I am dealing with a persistent I2S RX overrun issue in the nRF5340 audio application that is impacting data reception and disrupting communications between the gateway and headsets. I have provided logs below that illustrate the problem, and I am seeking advice on possible solutions.
Issue Summary: The nRF5340 appears to not receive data correctly from the I2S, resulting in no data being sent from the gateway. As a result, the headsets receive nothing, which interrupts the compensation mechanism and perpetually triggers the presentation compensation due to the lack of reference packets.
Steps to Reproduce:
Initial Setup:
- Utilize the nRF5340 audio application version v2.6.0.
Modifications Made:
- Adjustments have been made to the
sw_codec_select.candaudio_system.cfiles.
Configuration Adjustments:
pri.confFile Updates:CONFIG_TRANSPORT_CIS=y: Enable CIS transport.CONFIG_AUDIO_SOURCE_I2S=y: Set the audio source to I2S.CONFIG_BT_BAP_UNICAST_16_2_1=y: Enable Bluetooth Audio Profile Unicast 16.2.1.CONFIG_SW_CODEC_LC3=y: Integrate software codec LC3.CONFIG_LE_AUDIO_MSG_SUB_STACK_SIZE=51200: Increase LE Audio Message Subscription stack size to 51200.
konfigFile Changes:- Adjusted stack sizes under the menu "Stack sizes":
config ENCODER_STACK_SIZE: 15000 for AUDIO_BIT_DEPTH_16 and 22528 for AUDIO_BIT_DEPTH_32.config AUDIO_DATAPATH_STACK_SIZE: 38000 for AUDIO_BIT_DEPTH_16 and 73500 for AUDIO_BIT_DEPTH_32.
Triggering the Issue:
- Power on the devices and start data transmission.
- Monitor LED statuses: Gateway (LED1 blue blinking, LED3 green blinking); Headsets (LED1 blue blinking, LED2 green constant, LED3 green blinking).
Observing the Error:
- Logs from headsets show early signs of configuration but stop updating shortly after.
Logs of gateway:
GW [00:00:00.320,404] <inf> fw_info:
nRF5340 Audio nRF5340 Audio DK cpuapp
NCS base version: 2.6.0
Cmake run : Tue Apr 16 13:21:10 2024
GW [00:00:00.320,434] <inf> fw_info: ------- DEBUG BUILD -------
GW [00:00:00.320,434] <inf> fw_info: Compiled for GATEWAY device
GW [00:00:00.341,400] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 5.4 (0x0d), Revision 8591
GW [00:00:00.341,644] <inf> bt_mgmt: Local identity addr: F1:53:CB:A1:37:61 (random)
GW [00:00:00.352,783] <inf> bt_mgmt_scan: All bonded slots filled, will not accept new devices
GW [00:00:00.355,102] <inf> bt_mgmt_scan: Local addr: 51:DF:06:55:F6:F3 (random). May time out. Updates not printed
GW [00:00:00.355,102] <inf> bt_mgmt_scan: Scanning successfully started
GW [00:00:00.791,046] <inf> bt_mgmt_scan: Creating connection to bonded device: E4:0A:37:69:AE:56 (random)
GW [00:00:00.798,828] <inf> bt_mgmt: Connected: E4:0A:37:69:AE:56 (random)
GW [00:00:00.798,950] <inf> bt_mgmt_scan: All bonded slots filled, will not accept new devices
GW [00:00:00.800,018] <inf> bt_mgmt_scan: Local addr: 51:DF:06:55:F6:F3 (random). May time out. Updates not printed
GW [00:00:00.800,048] <inf> bt_mgmt_scan: Scanning successfully started
GW [00:00:00.800,048] <inf> main: Device connected
GW [00:00:00.817,413] <inf> bt_mgmt_scan: Creating connection to bonded device: D4:3B:14:F0:11:28 (random)
