I am using a I2C based sensor for my project. I referred to the example projects in the nRF Connect SDK as well as online tutorial for this.
I have 2 questions on the same.
1. My sensor has no default driver available for nRF platform, so can I still use this example. https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-6-serial-com-i2c/topic/exercise-1-6-2/ . The reason I am asking because, if I use this, I am not able to read/ write to 8-bit register address of the sensor. Getting the below error.
Can you help me fix this or guide me through appropriate examples for my use case.
2. I see that there is a major difference in the way I2C/ TWI is handled between the examples provided in the IDE (tx_rx_blocking, tx_rx_non_blocking, txrx, txtx) and this example: https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-6-serial-com-i2c/topic/exercise-1-6-2/
The way I2C/ TWI is configured and the APIs used are totally different between the two. Wanted to understand the use case of both types of examples so that I can choose the example appropriately.
I am using nRF53 series board with nRF Connect SDK IDE.
