NRF9160 https_client does not connect to example.com
1. am currently using the nrf9161_dk. and have not modified the modem FW in anyway.
2. I am using the vscode extension provided by nordic to build/run this sample
        a, i am using version v2.4.1 for the SDK
3. this is my build config.  with this configuration  get the err 111 which when i look it up means   #define ECONNREFUSED 111   /* Connection refused */
this is the output:
*** Booting Zephyr OS build v3.3.99-ncs1-2 ***
HTTPS client sample started
Certificate mismatch
Provisioning certificate
Waiting for network.. PDP context 0 activated
OK
Looking up example.com
Resolved 93.184.216.34 (AF_INET)
Connecting to example.com:443
connect() failed, err: 111
PDP context 0 network detached
So then i tried adding mbed tools as well:
build config with mbed tool:
and i get this errno 22 #define  EINVAL 22   /* Invalid argument */
So then i has a thingy91 and decided to test that dev kit out, i uploaded that modem with mfw_nrf9160_1.3.5.zip  and i am running the exact same configurations and i am getting the same errors.
does anyone have any ideas of what might be happening here and why the sample is not working, any input is appreciated.
thanks,
    Could you please test the same sample in NCS v2.6.0? Do you get the same errors?
    Dejan
  • hello, i updated the SDK to v2.6.0 and the toolchain is also at v2.6.0. now i am getting deprecation warnings like 'lte_lc_init_and_connect' is deprecated. i can still run the  example, another difference now is that if i only add the ipv4.conf i get the same 111 error, but if i add the mbed.conf file, i get the following errors C:/ncs/v2.6.0/nrf/ext/oberon/psa/core/library/check_crypto_config.h:106:2: error: #error "PSA_WANT_ALG_RSA_PKCS1V15_CRYPT defined, but not all prerequisites"
    106 | #error "PSA_WANT_ALG_RSA_PKCS1V15_CRYPT defined, but not all prerequisites"
    C:/ncs/v2.6.0/nrf/ext/oberon/psa/core/library/check_crypto_config.h:112:2: error: #error "PSA_WANT_ALG_RSA_PKCS1V15_SIGN defined, but not all prerequisites"
    112 | #error "PSA_WANT_ALG_RSA_PKCS1V15_SIGN defined, but not all prerequisites"
    so it seems that v2.6.0 does not work either
  • Dejans, did you check, if that works with NCS v2.6.0?
  • I checked it with a nRF9160-DK and a nRF9161-DK, NCS-2.6.0:
    Works with both.
    Build log (nRF9161):
    -- Application: .../nrf/samples/net/https_client
    -- CMake version: 3.29.2
    -- Found Python3: /usr/bin/python3 (found suitable version "3.10.12", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: .../.cache/zephyr
    -- Zephyr version: 3.5.99 (.../zephyr)
    -- Board: nrf9161dk_nrf9161_ns, Revision: 0.9.0
    -- ZEPHYR_TOOLCHAIN_VARIANT not set, trying to locate Zephyr SDK
    -- Found host-tools: zephyr 0.16.5 (.../zephyr-sdk-0.16.5-1)
    -- Found toolchain: zephyr 0.16.5 (.../zephyr-sdk-0.16.5-1)
    -- Found Dtc: .../zephyr-sdk-0.16.5-1/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found BOARD.dts: .../zephyr/boards/arm/nrf9161dk_nrf9161/nrf9161dk_nrf9161_ns.dts
    -- Generated zephyr.dts: .../nrf/samples/net/https_client/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: .../nrf/samples/net/https_client/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: .../nrf/samples/net/https_client/build/zephyr/dts.cmake
    warning: Experimental symbol NET_CONNECTION_MANAGER is enabled.