GW [00:00:00.871,307] <inf> bt_mgmt: Connected: D4:3B:14:F0:11:28 (random)
GW [00:00:00.871,337] <inf> main: Device connected
GW [00:00:01.118,804] <inf> main: Security changed
GW [00:00:01.188,812] <inf> main: Security changed
GW [00:00:01.718,750] <inf> bt_rend_vol: VCS discover finished
GW [00:00:01.828,765] <inf> bt_rend_vol: VCS discover finished
GW [00:00:03.480,255] <inf> unicast_client: LEFT sink stream configured
GW [00:00:03.521,148] <inf> unicast_client: Enable stream 0x20004988
GW [00:00:03.710,266] <inf> unicast_client: RIGHT sink stream configured
GW [00:00:03.789,764] <inf> unicast_client: Enable stream 0x20004bf0
GW [00:00:03.839,080] <inf> unicast_client: Stream 0x20004988 started
--- 1 messages dropped ---
GW [00:00:03.968,719] <wrn> audio_datapath: I2S RX continuing stream
--- 12 messages dropped ---
GW [00:00:04.099,731] <inf> audio_datapath: Drft comp state: CALIB
--- 10 messages dropped ---
GW [00:00:04.200,714] <inf> audio_datapath: Drft comp state: CALIB
--- 8 messages dropped ---
GW [00:00:04.333,709] <wrn> audio_datapath: I2S RX continuing stream
--- 7 messages dropped ---
GW [00:00:04.455,718] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:04.564,697] <wrn> audio_datapath: I2S RX overrun. Single msg
--- 5 messages dropped ---
GW [00:00:04.674,713] <wrn> audio_datapath: I2S RX overrun. Single msg
--- 6 messages dropped ---
GW [00:00:04.774,719] <wrn> audio_datapath: I2S RX continuing stream
GW [00:00:04.820,709] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:04.927,703] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:05.062,713] <wrn> audio_datapath: I2S RX continuing stream
GW [00:00:05.182,708] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:05.327,697] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:05.463,714] <wrn> audio_datapath: I2S RX continuing stream
GW [00:00:05.584,716] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:05.720,703] <wrn> audio_datapath: I2S RX continuing stream
GW [00:00:05.839,721] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:05.948,699] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:06.091,705] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:06.200,714] <wrn> audio_datapath: I2S RX overrun. Single msg
GW [00:00:06.336,700] <wrn> audio_datapath: I2S RX continuing stream
Logs of headsets:
HL [00:00:00.319,488] <inf> fw_info:
Cmake run : Tue Apr 16 13:20:42 2024
HL [00:00:00.319,519] <inf> fw_info: ------- DEBUG BUILD -------
HL [00:00:00.319,519] <inf> fw_info: HEADSET left device
HL [00:00:00.339,294] <inf> bt_mgmt_ctlr_cfg: Controller: SoftDevice: Version 5.4 (0x0d), Revision 8591
HL [00:00:00.339,477] <inf> bt_mgmt: Local identity addr: E4:0A:37:69:AE:56 (random)
HL [00:00:00.354,064] <inf> bt_mgmt_adv: Local addr: 69:AA:C0:29:40:AF (random)
HL [00:00:00.354,125] <inf> bt_mgmt_adv: Adv directed to: F1:53:CB:A1:37:61 (random).
HL [00:00:00.354,736] <inf> bt_mgmt_adv: Advertising successfully started
HL [00:00:00.885,070] <inf> bt_mgmt: Connected: F1:53:CB:A1:37:61 (random)
HL [00:00:00.885,101] <inf> main: Connected
HL [00:00:00.885,498] <inf> bt_mgmt_adv: RPA (Resolvable Private Address) expired.
