I've stumbled upon an adc_read issue on NRF52832, where following a certain sequence, adc_read gets stuck forever. I'm inserting a small code block that replicates the issue for me (on the second/third run). In the example, I read one channel first with calibration on, then go ahead and read two channels with a single call (providing the appropriate mask in adc sequence) & in this case it gets stuck on the first/second run of the code block. If I read all channels one by one, or, enable calibration for the two channel read, it does not get stuck. Have you noticed any similar behavior? Did I misconfigure something or maybe this is a known issue? Thanks!
int16_t ch0_sample;
int16_t ch6ch7_sample[2];
struct adc_sequence seq_ch0 =
.buffer = &ch0_sample,
.buffer_size = sizeof ch0_sample,
.calibrate = true,
.channels = BIT(0),
.oversampling = 4,
.resolution = 12
struct adc_sequence seq_ch6ch7 =
.buffer = ch6ch7_sample,
.buffer_size = sizeof ch6ch7_sample,
.calibrate = false,
.channels = BIT(6) | BIT(7),
.oversampling = 0,
.resolution = 8
struct adc_channel_cfg ch0_cfg = {
.channel_id = 0,
.gain = ADC_GAIN_1,
.reference = ADC_REF_INTERNAL,
.acquisition_time = ADC_ACQ_TIME(ADC_ACQ_TIME_MICROSECONDS, 40),
.input_positive = SAADC_CH_PSELP_PSELP_AnalogInput0,
struct adc_channel_cfg ch6_cfg = {
.channel_id = 6,
.gain = ADC_GAIN_1_5,
.acquisition_time = ADC_ACQ_TIME_DEFAULT,
.input_positive = SAADC_CH_PSELP_PSELP_AnalogInput6,
struct adc_channel_cfg ch7_cfg = {
.channel_id = 7,
.input_positive = SAADC_CH_PSELP_PSELP_AnalogInput7,
int err = adc_channel_setup(adc_device, &ch0_cfg);
if (err != 0)
return err;
err = adc_channel_setup(adc_device, &ch6_cfg);
if (err != 0)
return err;
err = adc_channel_setup(adc_device, &ch7_cfg);
if (err != 0)
return err;
err = adc_read(adc_device, &seq_ch0);
if (err != 0)
return err;
err = adc_read(adc_device, &seq_ch6ch7);
if (err != 0)
return err;
