Connecting P19 pins from nRF52-DK to my custom board
I am trying to use a 10-pin flat cable to connect my custom board to nRF52-DK to program the nRF52840 on my custom board.
Just wanted to make sure I connected the wired correctly. From the pins specified here, I will connect
SWD0_VTG to VDD of nRF52840 (only effective when I short the SB32 on nRF52840)
SWD0_SWDIO to SWDIO of nRF52840
SWD0_SELECT to GND of nRF52840
SWD0_SWDCLK to SWDCLK of nRF52840
GND to GND of nRF52840
SWD0_SW0 can be left floating?
SWD0_RESET to P0.18/RESET of nRF52840
Could you please confirm if the connection above is correct? Then, if I don't short SB32, all I need to do is to connect the custom board and nRF52-DK with the 10-pin cable and power up the custom board (VDD) with 3V,right? (The nRF52-DK will be powered by USB)
Also, I was able to use UART with printk() using nRF Connect SDK on my nRF52-DK. If I want to do the same with my custom board, which pins on the nRF52840 shall I use as the TX and RX? If they are configurable, which are the default pins? (used by the hello world example in nRF Connect SDK)
Thank you!
  • Hi.
    That looks correct, Are you observing any issues with it?
    Yes,
    By default the examples will use P0.06 and P0.08 for RX and TX.
    regards
    Jared
  • Thank you very much for confirming that!
    Another related question:
    I want to put the 10 SWD pins on my custom board. However, I cannot find the bill of materials of nRF52-DK. Specifically, I am looking for the part number of the 10 pins used for P19. So far, this item is the closest that I can find, but I am wondering if there is any specific manufacturer and part number. (I assume Nordic didn't get those pins from Adafruits)
    Alternatively, could you suggest any keywords I should use to find parts like this?
    Thank you!