HL [00:00:00.885,589] <inf> bt_mgmt_adv: Local addr: 69:AA:C0:29:40:AF (random)
HL [00:00:01.412,200] <inf> main: Security changed
HL [00:00:01.412,445] <wrn> bt_gatt: Device is not subscribed to characteristic
HL [00:00:01.412,445] <wrn> bt_pacs: PACS notify failed: -22
HL [00:00:05.412,048] <inf> bt_content_ctrl_media: Discovery of MCS finished
HL [00:00:05.812,835] <inf> unicast_server: LC3 codec config for sink:
HL [00:00:05.812,835] <inf> unicast_server: Frequency: 48000 Hz
HL [00:00:05.812,835] <inf> unicast_server: Duration: 10000 us
HL [00:00:05.812,835] <inf> unicast_server: Channel allocation: 0x1
HL [00:00:05.812,835] <inf> unicast_server: Octets per frame: 120 (96000 bps)
HL [00:00:05.812,835] <inf> unicast_server: Frames per SDU: 1
HL [00:00:05.972,747] <inf> main: Presentation delay 10000 us is set by initiator
HL [00:00:06.539,276] <inf> unicast_server: Stream 0x2000f850 started
HL [00:00:06.549,987] <wrn> le_audio_rx: Not in streaming state, throwing data: 1
HL [00:00:06.559,997] <wrn> le_audio_rx: Not in streaming state, throwing data: 1
HL [00:00:06.569,976] <wrn> le_audio_rx: Not in streaming state, throwing data: 1
HL [00:00:06.581,237] <wrn> audio_datapath: Data received, total under-runs: 4
HL [00:00:06.639,221] <inf> audio_datapath: Drft comp state: CALIB
HL [00:00:06.739,227] <inf> audio_datapath: Drft comp state: INIT
HL [00:00:06.740,234] <inf> audio_datapath: Drft comp state: CALIB
HL [00:00:06.840,240] <inf> audio_datapath: Drft comp state: OFFSET
HL [00:00:07.071,960] <wrn> audio_datapath: Data received, total under-runs: 5
HL [00:00:07.439,788] <inf> audio_datapath: Drft comp state: LOCKED
HL [00:00:07.440,490] <inf> audio_datapath: Pres comp state: MEAS
HL [00:00:07.550,506] <inf> audio_datapath: Pres comp state: WAIT
HL [00:00:07.698,516] <inf> audio_datapath: Pres comp state: INIT
HL [00:00:07.700,500] <inf> audio_datapath: Pres comp state: MEAS
HL [00:00:07.810,485] <inf> audio_datapath: Pres comp state: WAIT
HL [00:00:07.949,951] <inf> audio_datapath: Pres comp state: INIT
HL [00:00:07.959,075] <inf> audio_datapath: Pres comp state: MEAS
HL [00:00:08.069,061] <inf> audio_datapath: Pres comp state: WAIT
HL [00:00:08.210,479] <inf> audio_datapath: Pres comp state: INIT
HL [00:00:08.230,072] <inf> audio_datapath: Pres comp state: MEAS
HL [00:00:08.340,179] <inf> audio_datapath: Pres comp state: WAIT
HL [00:00:08.469,085] <inf> audio_datapath: Pres comp state: INIT
HL [00:00:08.490,051] <inf> audio_datapath: Pres comp state: MEAS
HL [00:00:08.600,067] <inf> audio_datapath: Pres comp state: WAIT
HL [00:00:08.740,081] <inf> audio_datapath: Pres comp state: INIT
HL [00:00:08.749,969] <inf> audio_datapath: Pres comp state: MEAS
HL [00:00:08.858,520] <inf> audio_datapath: Pres comp state: WAIT
HL [00:00:09.000,061] <inf> audio_datapath: Pres comp state: INIT
HL [00:00:09.008,544] <inf> audio_datapath: Pres comp state: MEAS
HL [00:00:09.118,530] <inf> audio_datapath: Pres comp state: LOCKED
Questions and Insights: Is the I2S RX overrun issue potentially caused by the sw_codec_encode function processing PCM data slower than I2S reads it? Could a mismatch in the data processing speed of the software codec and the I2S data read rate be the root cause of these overruns? I welcome any insights or experiences related to similar issues, especially any adjustments or configurations that have been effective in preventing I2S RX overrun.
I am also considering whether modifying the size of pcm_raw_data in the source code found at encoder_thread could help stabilize the input size and potentially resolve the I2S RX overrun issue. Would fixing the size of pcm_raw_data to a constant value be a feasible solution? I would appreciate any thoughts on this approach or experiences with similar adjustments.
Thank you in advance for your assistance.
Runqi
