Can't get BLE device to sleep
I have a custom PCBA with which has the flow of:
- Boot
- Advertise some temperature data read from TWI with a 5 second timeout using `ble_adv_fast_timeout`.
- I then set a timer to wake the `app_timer_start(m_awake_timer_id, APP_TIMER_TICKS(SLEEP_IN_MS), NULL);`
And I expect the device to go into sleep whilst its BLE is not advertising. Here's my main.c file:
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_crypto_init.h"
#include "nrfx_clock.h"
#include "SEGGER_RTT.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
#include "customble.h"
#include "peripheral.h"
#include "encryption.h"
void timers_init(void)
    nrf_pwr_mgmt_run();
void power_management_init(void)
  ret_code_t err_code;
  NRF_LOG_INIT(NULL);
  ret_code_t reta = nrf_crypto_init();
  APP_ERROR_CHECK(reta);
  timers_init();
  ble_timers_init();
  ble_stack_init();
  power_management_init();
  gap_params_init();
  advertising_init();
  advertising_start();
  for (;;)
    idle_state_handle();
and here's the relevant sections of the customble.c code
void awake_timer_handler()
  NRF_LOG_INFO("Awake and start advertising");
  update_advertising_data_while_advertising();
void sleep_timer_handler()
  NRF_LOG_INFO("asleep");
  sd_ble_gap_adv_stop(m_advertising.adv_handle); // i've tried with and without this
  // Proceed with setting the device to low power mode
  app_timer_start(m_awake_timer_id, APP_TIMER_TICKS(SLEEP_IN_MS), NULL); // 60 seconds
void on_adv_evt(ble_adv_evt_t ble_adv_evt)
  NRF_LOG_INFO("BLE EVENT");
  switch (ble_adv_evt)
  case BLE_ADV_EVT_IDLE:
    NRF_LOG_INFO("Advertising event: Idle");
    sleep_timer_handler();
I have measured the amps on the device and during advertising it jumps to about 3mA and when it's not advertising (when I thought it would sleep) it's using ~1.48mA. What exactly am I doing wrong here?
I have commented lots of things out, and it's not the TWI causing the issue, it's definitely the BLE. When I comment out starting BLE, I get ~400uA constant.
  • Ok, that looks good. I can't tell from your snippet, but that is using the RC-oscillator, and not the SYNTH LFCLK_SRC, right?
    Correct, with the RC oscillator.
    When you initially tested your own application, and the issue was the high current consumption. Were you able to pick up more advertising packets then? When you were using the SYNTH source for the LF clock? Or was the performance the same?
    Yes, when setting the LFCLK to SYNTH everything behaves exactly how I'd expect. I've attached two scans, the first one is my custom PCBA with SYNTH, the second is using the RC oscillator:
    SYNTH
    #define CLOCK_CONFIG_LF_SRC 2
    #define NRF_SDH_CLOCK_LF_SRC 2
    #define NRF_SDH_CLOCK_LF_RC_CTIV 0
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 0
    #define NRF_SDH_CLOCK_LF_ACCURACY 5
    #define ADV_TIMEOUT 1000
    #define SLEEP_IN_MS 10000
    As you can see from the screenshot, it's advertising for 10 seconds then sleeping for 10 seconds.
    RC oscillator
    #define CLOCK_CONFIG_LF_SRC 0
    #define NRF_SDH_CLOCK_LF_SRC 0
    #define NRF_SDH_CLOCK_LF_RC_CTIV 16
    #define NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
    #define NRF_SDH_CLOCK_LF_ACCURACY 1
    just to add more intrigue into this, when running the RC oscillator, with the same configuration as above, nothing shows up.
    If I update the advertising timeout to 20 seconds,
    #define ADV_TIMEOUT 2000
    I get this:
    Note the duration of this scan 38 minutes and it detected 35 advertisement packets. When I use the synthesised clock I get that in a few seconds.
    Whilst this update frequency would be fine, the problem is when I then reduce the sleep to 120 seconds to preserve battery, it'll be a much longer period of time before an advertisement is picked up.
    Edit:
    I decided I was just going to play around with the rc configuration. The following configuration works* best for my device:
    #define NRF_SDH_CLOCK_LF_ACCURACY 9
    With these values, and setting the original settings of 10 seconds advertising, 10 seconds sleep I get the following:
    Now, it's nowhere near as good as using the synthesised lfclk, but at least i'm detecting multiple packets per advertisements each wake cycle.
    * As with everything, there's a cost to this - the "sleep" cycle is almost non-existent as it hops from sleep into what I imagine is a wake calibrate the rc oscillator. This is the power being used whilst in sleep:
    To my fairly uneducated mind, this configuration change and increase in packets received does suggest that the rc oscillator is not stable enough with the recommended settings - does that make sense?
  • I find this very odd.
    Do you happen to have a PPK2? If so, can you please capture some graphs from running on SYNTH, and from running the RC_OSCILLATOR? A multimeter doesn't really give a clear picture of what's going on.
    If you have not already, I suggest that you also create a new ticket where you upload your schematics and PCB layout and ask for a layout review. I am not sure what it would be, but perhaps one of our HW engineers can spot something that I have not thought of.
    Have you tried to capture a sniffer trace of the advertisements? You can do so using the nRF Sniffer for Bluetooth LE. If possible, can you upload one trace usnig SYNTH and one using the RC_OSCILLATOR?
    BR,
    Edvin
  • Indeed, very strange.
    Will a PPK1 do? I can get ahold of one of those in a few days.
    I will get those sniffer traces uploaded for both SYNTH and RC.
    How do I request a specific hardware review?
    Yes. That works too. The PPK2 is a bit easier to use, but the PPK 1 will still give accurate readings, and perhaps show some patterns that can reveal something.
    Just create a ticket here on DevZone (but make it private, unless you want your design to be out in the public), and add your PCB layout files and your schematics. If you didn't design the HW, then talk to the people who did, and they probably know what files we are talking about. And if something is missing, the HW engineer from our side that is assigned to the ticket will know what additional files to request.
    However, before you do this. Did you test this on one device, or do you have several custom boards? It would be interesting to know whether this behavior is only present on one nRF Chip, or several.
    BR,
    Edvin
  • hello again  !
    After a few attempts at trying to get the PPK1 to work, I managed to take some readings. This is with the previously mentioned configuration:
    with 10 seconds advertising, then 120 seconds sleep. This is the graph for one sleep/wake cycle
    here is 1 seconds worth of data for the awake period
    and here is 1 second for the sleep period
    this all seems very high to me, so perhaps i've not setup the device correctly. here's how i have it setup:
    1. I have plugged the PPK1 into the DK.
    2. I have plugged in the computer to the DK.
    3. I have used the EXTERNAL OUT pins on the PPK1 to provide power to my custom PCBA
    does that make sense? if not, I can take a photo.
