NRF52 DK RTT printf Problem
I recently purchased the NRF52 DK. I'm using the ble_uart_example for the SDK 11. I'm using the softdevice PCA10040.
I noticed the the SDK 11 includes the RTT c and h files there, so I don't need to worry about using the tutorial.
I want to test out the SEGGER_rtt_printf, but when I compile and link the project, it gave me an error saying.
"._build\nrf52832_xxaa_s132.axf: Error: L6218E: Undefined symbol SEGGER_RTT_printf (referred from main.o)."
So I defined it as #define SEGGER_RTT_printf, it compiles but it gives me 3 warnings that about expressions that have no effect. That one couldn't print anything on jlink rtt.
I read the documentation for the sdk11, but it didn't give me much help. I currently have the nrf51dk kit and it didn't have this error. And it worked fine.
What am I missing here?
Thanks
Update:
image description
image description
  • I think this is a bug in the SDK. I don't see why Nordic has chosen to add "#ifdef NRF_LOG_USES_RTT" to SEGGER's source file. Whatever the compiler generates, the linker should omit if it is not referenced. If you download from SEGGER (as answered above), the file does not have that #ifdef. Then assuming I am wrong and there is a need for that, shouldn't Nordic have also added #include "sdk_config.h", which is where "#define NRF_LOG_USES_RTT 1" should be defined, by Nordics own convention? In other words, adding -DNRF_LOG_USES_RTT=1 works, but is not the documented way of configuring.
  • Thanks for mentioning the difference. Even I had made all the respective changes in sdk_config.h believing it should compile. But only -DNRF_LOG_USES_RTT=1 works.
