Hello, there seem to be a lot of technical details missing from the datasheet. In my case, I really need to know the capabilities of the load switches such as reverse current protection, leakage current, etc. My application will involve using the load switch to connect VSYS to VBUS. This is because I am using the same pin as an input and an output so it needs reverse current protection in case the switch is left on while 5V is applied to the same pin for charging.
Also, the precision of the battery current measurement is not mentioned. The datasheet just says where the measurements are stored but not what the value of the LSB is.
