: D0:07:B7:A4:FC:E2
    I couldn't quite get that project setup, so I quickly wrote another one to run on my PCBA that does the same (blinks the light using app timers every 1000ms:
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "boards.h"
    #define LED_PIN 6 // LED connected to pin 6
    APP_TIMER_DEF(m_led_toggle_timer);
    static void led_toggle(void * p_context)
        UNUSED_PARAMETER(p_context);
        nrf_gpio_pin_toggle(LED_PIN);
    static void timers_init(void)
        // Initialize the app timer module.
        // Create the timer to toggle the LED every 1 second.
        err_code = app_timer_create(&m_led_toggle_timer, APP_TIMER_MODE_REPEATED, led_toggle);
    static void gpio_init(void)
        // Initialize the GPIO pin as output with initial value as low (LED off)
        nrf_gpio_cfg_output(LED_PIN);
        nrf_gpio_pin_clear(LED_PIN);
        // Initialize the LFCLK required for the timers.
        nrf_drv_clock_init();
        gpio_init();
        timers_init();
        // Start the timer
        ret_code_t err_code = app_timer_start(m_led_toggle_timer, APP_TIMER_TICKS(1000), NULL);
        // Enter main loop.
        while (true)
    and the output looks good to me:
    Edit:
    I got the ble_app_hrs_pca10040e_s112 example working on both the DK and custom PCBA. First image is on the DK and second is on the custom PCBA (I removed DEVELOP_IN_NRF52832 when on the PCBA as needed).
    Ok, that looks good. I can't tell from your snippet, but that is using the RC-oscillator, and not the SYNTH LFCLK_SRC, right?
    Just so I didn't misunderstand something. When you initially tested your own application, and the issue was the high current consumption. Were you able to pick up more advertising packets then? When you were using the SYNTH source for the LF clock? Or was the performance the same?