    Parsing .../nrf/samples/net/https_client/Kconfig
    Loaded configuration '.../zephyr/boards/arm/nrf9161dk_nrf9161/nrf9161dk_nrf9161_ns_defconfig'
    Merged configuration '.../nrf/samples/net/https_client/prj.conf'
    Merged configuration '.../nrf/samples/net/https_client/boards/nrf9161dk_nrf9161_ns.conf'
    Configuration saved to '.../nrf/samples/net/https_client/build/zephyr/.config'
    Kconfig header saved to '.../nrf/samples/net/https_client/build/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: .../zephyr-sdk-0.16.5-1/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: .../zephyr-sdk-0.16.5-1/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Using ccache: /usr/bin/ccache
    Dropping partition 'nrf_modem_lib_trace' since its size is 0.
    Dropping partition 'nonsecure_storage' since it is empty.
    -- Configuring done (4.9s)
    -- Generating done (0.1s)
    -- Build files have been written to: .../nrf/samples/net/https_client/build
    [1/295] Preparing syscall dependency handling
    [3/295] Generating include/generated/version.h
    -- Zephyr version: 3.5.99 (.../zephyr), build: v3.5.99-ncs1
    [10/295] Generating ../../tfm/CMakeCache.txt
    CMake Warning at cmake/version.cmake:22 (message):
      Actual TF-M version is not available from Git repository.  Settled to
      v2.0.0
      CMakeLists.txt:22 (include)
    -- Found Git: /usr/bin/git (found version "2.34.1")
    -- Found Python3: /usr/bin/python3 (found version "3.10.12") found components: Interpreter
    CMake Deprecation Warning at .../zephyr/cmake/modules/FindDeprecated.cmake:121 (message):
      'PYTHON_PREFER' variable is deprecated.  Please use Python3_EXECUTABLE
      instead.
      .../zephyr/cmake/modules/python.cmake:16 (find_package)
      .../zephyr/cmake/modules/user_cache.cmake:30 (include)
      .../zephyr/cmake/modules/extensions.cmake:5 (include)
      .../nrf/subsys/nrf_security/tfm/CMakeLists.txt:38 (include)
    -- Configuring done (0.9s)
    -- Generating done (0.0s)
    CMake Warning:
      Manually-specified variables were not used by the project:
        CRYPTO_RNG_MODULE_ENABLED
        MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE
        PYTHON_PREFER
    -- Build files have been written to: .../nrf/samples/net/https_client/build/tfm
    [15/295] Performing build step for 'tfm'
    [164/168] Linking C executable bin/tfm_s.axf
    Memory region         Used Size  Region Size  %age Used
               FLASH:       32096 B        32 KB     97.95%
                 RAM:       10416 B        32 KB     31.79%
    [168/168] Linking C static library secure_fw/libtfm_s_veneers.a
    [17/295] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    ----- Installing platform NS -----
    [293/295] Linking C executable zephyr/zephyr.elf
               FLASH:      115948 B       992 KB     11.41%
                 RAM:       45644 B     211608 B     21.57%
            IDT_LIST:          0 GB        32 KB      0.00%
    [295/295] Generating zephyr/merged.hex
    Console output:
    *** Booting nRF Connect SDK v3.5.99-ncs1 ***
    Bringing network interface up
    Connecting to the network
    +CEREG: 2,"67B9","01CC2B03",7
    +CSCON: 1
    +CGEV: ME PDN ACT 0,0
    +CNEC_ESM: 50,0
    +CEREG: 5,"67B9","01CC2B03",7,,,"11100000","11100000"
    Network connectivity established and IP address assigned
    Resolved 93.184.215.14 (AF_INET)
    Sent 61 bytes
    Received 371 bytes
    >     HTTP/1.1 200 OK
    Finished, closing socket.
    +CEREG: 0
    +CGEV: ME DETACH
    +CSCON: 0
    Network connectivity lost
    Disconnected from the network
     , I have tested https_client sample on nrf9161-dk in both NCS v2.4.1 and v2.6.0. I have observed the same errors as you when using nrf9161-dk in NCS v2.4.1 (errors 111 and 22). I got different errors in NCS v2.6.0.
     , we have tested internally on another nrf9161-dk board and results were the same as you reported, without errors.
    We would need some time to investigate further why we got different results. We will further look into this issue during next week.
    Could you  and  provide information about the versions of your nrf9161-dk boards that you used for testing?
    Dejan
