Accidentally used 9V power supply. nRF9160 board wont flash anymore.
Accidentally used a 9V power supply. Board does not flash anymore.
Can still connect to com ports, and onboard led lights up.
Is the board fried or is it stuck in a memory protection mode ?
-nRF Connect SDK 2.5.1
-Win 11
Different error messages below:
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: c:\ncs\v2.5.1\zephyr\samples\basic\blinky\build\zephyr\merged.hex
[error] [ Client] - Encountered error -90: Command read_memory_descriptors executed for 14 milliseconds with result -90
[error] [ Worker] - Can't read memory descriptors, ap-protection is enabled.
[error] [ Client] - Encountered error -90: Command erase_file executed for 30 milliseconds with result -90
[error] [  nRF91] - Failed while detecting device memory block protection status!
[error] [  nRF91] - Failed while erasing device. -90: Access protection is enabled, can't read block protection state.
[error] [ Worker] - Access protection is enabled, can't read block protection state.
ERROR: The operation attempted is unavailable due to readback protection in
ERROR: your device. Please use --recover to unlock the device.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
ERROR: runners.nrfjprog: Flashing failed because the target must be recovered.
  To fix, run "west flash --recover" instead.
  Note: this will recover and erase all flash memory prior to reflashing.
-- west flash: rebuilding
[0/16] Performing build step for 'tfm'
ninja: no work to do.
Using board 960064568
-- runners.nrfjprog: Recovering and erasing all flash memory.
Recovering device. This operation might take 30s.
[error] [  JLink] - Not supported by current CPU + target interface combination.
[error] [ Client] - Encountered error -21: Command recover executed for 21131 milliseconds with result -21
[error] [  nRF91] - Unable to perform system reset. Device is readback protected.
[error] [ Worker] - Encountered error while performing recover post-cleanup.
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
FATAL ERROR: command exited with status 62: nrfjprog --recover -f NRF91 --snr 960064568
nrfjprog --eraseall -f NRF91
[error] [ Client] - Encountered error -90: Command read_memory_descriptors executed for 16 milliseconds with result -90
[error] [ Client] - Encountered error -21: Command recover executed for 30554 milliseconds with result -21
  • I was able to update the firmware on the nRF9160 board. But the issue still remains.
    I am not quite sure that i understand what you meant with the last reply. Is there a guide for this ?
  • First of all, just to verify, have you seen our Developer Academy? This goes through various levels of the nRF Connect SDK e.g. Cellular IoT Fundementals.
    The nRF9160DK includes an onboard debugging/programming interface which allows you to program external devices such as the nRF9160 and nRF52840 on the Thingy:91 More information found here: https://docs.nordicsemi.com/bundle/ug_nrf91_dk/page/UG/nrf91_DK/hw_debug_out.html
    The issue of programming the device?
    Are you able to program e.g. AT Client from the Precompiled firmware package found on the nRF9160DK product page? Does the AT client allow you to send AT commands to the nRF9160 modem to e.g. turn on and off LTE?
  • I have gone through the SDK and celluar fundamentals courses. I am able to flash the AT client program to the device. But it stops at "The AT host sample started". And when reflashing the same memory error appear.
    This application does not do more other than show AT commands. You should be able use the Serial Terminal or Cellular Monitor to get information in the application.
    E.g
    *** Booting nRF Connect SDK v3.5.99-ncs1 ***
    Ready
    > AT+CFUN=1
    OK
    > AT%XCONNSTAT=1
    OK
    > AT%XCONNSTAT?
    %XCONNSTAT: 0,0,0,0,0,0
    OK
    > AT+CMEE=1
    OK
    > AT%XSIM=1
    OK
    > AT+CEREG=5
    OK
    > AT%MDMEV=1
    +CME ERROR: 0
    > AT%CESQ=1
    OK
    > AT+CGSN=1
    +CGSN: "352656100376253"
    OK
    > AT+CGMM
    nRF9160-SICA
    OK
    > AT+CEMODE?
    +CEMODE: 2
    OK
    > AT+CMEE?
    +CMEE: 1
    OK
    > AT+CNEC?
    +CNEC: 0
    OK
    > AT+CGEREP?
    +CGEREP: 0,0
    OK
    > AT+CIND=1,1,1
    OK
    > AT+COPS=3,2
    OK
    > AT+CGDCONT?
    OK
    > AT+CGACT?
    OK
    > AT+CESQ
    +CESQ: 99,99,255,255,255,255
    OK
    > AT%XSIM?
    %XSIM: 0
    OK
    > AT+CPIN?
    +CME ERROR: 13
    > AT+CIMI
    +CME ERROR: 0
    > AT+CNEC=24
    OK
    > AT+CEER
    OK
    > AT+CGEREP=1
    OK
    > AT%XPOFWARN=1,30
    +CME ERROR: 0
    > AT%XVBATLVL=1
    OK
    > AT+CGMI
    Nordic Semiconductor ASA
    OK
    > AT+CGMR
    mfw_nrf9160_1.2.3
    OK
    > AT+CGSN
    352656100376253
    OK
    > AT%XMODEMUUID
    %XMODEMUUID: 0191538f-d3a5-4fe9-8f54-ba7cad9460c0
    OK
    > AT%XDATAPRFL?
    %XDATAPRFL: 2
    OK
    > AT+CEREG?
    +CEREG: 5,4,"FFFE","FFFFFFFF",7,0,0,"00000000","00000000"
    OK
    > AT+CFUN?
    +CFUN: 1
    OK
    > AT%CESQ=1
    OK
    > AT+CSCON=1
    OK
    > AT+CSCON?
    +CSCON: 1,0
    OK
    > AT+CPAS
    +CPAS: 0
    OK
    > AT+CEDRXRDP
    +CEDRXRDP: 4,"1001","0000","0000"
    OK
    > AT%XTIME=1
    OK
    > AT%CONEVAL
    +CME ERROR: 0
    > AT%XCBAND=?
    %XCBAND: (1,2,3,4,5,8,12,13,18,19,20,25,26,28,66)
    OK
    > AT%XCBAND
    %XCBAND: 0
    OK
    > AT%HWVERSION
    %HWVERSION: nRF9160 SICA B0A
    OK
    > AT%XMODEMTRACE=1,2
    OK
    > AT%XSYSTEMMODE?
    %XSYSTEMMODE: 1,0,0,0
    OK
    > AT%XICCID
    +CME ERROR: 0
    > AT%XEMPR?
    %XEMPR:
    OK
    > AT+CGDCONT?
    OK
    > AT+COPS?
    +COPS: 0
    OK
    > AT%XMONITOR
    %XMONITOR: 4
    OK
    > AT+CPINR="SIM PIN"
    +CEREG: 90
    %XSIM: 0
    You are referring to - "Can't read memory descriptors, ap-protection is enabled" ?
  • You are referring to - "Can't read memory descriptors, ap-protection is enabled" ?
    Yes.
    The application stops at "The AT host sample started" It does not initialize the modem libary. This is where the program stops in my own program aswell. And this worked before using the 9V power supply.
